AMX Mouse Software
AMX Mouse Software
Here's a selection of software for use with the AMX mouse:
- AMX 3D Zicon
- AMX Database
- AMX Desk
- AMX Paintpot
I also have the originals of:
- AMX Super Art
- AMX Art
- AMX Pagemaker
- AMX Pagemaker Fonts
but due to protection have not been dumped.
- AMX 3D Zicon
- AMX Database
- AMX Desk
- AMX Paintpot
- AMX Super Art
- AMX Art
- AMX Pagemaker
- Attachments
- AMX Software.zip
- (109.24 KiB) Downloaded 362 times
Re: AMX Mouse Software
Thank you Pernod. I will have a look....fingers crossed!
Ah wow AMX paintpot......cor that I haven't seen in a long time
Jason and I converted a couple of ps2 mice at the ABug meet at the weekend so this is a good opportunity to test them out fully! Will I need the rom or does the software handle the mouse automatically?
The previous dumps were all DSD but both sides were identical, so redumped them all as SSD, and added the following:
- AMX Art - AMX Super Art - AMX Pagemaker
Unable to redump 3D Zicon as disc has gunged my drives
- Attachments
- AMXSuperArt.zip
- (36.09 KiB) Downloaded 228 times
- AMXPaintpot.zip
- (22.51 KiB) Downloaded 191 times
- AMXPagemaker_FontDisc.zip
- (30.64 KiB) Downloaded 185 times
- AMXPagemaker.zip
- (34.26 KiB) Downloaded 203 times
- AMXDesk.zip
- (27.33 KiB) Downloaded 197 times
- AMXDatabase.zip
- (17.69 KiB) Downloaded 182 times
- AMXArt.zip
- (17.62 KiB) Downloaded 200 times
You will also need the ROM. I'd recommend at least version 3.31, see http://mdfs.net/System/ROMs/Pointer/sydney wrote:Jason and I converted a couple of ps2 mice at the ABug meet at the weekend so this is a good opportunity to test them out fully! Will I need the rom or does the software handle the mouse automatically?
Cheers! I gave i a try earlier today but the master didn't like the ROM I'd chosen. I'll give the ROM you mentioned tomorrow.
- Contact:
Hi guys,
Has anyone had any luck with the disk images supplied above? AMX SuperArt just goes into an infinite load-and-reboot loop, and AMX PageMaker fails with a bad command error.
(Using BeebEm to emulate a Master 128, with AMX ROM 361 from JGH's site installed.)
These versions are BBC only, there is a Master version of Super Art at viewtopic.php?f=7&t=2163&p=15522. For PageMaker you'll need the ROMs.
- Contact:
Thanks for that!
If I load the AMX Super Art Master.ssd disk with the same config (Master 128, AMX ROM 3.61, AMX ticked on in BeebEm menu) then I get an error of "Pointer switched off at line 2025". Have you seen that before?
No, because I followed the instructions onscreen:nudelooney wrote:If I load the AMX Super Art Master.ssd disk with the same config (Master 128, AMX ROM 3.61, AMX ticked on in BeebEm menu) then I get an error of "Pointer switched off at line 2025". Have you seen that before?
*BASIC
*| Master BBC Boot File
*| If roms loaded then chain !MENU
X%=&70:Y%=0:A%=64:!&70=-1:CALL &FFF1
IF !&70<>-1 THEN CHAIN "!MENU"
*| Load in Roms
*SRLOAD RomI 8000 W Q
*SRLOAD Support 8000 X Q
*SRLOAD RomD1 8000 Y Q
*SRLOAD RomD2 8000 Z Q
*| Press <CTRL> <BREAK>
*| followed by *POINTER ON
*| and <CTRL> <BREAK> again
- Contact:
I don't get those instructions. For me, it goes as far as the "CHAIN "!MENU"" line, then I get the error about the Pointer being switched off.Pernod wrote:No, because I followed the instructions onscreen:nudelooney wrote:If I load the AMX Super Art Master.ssd disk with the same config (Master 128, AMX ROM 3.61, AMX ticked on in BeebEm menu) then I get an error of "Pointer switched off at line 2025". Have you seen that before?Code: Select all
*BASIC *| *| Master BBC Boot File *| *| If roms loaded then chain !MENU X%=&70:Y%=0:A%=64:!&70=-1:CALL &FFF1 IF !&70<>-1 THEN CHAIN "!MENU" *| *| Load in Roms *| *SRLOAD RomI 8000 W Q *SRLOAD Support 8000 X Q *SRLOAD RomD1 8000 Y Q *SRLOAD RomD2 8000 Z Q *| *| Press <CTRL> <BREAK> *| followed by *POINTER ON *| and <CTRL> <BREAK> again
- Contact:
Ah, sorted it! I was making a point of installing the ROM into a slot with BeebEm (because that's what I remember doing for real when I had SuperArt on a model B many years ago) which was confusing the later *SRLOAD stuff. I didn't realise that the Master version just had the ROMs as images to go straight into sideways RAM.
