RPCEmu 0.9.0
flibble
RPCEmu 0.9.0
Post by flibble » Sat May 05, 2018 8:52 pm
A new version of RPCEmu is available, 0.9.0
http://www.marutan.net/rpcemu/
The two major changes in version 0.9.0 compared to previous versions.
  • Changed to the Qt5 library for the GUI. Previously we used the Allegro 4
    library and additional win32 code.
    • The GUI is shared by all platforms, reducing maintenance work.
    • The Linux/BSD builds gain the full GUI that previously was Windows only.
    • The full-screen mode should no longer crash.
    • The full-screen mode uses software scaling. It will no longer resize your
      host OS desktop and it preserves the aspect ratio of the emulator video
      modes.
    • The clock "drift" (where host and emulated clock move apart) should be
      gone. As such we no longer enable the SyncClock module by default. However
      if this is causing you an issue please report it.
  • Changed the threading model of the program so that the GUI is in a separate
    thread from the emulation of the machine.
    • The most obvious change from this is that opening menus and configure
      windows does not halt the emulation of the machine while you work with
      them.
Additional fixes in version 0.9.0
  • Linux: Support being built as a position independent executable (PIE), this
    allows the 64-bit recompiler builds to work without modification on Linux
    distributions which compile all software as PIE by default (e.g. Ubuntu
    16.10 and later)
  • Windows: HostFS date stamps should be correct regardless of Daylight
    Savings Time flag.
  • ARM Core: STM with store of R15 should vary with processor type (x86
    recompiler).
  • ARM Core: STRT/STRBT with store of R15 should store same value as STR/STRB.
  • The mouse will work when changing between A7000 and RPC models without
    having to rerun RPCEmu.
  • In 'Follow host mouse' mode, enabled support for OS_Word 21,3 'Move Mouse',
    also supports BBC BASIC 'MOUSE TO'.
  • In 'Follow host mouse' mode, the mouse should work correctly if you change
    to fullscreen, change RISC OS mode and leave fullscreen again.
  • Clang compiler is now recognised when writing to the log file.
A special thanks to the members of the RPCEmu mailing list who helped with
testing these wide-ranging changes.
Matthew Howkins
Peter Howkins
Re: RPCEmu 0.9.0
Post by davidb » Sat May 05, 2018 9:13 pm
Great work! =D>
Switching to Qt 5 for the GUI should certainly make it easier (for me, at least) to make changes and improvements if I need to. :)
pixelblip
Re: RPCEmu 0.9.0
Post by pixelblip » Thu May 10, 2018 6:15 am
Than you so much.....it keeps the machine alive for us to still enjoy.
It's great you support all platforms.
