Turbo MMC Interface
Wheel_nut
Re: Turbo MMC Interface
Post by Wheel_nut » Fri May 03, 2019 11:57 am
Thank you guys for your responses.
CMorley, I downloaaded the fix from the link on that site to the Microsoft fix and ran it. It seemed to complete and said it had installed successfully ... but, I still get the error when trying to run MMBmanager :(
I tried re-booting the computer to no avail.
I also tried running it on another 64bit Win10 computer and the behaviour was identical. However, I don't get the same error on a 32bit Win10 computer, on this one, the MMBmanager opens and I can open the BEEBMMB file which shows allof the Disks in the catalogue .... but when I click on any of them, I get a message box saying File not found. :( :( ** See Edit below...
Edit: I discovered that BOTH of the Apps MMBmanager and DFSmanager need to be in the same directort when MMBmanager is executed because it calls DFSmanager to perform operations on the Disk images within the BEEBMMB pack. I have now got past this point.
cmorley
Post by cmorley » Fri May 03, 2019 1:39 pm
The instructions tell you how to install it on 64 bit windows - since that file predates 64 bit windows as we know it now. You don't run the MS installer but must unzip the file and copy it according to the instructions. I did it a few days ago on my newer laptop and the instructions do work.
Wheel_nut
Post by Wheel_nut » Fri May 03, 2019 3:01 pm
CMorley, Thank you so much for the explicit explanation which has fixed the error on my Windows 10 64Bit Laptop. I can now run MMBimager on this PC. I am not sure that I have got to the stage of being able to successfully load files into disk images but I am getting there... :D =D>
Post by tricky » Fri May 03, 2019 4:11 pm
Some operations, I can't remember which require you to disable protection in the menus.
Wheel_nut
Post by Wheel_nut » Fri May 03, 2019 6:44 pm
I have got to the stage of having loaded the MMBimage program and the BEEBMMB file on my PC.
I have discovered that Selecting a Blank Disk (say Disk 410) and clicking on the Restore button will format the Disk and I can then double click on it to bring up the DFSimage program window for Disk 410. I can aso add a Title to the Disk and after refreshing the MMBimage window, it shows the name of the now formatted Disk in the tiled disk icon display.
I am now trying to drag and drop ROM Images from Windows Explorer into the DFSimage window. Nothing happens!
The Disk is "Unlocked" i the MMBimage window and "Protection" is Disabled in the DFSimage menu.
Any clues?
KenLowe
Post by KenLowe » Fri May 03, 2019 8:25 pm
You need an associated .inf file to go with the ROM image. Drag a file from one of the SSDs onto your desktop to see how a typical .inf file is formatted.