All working now - thanks for your patience!
- CMcDougall
- Contact:
found this rom in a poorly beeb b, might be of some use....
on white sticker printer in red AMX MAX16K
shows on *roms as: (SL) MAX V1.2
and *H. : MAX Version 1.2 By Peter Elliot
- Attachments
- AMXmax12.zip
- ssd
- (11.54 KiB) Downloaded 162 times
Here's AMX Utilities.
- Attachments
- AMXUtils1.2.zip
- (35.3 KiB) Downloaded 167 times
Does anyone have AMX XAM? I believe that is the only package that we don't have to complete the set.
Edit: Added scans of discs above.
Anyone have anything to add to this collection?
My disc images of Pagemaker are actually Pagemaker+ and only work with the Pagemaker+ 1.7 ROMs. I have ROMs for Pagemaker 1.0 and Pagemaker+ 1.3 but no floppies to go with them. Also still looking for floppies for Stop Press (Beeb and Elk) and XAM.
- billcarr2005
- Contact:
STOP PRESS
System Disc
Font Disc
Master Downloader Disc
I've also got Super Art V3.12, V3.20d, V3.31 and V3.61
Also Pagemaker 1.4+ and 1.5+
- Attachments
- STOP PRESS.zip
- AMX STOP PRESS
- (103.66 KiB) Downloaded 84 times
Thanks for those, but can't get it to run. Tried in both a B with ROMs loaded and a Master using the Master Downloader, both give Bad Command at the Control Menu trying to issue *pMouse. What am I missing?billcarr2005 wrote: ↑Mon Nov 12, 2018 10:23 amSTOP PRESS
System Disc
Font Disc
- billcarr2005
- Contact:
I'm not sure...
After the prolonged title sequence "TITLES", I'm prompted to press any key for mouse/keyboard control and I'm then presented with the main menu "MENU"
*pMOUSE from the > prompt has no issues either
AMX STOP PRESS 1.9
(C) Tecnation 1984-1987
It's is quite an old (forum) subject but I'm trying to collect as much AMX software/ROMs as I can.
At the moment I have a lot myself and found also a lot spread around on the forum.
I would like archive all the versions that where released (or as much as I can find) of the AMX software and put them on my site as a complete overview, with the compatibility of the several machines.
So is there anyone who can help me with the following manuals?
manuals :
- AMX Zicon
- AMX Database
- AMX Stop Press - I found a manual on eBay (https://www.ebay.co.uk/itm/AMX-Stop-Pre ... Sw9-ZeT62W) with the complete bundled software, but wondered if someone can help me out on this one
In my rom collections I also found Mouse Support ROM V4 and V5.
When loaded in SWR (or as ROM en BeebEm) and type *H. they appear. But a command like *POINTER ON gives an error.
Does anyone know what kind of versions they are?
Koen
manuals :
- AMX Zicon
- AMX Database
Billcarr, do you still have the ROM dumps of te versions V3.12, V3.20d, V3.31? Could you send them here so I can archive them?billcarr2005 wrote: ↑Mon Nov 12, 2018 10:23 amSTOP PRESS
System Disc
Font Disc
Koen
- Attachments
- SuperArtSupport-M5.01.rom
- (16 KiB) Downloaded 39 times
- SuperArtSupport-M4.01.rom
- (16 KiB) Downloaded 33 times
These are Master only, and are usually loaded into SWR from floppy. There's a link to Super Art for Master earlier in this thread.
Aaaah that helps a lot. Had only bits and parts of these images!!
Thanks.
Strangely enough is that the mouse support image that is used works perfect in BeebEm, but not on my Master.
When all loaded and typed *POINTER ON and giving a ctr+break, the machine hangs with only an option to enter a star command.
So I type *B. and do PRINT ~PAGE it gives 0.
so I set the page to F00 manually and press break again, and again the only option is to enter a * command.
After a view times (sometimes I use CTRL+A+BREAK to force an ADFS start) I enter Basic as normal in page F00 and the mouse works good.
The same happens when I switching of the pointer. (using *POINTER OFF) I have to do the same as above but then setting the page to E00 a view times.
Is there a known incompatibility with AMX and some products?
UPDATE : I posted this question earlier but not solved yet......
