SupaStore 2.0S - ESM rom & discs
Post by CMcDougall » Sun Jan 14, 2018 10:06 am
by request Barrie / OneSwitch, he found this info:
info
Here is the ROM image two discs (Main & DataDisc), which I copied from high school 1989ish
but never used it, or know what to do with it, as no instructions...
to use, put "SupaStore-ESM ROM image" into a rom socket on BeebEm414 or emulator of choice,
boot up SupaStoreA.SSD, this gets:
scr
then when select Enter SupaStore, asks for DataDisc in0, so ejectA, select0 "SupaStoreB DataDisc" gets:
scr2
has at end of rom image:
"Written by Andrew Jacobs and David Tee.
Many thanks to Jim Milne at MEP and
Laurence Hardwick at Acorn Computers."
enjoy 8)
SupaStoreA B DataDisc-ESM.zip
2x SSD discs
(59.7 KiB) Downloaded 49 times
SupaStore-ESM ROM image.zip
rom image & on SSD
(34.74 KiB) Downloaded 50 times
OneSwitch
Re: SupaStore 2.0S - ESM rom & discs
Post by OneSwitch » Sun Jan 14, 2018 1:26 pm
Amazing! Works a treat (I insert the ROM and type *SUPASTORE to pull up the Database utility. I then insert the SEMERC database disc (13th Feb 1987 version attached), and can chose to view the database in order...
If anyone could help me to burn a SUPASTORE EEPROM, I'd be hugely appreciative. Be cool to get this running on a legitimate BBC Micro / Master.
Amazing find for the history of Special Needs technology.
Huge thanks to Jeff Hughes, Judith Stansfield and Colin McDougall for helping to preserve this. :) Only 321 pages to trawl through for gems.
Barrie
OneSwitch.org.uk
SP ED Software Datbase-SUPASTORE dataDisc Mar87.dsd
(400 KiB) Downloaded 34 times
Post by CMcDougall » Sun Jan 14, 2018 2:29 pm
OneSwitch wrote:could help me to burn a SUPASTORE EEPROM
done :wink:
