The Taroda Scheme (BBC version)
contribute new/updated software missing from online archives
billcarr2005
Post by billcarr2005 »
The disk / code protection used is detailed here
viewtopic.php?f=2&t=9061&p=195316#p195316
The Taroda Scheme.zip
(37.62 KiB) Downloaded 179 times
Re: The Taroda Scheme (BBC version)
Post by lurkio »
Thanks, BillC!
Just a minor note: the .SSD won't work if you've got the PRES Advanced BASIC Editor ROMs installed because they intercept the command *B, which clashes with the name of a machine-code file on the .SSD which seems to be run with the same command, *B!
Post by CMcDougall »
Great job, glad you got the disc, & forced it to copy =D> =D> =D>
billcarr2005
lurkio wrote:Thanks, BillC!
I always find it's best practice to disable any unnecessary ROMs when loading up any software, for maximum compatibility.
You could also argue it's bad practice to just have *B rather than */B or *RUN B in the code, I assume they did this to make it harder to scan through the data and see the obvious and/or to save space.
However it's fairly trivial to change the filename and where it's OSCLI'd from by hex-editing the SSD - offset &18 (the catalogue) and &16EA6 (it's position in the file BOOT, &ACE when the file is *LOADed)
Post by lurkio »
billcarr2005 wrote:it's fairly trivial to change the filename and where it's OSCLI'd from by hex-editing the SSD - offset &18 (the catalogue)
That's the wrong catalogue entry! It's the one at offset &08 that you need to edit.
billcarr2005 wrote:and &16EA6 (it's position in the file BOOT, &ACE when the file is *LOADed)
Thanks.
Have you got any documentation/instructions for the game?
billcarr2005
lurkio wrote: Have you got any documentation/instructions for the game?
Instructions Side 1
Instructions Side 1
Instructions Side 2
Instructions Side 2
Advertisement
Advertisement
Post by lurkio »
billcarr2005 wrote:[instructions]...
Thanks!
Btw, I assume the files O.B and O.Boot can be deleted? And an instructions program added? Does it matter which precise sectors the files occupy?
billcarr2005
Yes, O.B and O.Boot are the original, unmodified versions of the files, they can safely be deleted.
I'm fairly certain that R/H1 can be removed too... this does contain code, but refers to the protection and the file originally was longer and further data occupied the "bad" tracks which couldn't be read under normal DFS conditions (and just contained E5 anyway)
There shouldn't be any direct access of the disk with OSWORD&7F, so files are able to be moved around too :)
Post by lurkio »
billcarr2005 wrote:Yes, O.B and O.Boot are the original, unmodified versions of the files, they can safely be deleted.
Done and done.
I've typed up the instructions, put them on an .SSD together with the game itself, and uploaded it to bbcmicro.co.uk:
:idea:
