64K to 128K upgrade
Sniffer
Re: 64K to 128K upgrade
Post by Sniffer » Tue May 07, 2019 8:27 pm
I thought L13 meant S13, don't know why!
Now I know why I thought that. The post refers to L9, L11, L12, L15 or L18 but actualy means S9, S11, S12, S15 or S18, along the east of the board.
So, is there an actual L13? I now think it does mean $13 which brings me back to my original question. Both pin 20s can't be connected to the same point can they?
Post by DutchAcorn » Tue May 07, 2019 9:25 pm
Oops, I opened up my B+ to check what I had done. One of the pin 20s is connected to the NORTH pin of S13, the other to the south pin. The description mentions that you should use the “unused pin of S13”. In my case that was the north pin of S13. Sorry for the confusion.
No, they can’t be connected to the same point.
Sniffer
Post by Sniffer » Tue May 07, 2019 9:33 pm
Absolutely no problem, thanks for taking the time to check.
Sniffer
Post by Sniffer » Thu May 09, 2019 8:19 am
For a full RAM count you want RAMCount.
How is this used? I can see it's not basic.
Remklep
Post by Remklep » Sat Jan 04, 2020 12:38 pm
Gents,
I just did the 64-128kB upgrade to my model B+ and have some questions.
The first time I started the B+ it said:
Acorn OS 128K
Acorn 1770 DFS
BASIC
So everything was as expected.
But when I press Break it says:
Acorn OS
Acorn 1770 DFS
BASIC
Other times I have seen it display 96K or 112K.
I'm assuming this is not normal?
Thnx
Post by 1024MAK » Sat Jan 04, 2020 12:41 pm
Not giving the size after just pressing BREAK is normal.
After power up, the size should however be consistent.
Remklep
Post by Remklep » Sat Jan 04, 2020 12:52 pm
Hi 1024MAK,
Thnx for the info.
When I switch off the model B+ and switch it back on after a second or 2 it reports 96K.
If, however, I switch it off and press a keyboard button, it reports 128K again after power on.
I guess it's a capacitor thats still charged, getting discharged by pressing a button.
Remklep
Post by Remklep » Sat Jan 04, 2020 12:54 pm
I ran the 410 line memtest program and this was the output...
Seems to me there should be some RAM locations, or not?
Post by 1024MAK » Sat Jan 04, 2020 12:58 pm
There is another thread about upgrading a B+, this post gives details on how the machine decides how much RAM it has.
marcusjambler
Post by marcusjambler » Sat Jan 04, 2020 1:00 pm
I have a B+ that does this
I found that if I move the ROMS ( not OS ) around it changes the reported RAM :shock:
rmbrowngr
Post by rmbrowngr » Sat Jan 04, 2020 1:05 pm
I've done this upgrade and have the following arrangement of ROMs and RAM:-
DFS version 2.26 (if you don't have it I wopiuld recommend you get it) IC62
BASIC and OS IC71
Sideways RAM IC57
And I always get 128k on power on and crtl+break
Richard B
rmbrowngr
Post by rmbrowngr » Sat Jan 04, 2020 1:07 pm
This doesn't look right to me e.g. no RAM reported. Once you get RAM listed the next test is to load something into sideways RAM.
And this might be useful to read viewtopic.php?f=3&t=16789. Contains my experience on performing this upgrade. You can always use a version of Elite that using SWRAM once the get the upgrade working.
Also, there a some other tools for SWRAM available on mdfs.net http://mdfs.net/Software/BBC/SROM/
Richard B
Remklep
Post by Remklep » Sat Jan 04, 2020 1:39 pm
Mea Culpa!... #-o
What a big difference a ":" in stead of a "*" makes in a little 410 line program... :oops:
After running the corrected program:
But when running it a second time:
So something IS going on.
rmbrowngr
Post by rmbrowngr » Sat Jan 04, 2020 1:43 pm
Connect the other extra pin 20 to the spare pin of L13 (CS for either roms 0/1 or 14/15, depending on where you want BASIC)
Richard B
Remklep
Post by Remklep » Sat Jan 04, 2020 1:59 pm
I have.
One pin 20 goes to pin9 of IC46, the other pin20 goes to the unused north pin of S13.
Remklep
Post by Remklep » Sat Jan 04, 2020 2:02 pm
After putting jumper L12 in the East position (rest of L jumpers in in the West position) the RomRam test is now consistent and shows RAM in 6,7,12 and 13.
Post by 1024MAK » Sat Jan 04, 2020 3:30 pm
See also this thread.
rmbrowngr
Post by rmbrowngr » Sat Jan 04, 2020 5:17 pm
A picture guide to how I have the SWRAM setup:
ROMS
RAM\ROM List Disk attached below the pictures
Top View
Side view 1
side view 2
Disk image (DFS) for B+ with the ROM\RAM list program saved as "RTEST".
bplus.zip
(12.12 KiB) Downloaded 5 times
64K SIDEWAYS RAM DAUGHTER BOARD FITTING INSTRUCTIONS, if you're interested
BBCB+64k.zip
(2.96 KiB) Downloaded 6 times
BBC Microcomputer model B+ with 128K RAM, Additional User Information
BPlus128KAdditionalUserInfo.zip
(22.57 KiB) Downloaded 4 times
Richard B
Remklep
Post by Remklep » Mon Jan 20, 2020 9:38 pm
Finally took some time to look at my stack of chips.
Turned out some legs weren't soldered together properly.
Mea Culpa...
It works perfect now.
Post by Kazzie » Tue Jan 21, 2020 5:26 am
Mea Culpa...
Well done! =D>
We've all done something similar at some point. (Here's one of my finest... #-o )
