30th Anniversary BBC and Electron Collection
contribute new/updated software missing from online archives
pau1ie
Re: 30th Anniversary BBC and Electron Collection
Post by pau1ie »
Michael Brown wrote:Lords Of Time requires DTRAP to be if playing on a real BBC
I tried in b-em and in jsbeeb.
The image Lee uploaded works in b-em. I've used it to take a screenshot.
pau1ie
Post by pau1ie »
One more disc that doesn't seem to work in jbeeb or b-em is Disc059-CurseOfTheMiddleKingdomD.ssd It loads the help OK, but when you press space for the final time to load the game, it says,
Disc fault 18 at 00/00
Bad Program
leenew
Post by leenew »
Hi Paul,
Yes I highlighted this here viewtopic.php?f=51&t=11165&hilit=Help+r ... 50#p142798
Needs looking into.... anyone... :D
Lee.
Michael Brown
Post by Michael Brown »
I'm afraid the error occured because the instructions needed to be downloaded to &E00 to run and call code at &F00 to execute. It then did a *DISC, *DRIVE0, *DIR $ and then *RUN to load the game.
BITD when loads of games came my way, I did not have time to stop and spend hours changing code, so the simplest way to make games work was carried out.
It only took me about an hour to change the code to work from &1900 - so here it is.
curserelocated.zip
(12.14 KiB) Downloaded 321 times
Please let me know what you think.
Mick.
Last edited by Michael Brown on Sat Apr 28, 2018 1:14 pm, edited 2 times in total.
leenew
Post by leenew »
Mick, it doesn't work!! :wink:
Lee.
Michael Brown
:roll: Post removed
leenew
Post by leenew »
Works.
Works on the real beeb with datacentre now without having to use DTRAP :D
Lee.
Michael Brown
:D Post removed
Michael Brown
:lol: Post removed
Michael Brown
:D Post removed
Michael Brown
#-o Post removed
Michael Brown
Created in August 2016... here is Games Disc 111.
Disc111.zip
(148.08 KiB) Downloaded 51 times
The disc is called Disc111.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
The 18 games on this disc include...
Zen (STD) by Andrew Cook.
Survive! from The Micro User (5.06).
LazerChess (STD) by Andre Sihera.
World Cup Manager from Cosma/Software For All.
Strategy II: Hunt For The Bismark from ASP Software.
Startrek (R H Compendium) from R H Software.
Super Hanger (STD) from Soft Centre.
Poc-Man (Classic Arcade Games) from Ganymede Systems Ltd.
Palace Of Death by Simon Wallace.
Blockade (Unoriginal Games) (2P) by David McKeran.
Championship Boxing from Pan Books Ltd.
Skywalker from Computer & Video Games (#45).
Splat! (Golden Games) from The Micro User.
Pandemonia from Popular Computing Weekly (4.34/4.35).
Fruit Machine (AKA Bandit) from Beebugsoft.
The Quest Of Gondor (AKA Gondor) from Doctor Soft.
S.C.O.T.T. (E) from Electron Computing (#5).
Trio from Acorn Computing (12.03).
NOTE: Zen is a massive game which has to save parts of itself to disc in order to work. Some files have been left unlocked and you will need to write-enable the disc if you want to play it.
Also, LazerChess and Super Hanger allow you to save your score/position to disc.
Also, World Cup Manager has been amended to work correctly with OS 1.2.
Also, Blockade has had some of its control keys changed in order to work better with a QWERTY keyboard.
Lastly, Pandemonia is taken from a bad magazine listing. I have been able to amend the faults. The game is now as good as it can be.
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This works on Zen and LazerChess.
All original filenames have been kept where possible, but some have been changed where they conflict with the limitations of the Disc Filing System. Copy protection routines have been removed.
This disc has also been checked for *KEY related issues and is OK.
Regards,
Mick.
PS. I still require a uef image of The Quest For Gondor (just to check everything is as it should be).
Last edited by Michael Brown on Mon Jun 28, 2021 12:10 pm, edited 24 times in total.
Michael Brown
Thanks Arcadian for posting hundreds of discs. I have found a few games that have loading screens and instructions and have been able to add the extra files to my discs.
Regards,
Mick.
Last edited by Michael Brown on Sat Apr 28, 2018 1:23 pm, edited 2 times in total.
Site Admin
Post by Arcadian »
That's super news Mick, thanks for going through all the images, glad you were able to find some useful content.
Please subscribe to the ABug YouTube channel!
Michael Brown
:( Post removed
Michael Brown
Created in December 2016... here is Game Disc 112.
Disc112.zip
(243.8 KiB) Downloaded 46 times
The disc is called Disc112.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
Doomrun from The Micro User (2.05).
Artemidorus from Orchiewall Software.
The Secret Diary Of Adrian Mole (D) from Mosaic / Level 9 Computing.
Rockfall (Unoriginal Games) by David McKeran.
Invaders (Classic Arcade Games) from Ganymede Systems Ltd.
Blokkendoos (STD) from JBF Software.
3D-Maze (+ Editor) (STD) from Acorn Computing (11.07).
