Sound comparison (CTRL-G) real Elk and 4 emulators
0xC0DE
Post by 0xC0DE » Thu Apr 11, 2019 7:19 pm
Can you hear the difference?
Real Electron, waveform as output by the speaker is not a simple square wave:
Listen:
real.zip
(421.28 KiB) Downloaded 10 times
Electroniq (my own Electron emulator), square wave:
Listen:
electroniq.zip
(359.71 KiB) Downloaded 6 times
Electrem, square wave:
Listen:
electrem.zip
(381.56 KiB) Downloaded 7 times
Elkulator, square wave, but sounds slightly lower than the other emulators and the real Electron:
Listen:
elkulator.zip
(356.47 KiB) Downloaded 5 times
MAME, square wave:
Listen:
mame.zip
(380.69 KiB) Downloaded 5 times
So, to my ears, most emulators sound pretty close to the real Elk. Except for Elkulator which sounds slightly lower. And the waveform of a real Elk is definitely not square so it produces a 'richer' sound.
- 0xC0DE
Visit my YouTube channel featuring demo videos of Electroniq, my Acorn Electron emulator
SarahWalker
Re: Sound comparison (CTRL-G) real Elk and 4 emulators
Post by SarahWalker » Thu Apr 11, 2019 8:06 pm
The non-squarewaveness of the real machine should be a combination of filtering, noise/interference and poor frequency response of the cheap speaker.
Post by Richard Russell » Thu Apr 11, 2019 9:52 pm
Whilst that may well be true, it's perhaps worth noting that the waveform being very different doesn't imply that the sound will be different. For example these two waveforms should sound identical, because they differ only in the phase of the harmonics, and the ear isn't sensitive to phase:
Post by Rich Talbot-Watkins » Fri Apr 12, 2019 9:39 am
Yes! This is something that is not often appreciated! Here are a couple of examples in WolframAlpha to demonstrate the point.
Odd harmonics at same phase
Odd harmonics at different phases
Post by Rich Talbot-Watkins » Fri Apr 12, 2019 1:19 pm
Here's a spectrum analysis of the real one and ElectrEm's, for comparison:
Real
ElectrEm
Both dominant in odd harmonics, as per a pure square wave, but the real one is somehow more filtered. Not sure why the even harmonics in ElectrEm's waveform are so dominant, when it looks so convincingly like a square wave. Might be to do with the window function I used, although the actual output from the speaker (as opposed to the input to it) will introduce artefacts as well.
Last edited by Rich Talbot-Watkins on Fri Apr 12, 2019 1:20 pm, edited 1 time in total.
Post by Richard Russell » Fri Apr 12, 2019 2:52 pm
Might be to do with the window function I used.
[pedant]There's no such thing as a 'Hanning' window! A 'Hann' window yes, but calling it 'Hanning' for its similarity with 'Hamming' is not to be encouraged.[/pedant]
Last edited by Richard Russell on Fri Apr 12, 2019 2:55 pm, edited 2 times in total.
ThomasHarte
Post by ThomasHarte » Sun Apr 21, 2019 3:11 am
Using no science whatsoever, I played about with the filtering options I can apply in Clock Signal for free and subjectively thought that applying a 7kHz lowpass filter sounded most similar? Heavily subject to prejudices about nice round numbers, of course. It's attached.
Electron 7kHz.wav.zip
(10.04 KiB) Downloaded 3 times
0xC0DE
Post by 0xC0DE » Mon Apr 22, 2019 10:35 am
No science involved here either, and no audio expert either :mrgreen:
To be honest it sounds just a tiny bit too high. I can see the difference in wave lengths when comparing all the sounds in Audacity.
And the waveform is odd(?), no negative values. Have no idea if that really matters.
- 0xC0DE
Post by Richard Russell » Mon Apr 22, 2019 10:53 am
Adding a DC offset, i.e. a component at zero frequency, isn't going to affect the acoustic spectrum or the subjective sound. But it may not be good for your loudspeaker, if it gets that far.
