Ample DCT files
contribute new/updated software missing from online archives
pau1ie
Ample DCT files
Post by pau1ie »
I have some files which were downloaded from Ample DCT.
Ample DCT is a Music 500/5000 viewdatabase (similar in style to
PRESTEL), and can be called anytime on (0348) 239944. A library of
worksheets, and music telesoftware and other facilities are all offered
FREE of charge.
This transcribed from a dot matrix printed sheet. Turns out OCR is rubbish with dot matrix text. I have checked it carefully so hope it is OK. I can upload the scanned images if anyone wants to double check.
First up are a couple of worksheets about composition on the Music 5000. I don't have sheet 2, this contains 1 and 3.
compose.zip
(5.17 KiB) Downloaded 67 times
pau1ie
Re: Ample DCT files
Post by pau1ie »
This one looks like a screen print of a page from the Ample DCT bulletin board. It's short, so I just pasted it below.
  AMPLE DCT              D6.T.37b     0p
 Add the following NUCLEUS words:
"var" [ GVAR ]
"wait" [ REP(QTIME -200 £< )UNTIL(IDLE
)REP ON var £! ]
       % Change -200 to suit
"next" [ REP(var £?)UNTIL(IDLE)REP
 At the end of the RUN word, add:
next $2 """jukebo""LOAD RUN"
 ...where jukebox is the file you want
 to chain. (Change this to whatever
 file you want.)
 At the beginning of the music, insert:
OFF var £!
 At the end of the last music part, add:
wait
   0 Hints & Tips               £ More
pau1ie
Re: Ample DCT files
Post by pau1ie »
Here are a couple of worksheets about making waveforms for the Music 500 by Alistair Johnson
waveforms-500.zip
(2.93 KiB) Downloaded 63 times
pau1ie
Re: Ample DCT files
Post by pau1ie »
AMPLE Nucleus Programming Words
This worksheet describes the advertised extra programming words in AMPLE
Nucleus and lists those that are the same as in AMPLE BCE. It is extracted from
the forthcoming "AMPLE Nucleus Programmer's Guide" by Hybrid Technology.
NucleusWords.zip
(4.21 KiB) Downloaded 60 times
pau1ie
Re: Ample DCT files
Post by pau1ie »
Here is an article about the DCT Viewdata service.
DCT-Viewdata.zip
(1.55 KiB) Downloaded 58 times
pau1ie
Re: Ample DCT files
Post by pau1ie »
Some more files:
  • Ample DCT Maestro: AMPLE DCT is reorganising its service to conform with the present copyright laws
  • Hints and Tips: A couple of screen grabs from the hits and tips section of the bulletin board
  • Auto Chain Utility: Allan Gardner wrote and documented a utility to chain one program into another.
AutoChain.zip
(1.33 KiB) Downloaded 61 times
HintsTips.zip
(848 Bytes) Downloaded 56 times
DCT-maestro.zip
(1.03 KiB) Downloaded 56 times
pau1ie
Re: Ample DCT files
Post by pau1ie »
This is the last one:
                  PRESET ENVELOPES AND WAVEFORMS
               For the Hybrid Music 500 Synthesizer
       Worksheet compiled by Alistair Johnston for AMPLE DCT
    (Based on an Application Note supplied by Hybrid Technology)
PresetEnvelopes.zip
(1.69 KiB) Downloaded 57 times
