Key ghosting
garfield
Key ghosting
Post by garfield » Thu Jun 05, 2014 6:23 pm
What is the method for determining which simultaneous BBC key presses will create unwanted 'ghost' key activations? (Also, is the Beeb any worse or better than its contemporaries in this regard?)
I came across this image, and vaguely recall something about rectangles. Anyone care to explain this please?
I've a notion to create a 3-player game (using the keyboard) that requires six keys minimum per player.
Re: Key ghosting
Post by IanS » Thu Jun 05, 2014 8:07 pm
It is all about rectangles, if 3 buttons at the corners of a rectangle are pressed, to the hardware it will look like all 4 keys of the rectangle are pressed.
e.g. if keys S,G & A are pressed then the F key will also look like it is pressed. When the column with G & F is driven, signal will go via the other 3 keys and be detected on the row with A & F so it looks like F is pressed.
Does that help?
I think the most unique keys that can be individually detected would be to use one row and one column, avoiding the key at the intersection. Fancier keyboard have a diode on every key allow all keys to be seperately detected.
garfield
Re: Key ghosting
Post by garfield » Thu Jun 05, 2014 8:13 pm
I think I understand. Thanks.
paulb
Re: Key ghosting
Post by paulb » Thu Jun 05, 2014 10:03 pm
garfield wrote:I came across this image, and vaguely recall something about rectangles. Anyone care to explain this please?
If you want to understand the general concepts, I've found this document to be useful.
garfield
Re: Key ghosting
Post by garfield » Fri Jun 06, 2014 8:48 am
Handy! Cheers.
Re: Key ghosting
Post by tricky » Fri Jun 06, 2014 9:13 pm
I wrote a program over 30 years ago which draws a keyboard and then highlights the keys it thinks are pressed, you can use it on a real beeb to see exactly what is aliasing. http://www.retrosoftware.co.uk/forum/vi ... 6135#p6458 I used it when I was working on Jeltron http://www.retrosoftware.co.uk/wiki/ind ... l_Jaysmith which had 12 keys (4 dir, fire and power-up per player).
There is a faster version http://www.retrosoftware.co.uk/forum/vi ... =100#p6558 that just lists the keys pressed (read from machine code).
PS I probably wouldn't have written it if the AUG was as clear as that diagram.
