FIXED operation SAFRAS
duikkie
Post by duikkie » Thu Dec 18, 2014 6:27 pm
there where about 4 files on the disk to run safras. there was strange thinks on screen, when you push the funtions keys and the quit statement in the game was wrong
safras is now totaly m/c code program, i changed the begin screen a little in mode 7. all funtionkey are disabled, break key is function, quit statement in game is there to quit and not start over again
FIXSAFRAS.zip
(17.26 KiB) Downloaded 109 times
Site Admin
Re: FIXED operation SAFRAS
Post by Arcadian » Thu Dec 18, 2014 6:37 pm
Well done Duikkie. =D>
Have moved your post to the Archive Submission forum ...
Michael Brown
Post by Michael Brown » Sun Jun 07, 2015 7:15 am
Hi Duikkie, there is a error in the game. If you press T to buy a ticket and then go to nottingham, you get a "Error in Adventure" message and it restarts.
Not sure if this is a bug with the original game or in the transfer, So do you have the original tape/disc image and can you post that here for checking.
I obtained some inlay instructions for this game and would like to include it on one of my newer games discs.
Again, good work in finding the game and posting it.
regards,
Mick.
PS nearly forgot, As this game uses the Incentive Adventure Creator utility, the same graphics glitch appears under BeebEm that affected Winter Wonderland and The Alien from Outer Space.
It works fine under b-em, but the same error when going to nottingham occurs.
Michael Brown
Post by Michael Brown » Wed Jun 10, 2015 7:09 pm
Hi Duikkie,
Using the files from Pernod's disc, I have been able to make a disc version that works properly and I have added the inlay info to a new instruction file.
FIXSAFRAS.zip
(19.24 KiB) Downloaded 96 times
Also, because the filenames now match those on the 2 Incentive games that have been corrected for BeebEm, I have been able to add the same fix for the graphics glitch to the ADV1 file at &61BC.
FIXSAFRASbeebem.zip
(19.25 KiB) Downloaded 94 times
regards,
Mick.
billcarr2005
Post by billcarr2005 » Thu Jun 11, 2015 9:33 am
Doesn't appear to have fixed it...
Also, the code at &61BC is now
61BA LDA #&02
61BC LDA #&02
61BE STA &01A9
61C1 STA &FE01
From the A9 01, I assume you were trying to LDA#1 to put it somewhere
Michael Brown
Post by Michael Brown » Thu Jun 11, 2015 2:13 pm
Hi Bill,
Well the fix is the same as the fix on the 2 Incentive games.
It always has been a temporary fix and hopefully one of the BeebEm authors will address this issue.
Obviously, for now playing the game under b-em is the best way to go. However, I am sure a fix for BeebEm cannot be out of the question as other issues with it have been resolved in the past.
regards,
Mick.
billcarr2005
Post by billcarr2005 » Thu Jun 11, 2015 5:54 pm
I've attempted to change the code something that gives the result like in B-Em, although instead of "shaking" the text now has a "shadow" above it, but it's in line!
        Original          Changed
61B0    LDA #01           LDA #01
61B2    STA &FE00         STA &FE00
61B5    LDA #00           LDA #02
61B7    STA &FE01         STA &FE01
61BA    LDA #02           LDA #02
61BC    STA &FE00         STA &FE00
61BF    LDA #31           LDA #32
61C1    STA &FE01         STA &FE01
FIXSAFRASbeebem[other].zip
(19.4 KiB) Downloaded 81 times
Post by leenew » Thu Jun 11, 2015 6:05 pm
Cool beans 8)
I assume this will work on the other games that use the same system too...
Winter Wonderland, Alien from Outta Space and is there another one too?
Mind blank... :shock:
Good work anyhoo =D>
Lee.
duikkie
Post by duikkie » Wed Jul 22, 2015 3:59 pm
strange thinks are happening with my beeb and SAFRAS ( file from me)
when i turn on my beeb and *run safras , the text is not good
if i do mode 1:mode 7:*run safras text is good ???
if i ever do mode 1 after turning the beeb on the game is fine text ??
what the hell is different by cool start mode 7 and
the command mode 1:mode7 ??
