EDIT ~
I've just discovered that my monitor cable is faulty as the screen went blue and flickered when jiggling it about, i've just swapped it for another cable and the screen is rock solid again
; JED2EQN -- JEDEC file to Boolean Equations disassembler (Version V063)
; Copyright (c) National Semiconductor Corporation 1990-1993
chip Slogger GAL16V8
romoein=1 upa15=2 upa14=3 upa13=4 turbo=5 phiout=6 upRnW=7 ipirq=8
upnmi=9 GND=10 upphiin=11 uprdy=12 ramp1=13 ramnoe=14 ramnwe=15
ulaa15=16 ulaa14=17 ramce2=18 romoeout=19 VCC=20
equations
romoeout = /upa15 * /upa14 * /upa13 * /turbo
+ romoein
ramce2 = /upa15 * /upa14 * /upa13 * /turbo
ulaa14 = /upa15 * /upa14 * /upa13 * /turbo
+ upa14
ulaa15 = /upa15 * /upa14 * /upa13 * /turbo
+ upa15
ramnwe = upRnW
ramnoe = turbo
+ upa13
+ upa14
+ upa15
ramp1 = uprdy
+ phiout
+ ipirq
+ upnmi
+ upphiin
Once I get the PAL decoded I can hopefully shed some light on what's going wrong!
I usually find that a big hammer helps at this point.
Dave will that be with a GAL in it or PAL? How much?daveejhitchins wrote: ↑Mon Jun 25, 2018 7:41 amI could also test them before sending - Or i could just send you a working Turbo board . . . ?
Dave H![]()
Always a bit random from days to months. Sometimes even from the same supplier.
Cargo ships take ages. Any luck it will be air mail. We send boxes via Cargo ship can take anything from 1 month to 3 months. (When they arrive)CMcDougall wrote: ↑Fri Jun 29, 2018 12:02 pm^ depends on when the cargo ship sails, so if they catch day before bonus
The would be a GAL.
PM sent . . .Slo wrote: ↑Fri Jun 29, 2018 5:16 pmDave would you mind if i post you my boards and you program my two gals and test them, i can rule out the issue 4 board being the problem if it works then, happy to pay labour and time costs thanks.
Has anyone got their old pal they can send me to replace my lost one otherwise this board is useless to me without one.
equations
romoeout = /upa15 * /upa14 * /upa13 * turbo
+ romoein
ramce2 = /upa15 * /upa14 * /upa13 * turbo
ulaa14 = /upa15 * /upa14 * /upa13 * turbo
+ upa14
ulaa15 = /upa15 * /upa14 * /upa13 * turbo
+ upa15
ramnwe = upRnW
+ phiout
ramnoe = /upRnW
ramp1 = /uprdy
+ uprdy
+ ipirq
+ upnmi
+ upphiin
Well, as there are at least two versions of the Slogger Click PCB, and at least two versions of the Slogger Pegasus PCB, it's entirely possible...
