Misc BBC/Electron Roms, for checking
contribute new/updated software missing from online archives
Wouter Scholten
Re: Misc BBC/Electron Roms, for checking
Post by Wouter Scholten »
Arcadian wrote:20180119_032534.jpg
Those contain more roms to be dumped?
Site Admin
Post by Arcadian »
Yup ... just one (32k) ROM to dump though (2 copies of the same thing) ... brought it with me today to the ABug meetup for dumping ... I think you'll be interested in the contents ... ;)
Site Admin
Post by Arcadian »
Here are snaps of the docs ... Phill HS successfully dumped the ROM earlier today, will post the image shortly ...
Wouter Scholten
Arcadian wrote:Here are snaps of the docs ... Phill HS successfully dumped the ROM earlier today, will post the image shortly ...
hmm, it's interesting that it's provided for the master, was it master-only? (then perhaps 65c02 opcodes were used, I've not checked the other ch200/chadfs rom dumps for this yet)
Site Admin
Post by Arcadian »
No idea if it's Master only.
Here's the ROM dump.
Does it look any different from the existing dump?
Challenger DFS-ADFS.zip
(23.21 KiB) Downloaded 110 times
Wouter Scholten
Arcadian wrote:No idea if it's Master only.
I did a bdiff and it's exactly the same as rom 527 (which is the same as roms 525+526), so, this needs looking into as there are now multiple rom images that are the same and it's inconceivable that if any bits unprogrammed (as happens slowly with eproms over time) that that would happen in the same way in each eprom.
So perhaps it's master-only. I will have a look soon if there are 65c02 opcodes.
tom_seddon
Post by tom_seddon »
Wouter Scholten wrote:
Sun Jan 21, 2018 3:05 pm
(Note: I'm calling the first 16K (DFS half) CH200, and the second 16K (ADFS half) CHADFS.)
Regarding the uninitialised RAM - note that page 3 of the docs, such as they are, says it's CHADFS that handles the formatting of the RAM disc, so it looks like this sort of thing is to be expected if you're using CH200 only.
The wording of the rest of the docs rather implies that the whole package is Master only, what with the references to *UNPLUG and links on the Master motherboard, and the fact it's supplied on a 32K EPROM. And the ROM switch code at the end of CHADFS uses PHX/PHY/PLX/PLY, so clearly that half *is* Master-only :( But there's nothing obviously Master-specific in CH200 that I've found yet, and - RAM clearing aside, which seems to be fixed by formatting the RAM disc and doing *CONFIG 0=0 1=1 2=2 (etc.) - it seems to run ok on my Beeb.
Anyway, I've started on a disassembly of CH200, and I've also installed it in my Beeb, so if there's anything problematic, I'll probably find it eventually one way or the other! First version of the disassembly to come on GitHub at some point probably fairly soon... just need to find all of the tables and annoying inline strings (of which there are several different types). I think I'm nearly there though.
Doesn't look like there's obviously a lot of free space, and inline strings will make it a pain, but perhaps there'll be some way of squeezing in a Challenger RAM clear + RAM disc format on startup? :)
--Tom
tom_seddon
Tue Jan 09, 2018 11:44 am
So the Challenger 3 DD BIOS v1.01 + DDCPM v1.01.fdi is the one I was curious about... (esp. because in my disassembled version, there was an issue with FORMAT not working sometimes depending on moving sections of code around and I must just have overlooked some small detail)
Is your disassembly available anywhere? I'd be interested in looking at it... might help with the 2.00 disassembly.
Wed Jan 10, 2018 9:01 pm
ADFS hangs with a bad sum for channel 48 when both are plugged in (when selected with e.g. *ADFS or if in higher priority than the CH200, possibly after a Break, not sure, I tried just about anything in ROM combinations and startup with keys pressed etc.), the BBC hangs when doing *HELP, so from my tests both ROM images are bad.
Judging by the ROM switch code, the two ROMs do need to be in adjacent slots, with CHADFS in the higher one. (I assume if you plug a 32K EPROM into a Master this is just how things come out?) The CH200->CHADFS code does a ldx $f4:inx:stx $f4:stx $fe30, and the CHADFS->CH200 code does the same but with a dex.
--Tom
tom_seddon
(GitHub repo to follow, but I'll make another thread for that, as it's not really archive-related.)
I've now dug into both parts a bit.
Regarding the DFS half's startup problems on a BBC B, this is a bug... I think... but you can fix it. Set offset $4e to $7e, and offset $4f to $ab. Now it calls the full DFS+ADFS reset routine on startup, rather than just the ADFS one, if it finds the Challenger RAM uninitialised. Result: boots up on BBC B and behaves as you'd expect, drive mappings reset and RAM disc initialised in the DFS style.
(I think the patched ROM will work same as before when used in conjunction with the ADFS half, but I reserve the right to later discover that I'm wrong about this ;) My Master 128 is packed away right now, so I haven't tested it.)
