Arculator v2.1 released!
SarahWalker
Post by SarahWalker »
Only two years since the last release! I must be getting soft in my old age.
Changes since v2.0:
  • New podules : Acorn AKA05 ROM Podule, Acorn AKA10 IO Podule (w/AKA15 MIDI Upgrade), Acorn AKA16 MIDI Podule, Aleph One 386PC/486PC Podule, Computer Concepts ColourCard, State Machine G16 Graphics Accelerator, Oak 16 Bit SCSI Interface
  • Minipodule support for A30x0/A4000. Currently included : Acorn AKA12 MIDI/IO Podule, ICS A3INv5 IDE Interface, ZIDEFS IDE Interface
  • Added A4 laptop emulation
  • Added A500 prototype emulation
  • Added HFE disc image support (read/write)
  • Fixed MEMC1 timing
  • Bugfixes
As ever, main site is at http://b-em.bbcmicro.com/arculator/ (and is in desperate need of some more modern styling...), github is at https://github.com/sarah-walker-pcem/arculator/.
IanJeffray
Re: Arculator v2.1 released!
Post by IanJeffray »
WOW! Impressive and boggling stuff. So much to play with! Totally boggled to see PC podule emulation.
Arculator support as an extension ROM is a smart idea too.
Great work. Thank you!
arkiruthis
Post by arkiruthis »
Thank you so much for continuing to work on this. It's been essential for going backwards and forwards with my own machine. Really appreciate it.
Post by Pernod »
Nice release, and good to see more podules supported, it saves me from having to reverse engineer them ;)
What's the significance of the fixed MEMC1 timing? Does any particular software fail without this?
SarahWalker
No, but if you're aiming for cycle accuracy having broken timing is a bit embarrassing!
Post by steve3000 »
Absolutely brilliant Sarah, as always!
Just tested RasterMan and very pleased it (still) runs nicely. :)
For the A500 prototype emulation - does this emulate the VIDC1 with sound byte format having D[7] as sign? (vs. VIDC2 used in production models, with D[0] sign). And is the FDC1793 emulated? Any other differences?
Is there any way to enter a different ARM3 speed, above 35MHz, without needing to modify source? BITD I had an IFEL 36MHz ARM3 upgrade and having recently overclocked a real ARM3 to 48MHz, I'd love to be able to do this (or more...) in emulation whenever I have something large to compress, compile, etc.
SarahWalker
steve3000 wrote:
Mon Sep 06, 2021 11:54 pm
Yes. Yes. ST-506 controller mapping is also different.
Not at present, no.
timw
Post by timw »
This is brilliant - thanks, Sarah! I still remember reading in one of the magazines BITD that "emulation of an Archimedes on another machine will never be possible", or words to that effect...
Here are some notes for compiling on linux. Some peculiarities may be down to my particular build environment.
  1. Add podules/morley_uap/src/Makefile to configure.ac
  2. In podules/aka10/src/Makefile.am: change .o to .c and the same for morley_uap, otherwise the libraries don't get built and we get missing symbols at runtime:
    libaka10_la_SOURCES = ../../common/uart/6850.c aka10.c ../../common/joystick/joystick_sdl2.c ../../common/adc/d7002c.c ../../common/misc/6522.c
  3. Add CFLAGS -std=c99 in podules/aka05/src/Makefile.am
  4. #include <stdint.h> in wx-hd_new.cc and wx-joystick-config.cc
  5. In wx-main.cc, exclude this windows call:
    #ifdef _WIN32
            SDL_SetHint(SDL_HINT_WINDOWS_DISABLE_THREAD_NAMING, "1");
    #endif
  6. I get a compile error "wx-podule-config.cc:619:49: error: cast from ‘void*’ to ‘int’ loses precision". I don't know what's going on with these casts, but if I change int to long, it seems to work:
    cbox->SetSelection((long)val);
  7. In wx-config.cc ConfigDialog::OnComboPodule(wxCommandEvent &event), the following doesn't return a valid string pointer:
    const char *sel_s = cbox->GetStringSelection().c_str();
    This breaks the function of the config menu, so I can't select any podules. I have to get the string as follows, instead:
    char sel_s[256];strncpy(sel_s, cbox->GetValue(), sizeof(sel_s));
  8. Regenerate the makefiles:
    autoreconf --force --install
    ./configure --enable-release-build
    make
It works. Great stuff!
arakeen
Post by arakeen »
Thanks for the update, however I am seeing an issue with the new version... On first launch of an A5000 machine I briefly get a Disc Error 23 or 22 for ADFS::5 (an HDF originally imaged from a physical A5000 ~10 years ago). Resetting the machine then boots without error.
Normally the machine is set to boot from this drive - this gives me the Error 23 at the initial boot screen. After a CMOS reset and before configuring boot back to the drive I get a short stall during the splash screen then Error 22 when trying to open the drive. Location is the same for each error (00000C00).
Screenshots attached. I reverted to 2.0 and confirmed that it still boots without error.
SarahWalker
Odd. Can you post your config please?
arakeen
Post by arakeen »
I've included the .cfg and CMOS files, hopefully that covers it - thank you.
I noticed in the 2.0 release thread a mention of removing the 512 byte header from older images - is this worth a try, and if so what's the best/safest way to do that?
A5000.zip
(776 Bytes) Downloaded 4 times
arakeen
Post by arakeen »
I tried removing the top 512 bytes in WSL (dd if=hd5.hdf of=hd5new.hdf bs=512 skip=1), but I see the same behaviour when it's not configured as the boot drive (I haven't tried it as boot drive).
SarahWalker
Whoops, looks like secondary IDE drive support is broken on v2.1. Will be fixed for v2.2.
garfield
Post by garfield »
SarahWalker wrote:
Wed Nov 17, 2021 8:30 pm
Nice! Thanks Sarah!
anightin
Post by anightin »
Was just thinking how cool it would be to have floppy drive support on Arculator via a USB floppy or such.
Have been following the Drawbridge project and great to see that it's hooked into WinUAE for Amiga:
https://amiga.robsmithdev.co.uk/
I'm currently on the waiting list for the current batch of boards, and if successful will hopefully have a drawbridge-enabled drive to lend to anyone who has the skill-set to link in the drive support in a similar way.
Just a thought.
sirbod
Post by sirbod »
When you edit a machine, there's a tagline below the machine name that says:
ARM2, 1MB RAM, MEMC1, Old IO, Arthur
Is that a leftover from a previous version or should it update to describe the machine config as list below in the drop-down menus? It doesn't appear to change.
arakeen
Post by arakeen »
Grand, thanks very much, I'll look forward to it :)
(Sorry for the delayed response, I swear all the posts following my last one only showed up for me today...)
