BBC, electron, atom, arch(?) on retropie?
iainjh
Post by iainjh » Wed Jul 11, 2018 8:46 pm
Hi
Has anyone got beebem or other compiled, working on retropie and added to emulation station etc?
I’ve read various threads that seem to lead to nowhere, missing sound etc,and mess seems a bit of a dead end re performance
I did see a mention of a build for sale in Kickstarter but nothing now happening it seems.
Anyone got these working?
As an aside it’d be great to focus a retropie build on computers not games machines... the acorns would beef such a collection up massively!
trixster
Re: BBC, electron, atom, arch(?) on retropie?
Post by trixster » Wed Jul 11, 2018 9:45 pm
I have both beebem and b-em working on my Pi, one of which (can’t remember which but I think it’s beebem) runs through emulationstation and the other through the desktop. Both work fine however the one that goes through emulationstation hangs if you try to open a disk requestor, so you can’t save your game or machine state. I think this is because it’s not compiled for sdl2.
I haven’t used them for a year or two so my recollection is hazy. Performance with both emulators is fine with an Rpi3.
A3020 | A3000 | A420/1 | BBC B 128K RAM/ROM 20K Shadow Pi0 VideoNuLA
Master Turbo DC BeebSID | Atom | A4000 060 | A3000 060 | A1200 060 | A500
Atari Falcon 060 | Saturn | PS1 | SNES | CPC6128 | C64 | 3DO | MD | Jaguar | X68000
Post by Elminster » Wed Jul 11, 2018 10:35 pm
Really I found they all worked (including B2) but performance was fairly poor. They were both compiled from source, but were running under raspbian. I didn’t try any tuning.
iainjh
Post by iainjh » Wed Jul 18, 2018 11:36 pm
Oops I didn’t reply sorry :(
Thanks for info I guess I’ll need compile and try it.
I also want to set up separate ES menu option for separate machines.
Martin8777
Post by Martin8777 » Tue Jan 22, 2019 6:47 pm
Did you have any success with that? I am building a retropie machine in the shell of my old Electron so would love to be able to play Electron games on there or BBC if that's not do-able.
cheers.
MK
iainjh
Post by iainjh » Sat Feb 02, 2019 10:50 pm
still working on it
I have bbc kindof working, more work to do. beebem and also under mess. beebem is without sound it seems, and mess is slow.
I'll hopefully get atom working under mess and i'll repost.
JasonStonier
Post by JasonStonier » Thu Feb 07, 2019 7:39 pm
If you ever get sound working, please let me know how. I've been working on it for a while and haven't cracked it!
In the end I built a standard small form factor PC for my RetroPie box, simply because Beebem sound works when compiled for x86.
iainjh
Post by iainjh » Sat Feb 09, 2019 8:37 pm
I've given up on compiling mess or lr-mess as always failed
I found that installing the advmame binary also gives an advmame executable in the /bin folder - and it seems to work!
this isnt completely correct, but I suggest starting here:
https://retropie.org.uk/forum/topic/198 ... asic-guide
There is plenty of conflicting info out there. There's a few w.i.p .cfg file pastes below if you want to have a go. I want to get electron and atom working as well as Beeb. I hadn't expected the speed to be usable at all but so far it seems ok?! Arcadians seems to run with sound. I need find how to get the fps displayed.
I do have a few keymap issues, physical positioning might be needed, and small issues like entering *., so I've deleted the advmame map for . (that had triggered scaling options) and I can now *., and *exec !boot arcadians.
i dont know if the per game settings are persistent.
also exile fails, 3d snooker runs.
opt/retropie/configs/bbcmicro/emulators.cfg
advmess = "/opt/retropie/emulators/advmame/bin/advmess bbcb -floppy %ROM%"
default = "advmess"
es_systems.cfg snippet:
  <system>
    <name>bbcmicro</name>
    <fullname>BBC Micro</fullname>
    <path>/home/pi/RetroPie/roms/bbcmicro</path>
    <extension>.ssd .dsd .SSD .DSD .zip .ZIP</extension>
	 <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ bbcmicro %ROM%</command>
    <platform>bbcmicro</platform>
    <theme>bbcmicro</theme>
  </system>
Post by Pernod » Sat Feb 09, 2019 9:32 pm
So which version of MESS does advmess give you, is it the latest?
There have been countless improvements to BBC and Electron emulation in MAME (MESS no longer exists) over the past couple of years, so anything older will have plenty of known issues.