Empire from Shards Software.
Balloons from C.J.E.Micro's.
Fishing (Triple Decker 4) from Alternative.
Rock Pile (E) from Electron User Group (70).
Shuttle (AKA Space Shuttle) from Molimerx Limited.
Draughts (AKA Draughts Challenger) from Micro Power.
Fireman (Games Compendium B1) from Salamander Software.
Division One '85 (C) (STD) from Qual-Soft.
Minefield by Mark Bailey.
Catcher (AKA Catch) (E) from The Electron User (2.05).
Zark! by Simon Wallace.
NOTE: Artemidorus is missing its original screens from a missing DATA file. I have created some temporary screens myself. Once the original screens are found, I will add them to this disc and re-post it.
Also, The Secret Diary of Adrian Mole is a massive game which has graphical files on both sides of the disc. It has to reset the disc drive (so requires *DTRAP on a real BBC Micro with a Datacentre fitted).
Also, Blokkendoos and 3D-Maze allow you to save data to disc.
Lastly, Division One has been compacted using PRES Advanced BASIC Editor in order to allow it to work correctly from disc at &1300 instead of &E00. You can now save your game to a file called 'SG' after playing. A test file 'SG' has been saved and can be used.
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This works with 3D-Maze and Empire.
Regards,
Mick.
PS. I will re-post this disc once correct versions of Artimidorus and Division One '85 become available.
Last edited by Michael Brown on Tue Aug 03, 2021 1:16 pm, edited 23 times in total.
Post by tricky »
Great work as always.
Michael Brown
Thanks Tricky.
BTW How is Phoenix coming on.
regards,
Mick.
Post by tricky »
I haven't done anything on it for quite a while now.
I'm still annoyed at myself for not requiring the drawing code completely as now there is flicker at the top of the screen.
I'll try and make an effort over the holidays if not before.
Michael Brown
Created in January 2017... here is Game Disc 113.
Disc113.zip
(147.96 KiB) Downloaded 50 times
The disc is called Disc113.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
Fruits! from The Micro User (6.10).
System 15000 from AVS / Craig Communications.
Battle Of Britain (STD) from Design People Software.
Tennis (Classic Arcade Games) from Ganymede Systems Ltd.
Mexico '86' (STD) from Qual-Soft.
Islandia (2P) from Red Shift Ltd.
Aquaman by Anthony Bartram.
Espionage from Modular Resources.
Jet-Pack Rescue from The Micro User.
Castle Blacknight from Retro Software.
Holey Floors from Arrowsoft.
Dodgems by ???
Lunar Run by Chris Nixon.
Photon Cycle Duel from Laserbug (Issue 11).
Alphabet Soup (AKA ABC Puzzle) (Games Compendium B1) from Salamander Software.
Battleships (2P) by Mark Gidley.
Beebtrek from Software For All.
Birds by ???
NOTE: Battle Of Britain and Mexico '86' are the disc versions and you can save your score/position to disc.
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This works on Battle Of Britain and Islandia.
Regards,
Mick.
Last edited by Michael Brown on Mon Jun 28, 2021 12:15 pm, edited 21 times in total.
Michael Brown
*KEY corruption can occur in High Score tables or when asked questions.
It has come to my attention that some games feature either *KEY OLD RUN commands or store new code at &B00 making the function keys do all sorts of weird things when pressed on certain games.
Not all games are affected and some have *FX225 (or LDA #&E1) commands added by authors to prevent this.
Some games have had the following done to them...
1) *FX225 command adding to the basic loader.
2) LDA #&E1 adding to the downloader in the final part.
3) Removal of *KEY 0 OLD RUN command and alternative coding used instead.
4) Removal of *KEY 0 *LOAD (filename) and better coding used instead.
Hopefully, this will sort the problem and make playing the games an even better enjoyment.
If anyone has any of these problems with the games on these discs, then please let me know so I can sort them.
Regards,
Mick.
Michael Brown
:oops: Post removed
Michael Brown
=D> Post removed
Michael Brown
:| Post removed
Michael Brown
:lol: Post removed
Michael Brown
:roll: Post removed
Michael Brown
:shock: Post removed
PitfallJones
Post by PitfallJones »
Hi Mick,
Could you give a link to download the latest versions, thanks, I'm not sure where they are posted - also do the disks have any method of identifing their version - like a date or number in the catalog?
Actually do you think it would be possible to just zip the whole lot up into a single file and just update that as you improve them?
It would be about 14MB in size - nothing these days!
PJ
Michael Brown
Hi PJ
Sorry about all the re-posts.
As it is, all the corrected discs are contained within the many pages of this topic.
I have always included a new post (which should be the last thing posted) each time a disc has been amended to alert everyone to the changes.
Hopefully, my discs will now only be re-posted when faults/bugs, inlay instructions or missing loading screens are found.
Regards,
Mick.
Post by sydney »
Hi Mick.
I was going to nominate Hyper Sports for the high score challenge but it crashes after completing the long horse event with a black screen and 'Not found' followed by 'Bad Program' and a > prompt.
