Flight Path
billcarr2005
Flight Path
Post by billcarr2005 » Tue Apr 12, 2016 6:26 pm
Since it was on an unprotected 3.5" ADFS disk, it was simply a case of
*ADFS
*LOAD filename 2000
*DISK
*SAVE filename 2000+length exec load
for all 17 files. :wink:
Flight Path.zip
Flight Path
(27.36 KiB) Downloaded 91 times
Re: Flight Path
Post by CMcDougall » Thu Apr 14, 2016 7:19 pm
:lol: I like the way you just threw that straight onto a DFS disc! Great minds think alike :D
billcarr2005
Re: Flight Path
Post by billcarr2005 » Tue Dec 06, 2016 4:33 am
Found this, the native DFS version, on a shelf.
All files are the same length (so I'm assuming same content) except for in REPZ, line 7840 on the ADFS version was *??? (which would error) whereas on the DFS version it's CHAIN"CONDZ1" which doesn't usually exist as a file, but code from the file "AUTOST" intercepts the file vector and loads it from a "bad" section of the disk as part of the protection.
Also, since ?&CE8=0, issued in the file "AUTOST" is now set when loading, you're guaranteed to get the title screen.
FLIGHT PATH (DFS).zip
FLIGHT PATH FROM NATIVE DFS DISK
(27.46 KiB) Downloaded 79 times