Regarding the ADFS half: now that I've checked, it turns out to be pretty unequivocally Master-only. It's not just the ROM switch code: there's CMOS instructions everywhere, it writes to $fe34, and it uses the Master FS workspace RAM at $c000 a lot. And interestingly, it doesn't look like it uses the Challenger RAM for ADFS workspace at all. (I suppose if you're targeting the Master, it doesn't really matter either way, and the Master workspace is a lot more convenient to access, especially as the accesses don't look to be always especially page-coherent. And no cycle stretching... ADFS is slow enough as it is, and combined with the bank switching I suppose this could make a measurable difference.)
I reckon a BBC B conversion would be quite the job. But there's 768 bytes free at the end of the ADFS ROM if anybody feels up to it...
--Tom
tom_seddon
I made another thread for my disassembly and the patched 2.00 ROM that appears to work on a BBC B: viewtopic.php?f=2&t=15816&p=216887#p216887
More on topic for this thread: I noticed that the ROM haul includes ROM 705, which has the same name and version number as the Challenger 1.01 ROM - but it isn't the same!
ea406c6ea7f69622ef036b4e1ba446e935dba2ea  /Users/tom/tmp/slogger/RomDumpsByRegregex_FromDM2009SloggerHaul/705-SLOGGER-1.01-S
37ee3f20bed50555720703b279f62aab0ed28922  /Users/tom/github/b2/etc/roms/opus/challenger-1.01.rom
The two versions are rather similar, bytewise, up to offset $147, at which point the 705 ROM has a jsr$b90d that the usual 1.01 doesn't. (The ROMs then diverge significantly because of that.) Based on a quick skim of the 2.00 code and my 1.01 disassembly, this appears to re-select the current drive when doing an OSWORD $7f with a negative drive number.
I didn't check for any other changes, but it looks like there are probably at least some. The code at $b90d in the 705 ROM is at $b901 in the 1.01 ROM, so there's clearly more than just those extra 3 bytes in there.
--Tom
Wouter Scholten
tom_seddon wrote:
Thu Oct 04, 2018 2:01 am
--Tom
It's only on my PC, nowhere public. I have disassembled 1.01 and 1.03, I could zip it and email if still of interest tomorrow of so (which email address?). With that I have list of table/data etc. that I used to indicate inline data, strings, jump addresses etc. with that for those versions, to create a disassembly listing.
tom_seddon
Going through some stuff I bought from eBay: a ROM labeled DDOS 3.45, titled DDOS 3.x5, that doesn't match any of the existing ones I've got, nor anything from Wouter Scholten's ROM collection or the ZIPs in this thread.
Judging by the numerous ROMs I seem to have calling themselves DDOS 3.x5 (and the two different Challenger 1.01 ROMs!), it doesn't look like Slogger were very organised about their versioning. So I didn't spend any time digging into this, on the assumption that would be unilluminating. But I've attached it anyway, if only for completeness's sake :lol:
--Tom
DDOS3.x5.zip
(12.06 KiB) Downloaded 27 times
Post by Pernod »
tom_seddon wrote:
Sun Jul 05, 2020 11:08 pm
It is 3.45, but contains a couple of extra bytes at offset &190 and a NOP at &19D, which then causes all JMP/JSR's to differ by 3 bytes. Haven't investigated any further but am assuming it's a hack, does yours look original?
tom_seddon
Pernod wrote:
Mon Jul 06, 2020 2:04 am
Not especially! - it's an EPROM with a green, handwritten label, with left-handed-looking writing.
The original Challenger ROM I had, that my dad bought in the mid 80s, was also an EPROM, but it had a a much more official-looking printed label.
--Tom
regregex
Post by regregex »
No reason to believe Tom's ROM isn't original:
>*ROMID
 3.45  01-06-85  20000
Wouter's archive has revision 1.2 (11-02-85 12000), and ROM 304 in the haul is revision 3.0 (16-10-85 30000). At first blush this ROM fits neatly between them. Among others, the change in rev 2.0 clears the interrupt flag and saves the old interrupt state before dispatching the OSWORD &7F command. (&19D reflects the new command table address). Rev 3.0 clears the entire current filename before parsing a file spec from the command line.
With your permission I'd like to add rev 2.0 to my ROM collection and put an entry in romsearch/ddos-versions.csv
Regards
Greg
Post by Pernod »
regregex wrote:
Thu Dec 17, 2020 3:44 pm
>*ROMID
 3.45  01-06-85  20000
Regards
Greg
Ahh, thanks for bringing *ROMID to my attention, wasn't aware of it. Looks like I need to revisit some collections in case I've erroneously discarded any other revisions. Presume it's only DDOS that implements *ROMID, wish other publishers would've implemented something similar, especially Solidisk.
Anything posted to the forum is fair game for adding to collections.
regregex
Post by regregex »
Pernod wrote:
Thu Dec 17, 2020 6:41 pm
Oddly enough it is only in DDOS. No such command in Challenger or SEDFS. Although by March '86 they get sloppy and send out three different ROMs with the same date and revision!
Fair enough!
