BeebSID
andyt31
Re: BeebSID
Post by andyt31 » Thu Aug 18, 2011 12:37 pm
I've now started to build an enclosure for mine.
If you have seen the episode of the IT Crowd with the internet in a box - mine looks a lot like that. :o
Website : https://www.retrocomputers.online
Twitter : http://twitter.com/andytuk
Volunteer for The Centre for Computing History
GroovyBee
Re: BeebSID
Post by GroovyBee » Thu Aug 18, 2011 5:20 pm
andyt31 wrote:If you have seen the episode of the IT Crowd with the internet in a box - mine looks a lot like that. :o
Here ya go
http://www.youtube.com/watch?v=mSGT6SSI0lA&t=3m23s
nOmArch
Re: BeebSID
Post by nOmArch » Thu Aug 18, 2011 10:03 pm
To save wading through the last 18 pages (I did go through the first 3) can someone give me a price and availability for one of these?
Alex
Back up to 1 Beeb again. \o/
MartinB
Re: BeebSID
Post by MartinB » Thu Aug 18, 2011 10:04 pm
'A' Martin wrote:I'm starting to think, BeebSID looks waaaay better without any enclosure!
Tis a thing of pure and wondrous beauty.... :D
(...and if it's in a box where do you put your scope probes :-k )
MartinB
Re: BeebSID
Post by MartinB » Thu Aug 18, 2011 10:10 pm
nOmArch wrote:To save wading through the last 18 pages (I did go through the first 3) can someone give me a price and availability for one of these?
Sorry just missed that, I wasn't taunting you!
Sadly, my run are all long gone :( but someone is working on Batch 2 :D
andyt31
Re: BeebSID
Post by andyt31 » Thu Aug 18, 2011 10:41 pm
Mine is now boxed - but easily opened to see the BeebSID in all of its glory.
(I need to protect it - I would be distraught if it broke.)
nOmArch
Re: BeebSID
Post by nOmArch » Fri Aug 19, 2011 9:35 am
Lol Well within your rights to :D these gadgets are things of beauty!
oh and ta for the info =D>
Alex
nOmArch
Re: BatchPCB for hardware projects
Post by nOmArch » Fri Aug 19, 2011 9:51 am
One definite order from me if a second batch is produced.
Alex
mga1103
Re: BeebSID
Post by mga1103 » Fri Aug 19, 2011 1:42 pm
andyt31 wrote:I've now started to build an enclosure for mine.
Oh my God!!! You've got the Internet AND BeebSID in a box, the one box!!! :lol:
Seriously, nice job! =D>
LeeB
Post by LeeB » Fri Aug 19, 2011 3:42 pm
nOmArch wrote:One definite order from me if a second batch is produced.
And almost definitely one from me too!
nOmArch
Post by nOmArch » Fri Aug 19, 2011 4:42 pm
2 down, 24 to go!
Alex
MartinB
Re: BeebSID
Post by MartinB » Fri Aug 19, 2011 10:46 pm
BeebSID boxed by andyt31.PNG (69.46 KiB) Viewed 2009 times
Fantastic job =D>
You guys are all putting my Morrison's cotton buds box to shame :roll:
andyt31
Re: BeebSID
Post by andyt31 » Sun Aug 21, 2011 11:07 pm
I've just uploaded my video of the BeebSID
poink
Re: BeebSID
Post by poink » Mon Aug 22, 2011 9:34 am
I'd also be interested in one :-)
I think that's 3 down 23 to go...
martinw
Re: BeebSID
Post by martinw » Mon Aug 22, 2011 5:49 pm
Me too .......... #4?
Re: BeebSID
Post by danielj » Mon Aug 22, 2011 6:37 pm
Oooh, g'wan. 5.
Prime
Re: BeebSID
Post by Prime » Sun Aug 28, 2011 3:54 pm
Ok,
Just prototyped the 2.0 board though I did manage to kill one of my two spare SIDs in the process :( I've discovered a couple of problems with the board as built, main one being that I didn't make it quite wide enough so was only able to get one of the bus connectors on it but that for me was not a problem. I have fixed this in 2.1. I've also added a set of pads for the poly caps that Maplins do as they are much smaller than the ones from the original board.
I've not included the MOSFET (yet), as the board now has sockets for both 12V and 5V-gnd-gnd-12V (standard 3.5" floppy power connector). I could add the MOSFETS but I assume that I'd want to put two of them on there, one for each of the 12V lines.
How does this sound to people.
I may be prepaired to do a small run of boards, but it would be just that, the boards will have to cost things but would I imagine be a similar price to the mk1 boards.
Here's the new layout.
beebsid 2.1 layout
Phill.
nOmArch
Re: BeebSID
Post by nOmArch » Sun Aug 28, 2011 5:31 pm
Yep I'm still very interested
Nice work on the v2.1 btw!
Alex
paulv
Re: BeebSID
Post by paulv » Sun Aug 28, 2011 6:13 pm
You're twisting my arm.... I guess I'll go for it too :D
nOmArch
Re: BeebSID
Post by nOmArch » Sun Aug 28, 2011 8:51 pm
6581's on ebay for £17 BIN or bid from £12
http://www.ebay.co.uk/itm/Commodore-64- ... 45fcaa70c9
Alex
piecrust
Re: BeebSID
Post by piecrust » Sun Aug 28, 2011 11:08 pm
Please count me in for one too, looks like great fun :-) genius bit of work.