Happy with my BBC Master
www.mybbcmaster.nl
www.mybbcmaster.nl
- Contact:
I got a manual, 2 disks and 2 ROMs for Watford Stop Press with a Beeb I picked up today. The manual has a different cover from the one in the eBay listing, but it says "AMX STOP PRESS" in the corner of each page, and it's 93 pages long.Yrrah2 wrote: ↑Tue Jun 30, 2020 11:14 am- AMX Stop Press - I found a manual on eBay (https://www.ebay.co.uk/itm/AMX-Stop-Pre ... Sw9-ZeT62W) with the complete bundled software, but wondered if someone can help me out on this one
(The ROMs have handwritten labels saying they're ver 1.9. Haven't got round to taking copies of them or the disks yet. Still trying to get the machine to work
--Tom
Sounds promising!tom_seddon wrote: ↑Tue Jun 30, 2020 9:50 pmI got a manual, 2 disks and 2 ROMs for Watford Stop Press with a Beeb I picked up today. The manual has a different cover from the one in the eBay listing, but it says "AMX STOP PRESS" in the corner of each page, and it's 93 pages long.
(The ROMs have handwritten labels saying they're ver 1.9. Haven't got round to taking copies of them or the disks yet. Still trying to get the machine to work)
--Tom
It seems there have been 2 versions of Stop Press 1.9. The ROM (the ones you have) and the Disc version, found here on the forum.
The manual I have is for PageMaker and is also 93 pages long. So I'm wondering what the difference is going to be. (except for the name)
Let me know your findings of the version you have.
Koen
www.mybbcmaster.nl
www.mybbcmaster.nl
- Contact:
Scans of the Watford Stop Press manual here: http://ffe3.com/beeb/WafordStopPressManual.zip
ZIPs of the ROMs and disks I've got attached.
The two ROMs I've got are different from the images on Bill's disk, but I think the ROMs look more sensible. The differences are in STOPPR1: (- is the ROM, + is the disk)
STOPPR2 and the contents of the system disk are identical to Bill's copies.
Various differences in the font disk, all in $.DEMPAGE.
--Tom
00000FD0: A5 0D E5 09 85 11 A5 0A 38 E5 0E 85 12 A5 0B E5 ........8.......
-00000FE0: 0F 85 13 A2 24 A0 0C 20 6E BD AD 53 19 C9 01 F0 ....$.. n..S....
+00000FE0: 0F 85 13 A2 24 A0 0C 20 6E BD A9 53 19 C9 01 F0 ....$.. n..S....
00000FF0: 0A C9 03 D0 03 4C 59 90 4C B7 90 A5 0C 18 65 12 .....LY.L.....e.
a2 24 ldx #$24
a0 0c ldy #$0c
20 6e bd jsr $bd6e
ROM DISK
ad 53 19 lda $1953 a9 53 lda #$53
c9 01 cmp #$01 19 c9 01 ora $01c9,y
f0 0a beq xxx f0 0a beq xxx
c9 03 cmp #$03
d0 03 bne xxx
@@ -697,3 +697,3 @@
00002B80: 6B B7 68 85 46 68 85 45 68 85 44 68 85 43 20 F9 k.h.Fh.Eh.Dh.C .
-00002B90: BA C0 FF F0 17 A2 24 A0 33 20 6E BD A5 35 38 E5 ......$.3 n..58.
+00002B90: BA C0 FF F0 17 A0 24 A0 33 20 6E BD A5 35 38 E5 ......$.3 n..58.
00002BA0: 45 85 35 A5 36 E5 46 85 36 4C D9 AA 4C BF AA A2 E.5.6.F.6L..L...
85 43 sta $43
20 f9 ba jsr $baf9
c0 ff cpy #$ff
f0 17 beq xxx
ROM DISK
a2 24 ldx #$24 a0 24 ldy #$24
a0 33 ldy #$33 a0 33 ldy #$33
20 6e bd jsr $bd6e 20 6e bd jsr $bd6e
--Tom
- Attachments
- WatfordStopPress.zip
- (84.93 KiB) Downloaded 33 times
Hi Tom,
Thanks!
Good to have a complete font disc, including the demo page.
Had the demo page, but not in this 'official' combination.
And I'll have a good look at both manuals. If there is a 1.7 and 1.9, I don't think its a name only that has changed.
The difference you show me with the 2 version, is a bit abracadabra to me (or greek to me).
In the numbers and code I see some differences, but can't make out what is better/sense or not.
Koen
Thanks!
Koen
www.mybbcmaster.nl
www.mybbcmaster.nl
On a 1986 AMX advert I have found it lists a disc called AMX Mind Games. Has anyone used this?
BBC Master 512, Music 5000, Gotek Drive.
Nigel,
On your link for Roms I am unable to download the PageMaker roms.
Dave C
Dave C
It's currently missing, as is AMX XAM.
Pagemaker ROMs can be found at http://mdfs.net/System/ROMs/DTP/ or http://www.kkeevel.nl/mybbcmaster/other_amx_mouse.htmlDave C wrote: ↑Thu Jul 23, 2020 7:38 pmNigel,
Dave C
- DutchAcorn
- Contact:
