MAME: Tape wav images
vanekp
Post by vanekp » Mon Jan 29, 2018 5:54 pm
I see the electron emulator also allows you to load tape wav files as a cassette but when you try to load it it sees no data, is this not yet implemented in the MAME Electron or is there another reason for it?
Peter.
Re: MAME: Tape wav images
Post by 1024MAK » Mon Jan 29, 2018 6:53 pm
Post by Pernod » Mon Jan 29, 2018 7:03 pm
vanekp wrote:I see the electron emulator also allows you to load tape wav files as a cassette but when you try to load it it sees no data, is this not yet implemented in the MAME Electron or is there another reason for it?
I believe all computers in MAME support WAV, all formats UEF, TAP, CSW, etc. are converted internally to WAV before being fed to the machine.
There may be limitations though, which I'm not sure is machine specific or a general MAME thing. Can you post (link to) your WAV and I'll see what the issue may be?
vanekp
Post by vanekp » Mon Jan 29, 2018 10:00 pm
in the MAME BBC they work fine but the electron one does not see any data.
On the BBC
On the elctron no data seen
This is the wav file I was using to test.
Aardvark - Frak(withCheat).rar
(72.59 KiB) Downloaded 21 times
Post by Pernod » Tue Jan 30, 2018 11:31 am
vanekp wrote:in the MAME BBC they work fine but the electron one does not see any data.
That does seems odd. I don't have an explanation right now, but will look into it.
vanekp
Post by vanekp » Tue Jan 30, 2018 4:09 pm
I though so as well :wink: , and thanks that would be greatly appreciated.
Peter.
vanekp
Post by vanekp » Thu Feb 01, 2018 11:24 am
where can one dowload the full rom set for the BBC and Electron ONLY for Mame or can you only get it if you download the full rom set?
Post by CMcDougall » Tue Mar 06, 2018 9:18 pm
bump LOL
just had a go at this as well (mame0195b_64bit.exe, win10), even got the Atom to work 8)
I can see all the tapes I have done (Tangled etc) and Kees (Galaforce etc) games too, but....
where do I get the image packs :? ie for the pictures.
Which folder do I put all my .CSW .UEFhq .WAV files :?: , so I can run them, put them in the ROMS folder, but said can't find.
not played with this MAME /MESS for 20years, after my director bought a CD off eBay and I got it to work.
it was easy to use, just double clicked any game, and off it went :)
vanekp
Post by vanekp » Tue Mar 06, 2018 9:39 pm
I think mame only works with uef ( hq uef) wav and disc images which have to have to correct name and are normally stored in the ROM folder, uef it i think only supports the normal uef's not the high quality its not been updated to that as yet, you can also start up say the BBC emulator, chose start empty then press scroll lock and then tab to get into the menu and load them from there under File Manager cassette or floppydisk1, exit out and then press scroll lock and you should then be able to run whatever image you have loaded.
Edit:- a couple of things to keep in mind the BBC disc system is fine as long as you use read only be very careful if you turn on write as there is a bug and it messes the disc catalog up, don't think it's been fixed as yet, and the electron emulator does not see tape data from wav files, uef works fine.
Post by CMcDougall » Tue Mar 06, 2018 10:20 pm
vanekp wrote:press scroll lock and then tab to get into the menu and load them from there under File Manager
bingo 8) , cheers Peter, also need >Tape Control play
just playing with the Atom at mo, and my original .WAVs, but could also use CSW to WAV & that should be same.
don't like the green screen much, and it's buggy too :
mame
should be this :
Atomulator128
have added below the atom.zip file to put in ROMS folder I made if anyone wants a play of it...
and =/+ on PC is for * for *RUN /LOAD "f" on Atom
atom.zip
atom roms akernal & basic joined etc
(83.85 KiB) Downloaded 8 times
Post by Pernod » Wed Mar 07, 2018 1:09 am
CMcDougall wrote:don't like the green screen much, and it's buggy too
I wasn't aware of that, something else I need to look at I guess. I also want to de-couple the colour board so you can have the option of original B&W or colour.
vanekp
Post by vanekp » Wed Mar 07, 2018 6:34 am
Yes for the atom you manual have to start tape play BBC and others it's automatic :wink:
