Tape CSW files -not working on other sites
contribute new/updated software missing from online archives
Re: Tape CSW files -not working on other sites
Post by CMcDougall » Tue Oct 15, 2019 12:28 pm
I beleave I have found where the problem lies with this its a bug in makeuef 2.3 and HQ UEF files, which means any HQ UEF made with makeuef Ver 2.3 is not 100%
^might have a micro second missing from lead in, but mine actually work, so don't care! :D
Typeast Exercises Writex - Carewell Computers 1983
media
sideA was bad quality, but worked! sideB was good quality, but did not work! #-o
included CSW, not working, might work with BackToLife to play to actual machine :?
files :
Found :    TYPEASY 01	Checksum ok, last block flag
Found :          ? 00	Checksum ok, last block flag
Found :        ??? 26	Checksum ok, last block flag
Found :     BLOCK0 04	Checksum ok, last block flag
Found :     BLOCK1 05	Checksum ok, last block flag
Found :     BLOCK2 05	Checksum ok, last block flag
Found :     BLOCK3 04	Checksum ok, last block flag
Found :     BLOCK4 05	Checksum ok, last block flag
Found :     BLOCK5 05	Checksum ok, last block flag
Found :     BLOCK6 08	Checksum ok, last block flag
Found :     WRITEX 0C	Checksum ok, last block flag
typeastExercisesWritex-carewellComputers1983Acsw.csw
csw , not working, might work BackToLife to actual machine
(266.34 KiB) Downloaded 20 times
typeastExercisesWritex-carewellComputers1983AhqUef.uef
HQuef
(15.18 KiB) Downloaded 20 times
typeastExercisesWritex-carewellComputersA1983.uef
uef
(13.98 KiB) Downloaded 20 times
vanekp
Post by vanekp » Tue Oct 15, 2019 8:11 pm
I hear the lead-ins are very short on the 1st block and its a hq uef and uses dummy bites which explains the very short lead in as Makeuef ver 2.3 contains the dummy bite block bug see viewtopic.php?p=238965#p238958 hopefully one of the days it will get fixed :)
It's not a case of a ms missing its that the dummy byte is sitting right up against the data block and causes problems, as its seen as being part of the data block instead of being seen as a separate dummy byte.
Peter.
Post by CMcDougall » Sat Nov 23, 2019 4:07 pm
Hooked On Numbers - Acornsoft / ICL 1983
EDIT: fix below :D
Post by CMcDougall » Tue Nov 26, 2019 7:41 pm
just re done, this time using a boost on last block, & right channel only :D
HookedOnNumbers-AcornsoftICL1983csw.csw
csw
(107.49 KiB) Downloaded 19 times
HookedOnNumbers-AcornsoftICL1983hq.uef
hq
(6.39 KiB) Downloaded 18 times
HookedOnNumbers-AcornsoftICL1983uef.uef
uef
(6.1 KiB) Downloaded 20 times
Post by CMcDougall » Fri Dec 06, 2019 8:48 pm
Mr. Ee - Micro Power 1984
recorded once on each side
*T.
PAGE=&E00
CH.""
:D
MrEE-MicroPowerUEF.uef
uef
(11.83 KiB) Downloaded 16 times
MrEE-MicroPowerHQ.uef
uefHQ
(12.21 KiB) Downloaded 18 times
MrEE-MicroPowerCSW.csw
csw
(146.46 KiB) Downloaded 19 times
Post by CMcDougall » Sun Dec 08, 2019 11:50 am
Jet Power Jack - Micro Power 1983
recorded twice on sideA, blank sideB
*T.
CH.""
JetPowerJack-MicroPower1983csw.csw
csw
(262.67 KiB) Downloaded 18 times
JetPowerJack-MicroPower1983hq.uef
uefHQ
(9.53 KiB) Downloaded 18 times
JetPowerJack-MicroPower1983twice.uef
uef
(8.64 KiB) Downloaded 17 times
Post by CMcDougall » Mon Dec 09, 2019 10:07 pm
Jet Set Willy 1 & 2 - Tynesoft 1986
media
sideA is bbc version, sideB is electron version on Willy1, vice versa Willy2
JSW1 was on old acornpreservation site, now gone, but JSW2 NEVER Before :shock:
*T.
PAGE=&E00
CH.""
JetSetWilly2-Tynesoft1986bCSW.csw
beeb csw
(163.38 KiB) Downloaded 19 times
JetSetWilly2-Tynesoft1986Bhq.uef
beeb HQuef
(17.41 KiB) Downloaded 18 times
JetSetWilly2-Tynesoft1986b.uef
beeb uef
(16.91 KiB) Downloaded 19 times
JetSetWilly2-Tynesoft1986eCSW.csw
elk2 csw
(155.38 KiB) Downloaded 19 times
JetSetWilly2-Tynesoft1986eHQ.uef
elk2 HQuef
(17.54 KiB) Downloaded 18 times
JetSetWilly2-Tynesoft1986eUEF.uef
elk2 uef
(17.07 KiB) Downloaded 18 times
JetSetWilly-Tynesoft1986eCSW.csw
elk CSW
(157.9 KiB) Downloaded 23 times
JetSetWilly-Tynesoft1986eHQ.uef
elk uefHQ
(17.33 KiB) Downloaded 18 times
JetSetWilly-Tynesoft1986e.uef
elk UEF
(16.87 KiB) Downloaded 18 times
vanekp
Post by vanekp » Tue Dec 10, 2019 9:10 pm
thanks :D
Peter.
