Fitting slogger turbo driver
KenLowe
Re: Fitting slogger turbo driver
Post by KenLowe » Sat Jun 30, 2018 8:12 pm
1024MAK wrote:
Sat Jun 30, 2018 6:38 pm
Well, as there are at least two versions of the Slogger Click PCB, and at least two versions of the Slogger Pegasus PCB, it's entirely possible...
The Slogger Turbo Driver in the photo that Slo posted looks very similar to the Slogger Turbo Driver in the photo that Danielj posted.
Assuming the pin labels are correct, the equation differences are quite fundamental.
AlanD PAL (written for Wincupl):
ramnoe = turbo # upa13 # upa14 # upa15;
ramnwe = upRnW;
Slo PAL (written for OPALJR):
ramnoe = /upRnW
ramnwe =  upRnW
	+ phiout
There are only minor differences with the other four equations - mainly that the AlanD PAL is using an inverted 'turbo' input whereas the Slo PAL is using a non-inverted 'turbo' input.
Edit: Duh! Obviously...
ramnwe = /upRnW * phiout
	+ upRnW
can be simplified to
ramnwe =  phiout
	+ upRnW
Various posts updated to reflect this.