Piecrust
poink
Re: BeebSID
Post by poink » Tue Aug 30, 2011 7:56 am
Prime wrote:I've not included the MOSFET (yet), as the board now has sockets for both 12V and 5V-gnd-gnd-12V (standard 3.5" floppy power connector). I could add the MOSFETS but I assume that I'd want to put two of them on there, one for each of the 12V lines.
That sounds great :D There's not a possibility of a header of some sort for audio in/out and the ability to use audio out on the 1MHz bus into the SID is there?
Re: BeebSID
Post by danielj » Tue Aug 30, 2011 8:16 am
Sounds spot on. Will it play with an 8580?
Prime
Re: BeebSID
Post by Prime » Tue Aug 30, 2011 9:18 am
poink wrote:That sounds great :D There's not a possibility of a header of some sort for audio in/out and the ability to use audio out on the 1MHz bus into the SID is there?
There's a jumper for audio to bus, just behind the phono out connector, top left, there's also a 2 pin 0.1" pitch audio out connector here too. No Audio in currently, but should be easy to plonk another 0.1" header on for that.
@danielj it should play ok with all versions of the SID, as the board has a jumper for SID VDD either 12V or 9V, though note I have not tried this as the SID I have is a 6581.
Phill.
Prime
Re: BeebSID
Post by Prime » Mon Sep 05, 2011 11:40 am
Ok pictures of the latest prototype here :
https://www.facebook.com/media/set/?set ... 848&type=1
Layout :
BeebSID 2.2 layout
Things of note :
The board may be powered either via a +12V supply, or via the 3.5" floppy power connector.
I have put the FETs on the +12V and +5V inputs, this will prevent damage by reverse polarisation, however this will not prevent dammage from plugging the floppy style power connector in upside down ! Which would route the +12 onto the +5 line and vice-versa. You are strongly advised to use a polarised connector to prevent that !
As a side note does anyone know where I can get 3.5" power connectors from ?
I have added a jumper to allow the option of selecting +12V or +9V for the SID.
I have added a jumper to select +5V provided by the regulator or from the floppy connector.
I have added a connector for audio in and brought the potx and poty SID pins to a header.
I have reduced the capacitor footprint to that used by the Maplin parts here : http://www.maplin.co.uk/polyester-pet-f ... tors-98159 as the y are smaller, if people really want I could possibly squeeze the large format parts on too.
The board has had a complete build and is hand buildable, once I'm done I'm going to make the Eagle files available so people can build their own if they want to. but as said before I am going to get some professionally made.
If there are no problems with this board once tested and there anre no further requests for things to be added this will be the version produced.
Phill.
paulv
Re: BeebSID
Post by paulv » Mon Sep 05, 2011 12:26 pm
Phill, that all looks great. Nice photos :D
As a complete aside, it appears we have two friends in common on Facebook, Bryan Jackson and Justin Murdock with whom I worked when I was contracting for Pipemedia :D
nOmArch
Re: BeebSID
Post by nOmArch » Mon Sep 05, 2011 1:44 pm
paulv wrote:Phill, that all looks great. Nice photos :D
+1 =D>
I have a spare set of logitech 2.1 x240 speakers which should do this wonderful little device justice.
Not sure my neighbours will be too happy though listening to the Castle Quest tune with full bass :lol:
Alex
Re: BeebSID
Post by 1024MAK » Mon Sep 05, 2011 3:41 pm
The 3.5inch floppy 4 way power connectors are just a modified 4 way, 2.54mm (0.1 inch) pitch right angle PCB connector and matching crimped 4 way housing for the cable connector (but you can solder the crimps if you do not want to pay silly money for the crimping tool).
So these may work (have not tried these, but have tried a different brand in the past with no problems):
http://www.rapidonline.com/Cables-Conne ... ader-66416
http://www.rapidonline.com/Cables-Conne ... tors-66414
Maplin do the proper cable connector (this may, or may not fit the PCB connector listed above):-
http://www.maplin.co.uk/floppy-disk-dri ... ctor--1319
If you keep looking, I'm sure you're find the "proper" PCB connector... :mrgreen:
And as your board looks so good =P~ you can put me down for one as well :D
Mark K.
station240
Re: BeebSID
Post by station240 » Mon Sep 05, 2011 4:46 pm
1024MAK wrote:The 3.5inch floppy 4 way power connectors are just a modified 4 way, 2.54mm (0.1 inch) pitch right angle PCB connector and matching crimped 4 way housing for the cable connector (but you can solder the crimps if you do not want to pay silly money for the crimping tool).
Or just steal both parts out of old PCs, hey preattached cable and everything.
Prime
Re: BeebSID
Post by Prime » Mon Sep 05, 2011 7:54 pm
station240 wrote: Or just steal both parts out of old PCs, hey preattached cable and everything.
Funny you should say that my Beeb aux power -> floppy cable was partly salvaged from a dead PC PSU.
In all seriousness this http://uk.farnell.com/te-connectivity-a ... dp/1056115 looks like it might work.
Phill.