Post by lurkio » Wed Dec 11, 2019 1:10 pm
=D> =D> =D>
Post by CMcDougall » Thu Feb 13, 2020 7:52 pm
The Life Of Repton - Superior 1987 BBC version
mediaA
mediaB
another one not done EVER !! 8)
TheLifeOfRepton-Superior1987aUEF.uef
a UEF
(30.35 KiB) Downloaded 19 times
TheLifeOfRepton-Superior1987Ahq.uef
a HQ
(31.59 KiB) Downloaded 15 times
TheLifeOfRepton-Superior1987aCSW.csw
a CSW
(467.92 KiB) Downloaded 16 times
TheLifeOfRepton-Superior1987bUEF.uef
b uef
(30.74 KiB) Downloaded 14 times
TheLifeOfRepton-Superior1987Bhq.uef
b HQ
(31.64 KiB) Downloaded 17 times
TheLifeOfRepton-Superior1987bCSW.csw
b CSW
(364.92 KiB) Downloaded 17 times
Multiwizard
Post by Multiwizard » Thu Feb 13, 2020 8:32 pm
=D> :D =D>
Post by CMcDougall » Sat Feb 15, 2020 8:37 pm
^Thanks Wim :D :wink:
& another:
Repton Thru Time - Superior 1988 BBC version
media a
media b
don't ask why sideB never converted into a basic UEF !! :?
enjoy 8)
ReptonThruTime-Superior1988Acsw.csw
csw
(519.47 KiB) Downloaded 15 times
ReptonThruTime-Superior1988Ahq.uef
HQuef
(33.31 KiB) Downloaded 17 times
ReptonThruTime-Superior1988Auef.uef
uef
(32.03 KiB) Downloaded 14 times
ReptonThruTime-Superior1988Bcsw.csw
CSW
(408.06 KiB) Downloaded 15 times
ReptonThruTime-Superior1988Bhq.uef
HQuef
(33.19 KiB) Downloaded 14 times
Post by CMcDougall » Sun Feb 16, 2020 9:44 pm
Countdown To Doom - Acornsoft 1982 version 3.2
media
enjoy 8)
countdownToDoom-Acornsoft1982CSW.csw
csw
(253.21 KiB) Downloaded 14 times
countdownToDoom-Acornsoft1982HQ.uef
uefHQ
(19.25 KiB) Downloaded 15 times
Post by CMcDougall » Mon Feb 17, 2020 8:55 pm
WordWise - Computer Concepts - Typing & Example 1982
recorded twice on each side
boring, I know :lol:
WordWiseTyping-computerConcepts1982bCSW.csw
(98.13 KiB) Downloaded 13 times
WordWiseTyping-computerConcepts1982bHQ.uef
(3.54 KiB) Downloaded 15 times
WordWiseTyping-computerConcepts1982aCSW.csw
(139.43 KiB) Downloaded 13 times
WordWiseTyping-computerConcepts1982aUEF.uef
(5.51 KiB) Downloaded 14 times
WordWiseTyping-computerConcepts1982aHQ.uef
(5.94 KiB) Downloaded 15 times
WordWiseTyping-computerConcepts1982bUEF.uef
(3.18 KiB) Downloaded 15 times
Post by CMcDougall » Mon Mar 16, 2020 8:40 pm
Kingdom Of Hamil - Acornsoft 1983 version 1.1 :
media
KingdomOfHamil-Acornsoft1983csw.csw
csw
(232.97 KiB) Downloaded 12 times
KingdomOfHamil-Acornsoft1983hq.uef
hq
(19.14 KiB) Downloaded 12 times
KingdomOfHamil-Acornsoft1983uef.uef
uef
(18.49 KiB) Downloaded 16 times
Post by CMcDougall » Wed Apr 22, 2020 9:30 pm
The Way of The Exploding Fist - Melbourne House - electron version :1st release (not archived before... :D )
both sides worked !! :shock:
WayOfTheExplodingFist-Melbourne1986elkAcsw.csw
csw A
(143.26 KiB) Downloaded 9 times
WayOfTheExplodingFist-Melbourne1986elkAhq.uef
hq A
(14.34 KiB) Downloaded 14 times
WayOfTheExplodingFist-Melbourne1986elkBcsw.csw
csw B
(172.4 KiB) Downloaded 13 times
WayOfTheExplodingFist-Melbourne1986elkBhq.uef
hq B
(14.53 KiB) Downloaded 11 times
