Page 1 of 1
WE 30Mb Winchester
Posted: Wed Mar 09, 2011 7:20 am
by dwarfmage
Just acquired a watford electronics 30 meg winchester but cannot access it on a master 128. Do i need a specific DFS rom or utils floppy? The master has no additional roms installed.
Re: WE 30Mb Winchester
Posted: Wed Mar 09, 2011 8:45 am
by AndyF
Without having owned a 'real' one, I would say no you should be able to just access it via ADFS. I can't visualise a WE one wanting its own version of ADFS.
You 'do' have ADFS 'plugged in' ? , do a *ROMS and *INSERT the ADFS if needed.
It might not be formatted. Somewhere I've seen a WE formatter, not 100% sure if the others would do it.
Posted: Wed Mar 09, 2011 11:48 am
by dwarfmage
Thanks Andy
Yep, the ADFS is inserted (v1.50). When the CTRL+Break is pressed, the winchester light comes on and after a while it reports a disc error so it is seeing it connected.
I'll try hunting around the websites for a WE formatter.
Posted: Wed Mar 09, 2011 4:45 pm
by AndyF
You're welcome. :)
I think its normal for it to hang until the disk reports 'ready' , ie: it has spun up. The modified versions do not do this (and have other handy features such as not forgetting their CSD on break)
I think an unformatted one will report 'broken directory' though, anything else might be a concern but I guess you could try formatting it unless you wanted to use a disc editor to inspect its contents.
I don't have access to my PC backup of my Acorn disc images at the moment, so I can't fish it out. There's a few around but I do recall seeing a WE utils disk with a version of WForm or something on it, I've not looked for a while though, sorry that's probably not a lot of help.
Posted: Wed Mar 09, 2011 7:19 pm
by dwarfmage
Its more info than I had this morning. At least I'm only looking for a disk image now.
Posted: Wed Mar 09, 2011 7:44 pm
by RobC
Have a look in this thread:
http://www.stardot.org.uk/forums/viewto ... f=3&t=3707
BeebMaster has posted some disk images that contain a variety of HD formatters. I'm pretty sure there's a WE one in there.
Best wishes,
Rob
Posted: Sun Mar 13, 2011 7:04 pm
by dwarfmage
Thanks Rob. Will try those formatting tools out.
Posted: Sun Mar 20, 2011 11:34 am
by AndyF
Did you have any luck with this ? :)
Posted: Wed Mar 23, 2011 3:52 pm
by AndyF
I guess you are busy filling said hard drive up hence lack of reply :D :D :D
Posted: Sun Mar 27, 2011 9:03 pm
by BeebMaster
Either that or it's STILL formatting - I've got one which is something beginning with K, Kalok or Kyocera or something, which never finishes formatting. I've left Superform running for about 3 hours before now without it ever moving on to verification.
Posted: Thu Apr 21, 2011 5:10 pm
by dwarfmage
Sorry.. needed some bits while I was in the UK. Now back in Germany so I can try to transfer the disk image from a previous link for utils to a floppy and get the winchester formatted.
Posted: Fri Apr 22, 2011 11:14 pm
by dwarfmage
After getting the links from RobC, using ADFS explorer to copy the hard.img disk image to an ADFS one and then transferring it to a disk via serial cable, I've managed to get the superfo to format the winchester successfully.
And after all the years since the drive was made, there was only 3 defects found!
Posted: Sat Apr 23, 2011 9:56 am
by AndyF
Excellent =D>
