Accelerator 1.06
Accelerator 1.06
Post by Pernod » Mon Oct 10, 2016 12:48 pm
The original disc fails verify at track 31, on both sides, so probably just to stop you from doing a *BACKUP. Since UPURS without F only copies actual data then track 31 is never accessed.
Accelerator-1.06.zip
(16.71 KiB) Downloaded 43 times
Accelerator.zip
(17.97 KiB) Downloaded 103 times
Re: Accelerator
Post by lurkio » Mon Oct 10, 2016 1:10 pm
Thanks, Pernod.
=D> =D>
Are you planning to image the ROMS and scan the manual? I ask because there seems to be a number of different versions of Accelerator floating about, and I'm a bit confused about which is the latest, and which of the disc- and ROM-images actually work!
See this thread for more info:
Re: Accelerator 1.06
Post by Pernod » Mon Oct 10, 2016 1:46 pm
I'll do the ROMs at a later date. The manual and quick reference card match those already available in the other thread.
billcarr2005
Re: Accelerator
Post by billcarr2005 » Mon Oct 10, 2016 2:35 pm
Pernod wrote: The original disc fails verify at track 31, on both sides, so probably just to stop you from doing a *BACKUP.
Tracks 31 - 39 are all unformatted, possibly to speed up duplication? :?
Post by Pernod » Wed Jun 12, 2019 10:25 am
Updated the first post with the 1.06 ROMs that came with this package.
