The Oregon Trail (1978)
Post by lurkio » Sun Oct 22, 2017 10:58 pm
For some reason, I recently allowed Lee to badger me into porting Jimmy Maher's listing for the 1978 version of the classic educational text-only survival-simulation game The Oregon Trail from HP BASIC to BBC BASIC:
I wanted to try and make as few changes to Maher's listing as possible, so I had to use MODE 3, for its 80-column text display. (However, because there's less RAM available for BASIC programs in MODE 3, I did end up having to compress the main game listing using the good old Pack routine in the PRES Advanced BASIC Editor ROMs. If I hadn't, the program would have run on a Master 128 but would have been too big to run on a Model B.)
Here's some background on the program from a 1978 issue of Creative Computing magazine, where the Oregon Trail listing was first published, I believe:
By the way, this is the pre-dysentery version of the game.
:idea:
Re: The Oregon Trail (1978)
Post by leenew » Mon Oct 23, 2017 10:28 am
Well done Lurkio =D>
Was this trickier than expected??
Why have you left it as Beta? - Do you expect there to be bugs on yonder trail?
I have to say, for such a simple game, it definitely has *something* that makes you want to succeed and have another go.
I am in bed feeling ill at the moment, so I don't miss the dysentery in the game. :-&
Lee.
Post by lurkio » Mon Oct 23, 2017 10:37 am
leenew wrote:Was this trickier than expected??
Well, the program was certainly larger than I thought it would be. (Hence the compression.)
leenew wrote:Why have you left it as Beta? - Do you expect there to be bugs on yonder trail?
I haven't thoroughly tested all the possible ways to die. Maybe other people can have a go..?
leenew wrote:I have to say, for such a simple game, it definitely has *something* that makes you want to succeed and have another go.
Agreed! I think it's partly because there's a clear time-limited goal, and partly because it's based on real historical events, which can create an atmosphere and draw you in (if you use (a lot of) your imagination!).
Commodore
Post by Commodore » Mon Oct 23, 2017 9:20 pm
Sounds interesting Lurkio. I'll probably have ago when I've finished fiddling with GAC, or maybe for some respite....
Post by lurkio » Mon Oct 23, 2017 9:39 pm
Commodore wrote:Sounds interesting Lurkio. I'll probably have ago when I've finished fiddling with GAC, or maybe for some respite....
Make sure you stock up on those "Miscellaneous Supplies".
:D
Commodore
Post by Commodore » Mon Oct 23, 2017 10:56 pm
Sounds ominous! I'm sure Oregon was pretty tough in the 1800s. I read they had some Bubonic Plague in 2010, so goodness knows what it was like way back then!
