For those following progress of my IntegraB V2 project:
viewtopic.php?f=3&t=19392
viewtopic.php?f=3&t=19429
With the help of some very knowledgeable and helpful people on this forum (you know who you all are!!!) I managed to get both Shadow and SWRAM / ROMs working reliably on my board. However, currently I am having to use a bunch of 32K RAM ICs instead of the 512K IC that is soldered onto the board.
The 512K IC does work to a degree, and I can both read / write to it without any issue. However, if I try to run code from it, it's not so happy. For example, if I load BASIC into one of the banks (using Martin Barrs EELOAD utility), it loads and verifies fine. On reset it even responds correctly and returns with the
BBC Computer 32K
Acorn 1770 DFS
BASIC
On my 512K IC, I've added a MAX6366 Supervisory IC to the /CE line to try and avoid data corruption on power down, and I suspect this is the source of the problem. I've wired A13 into the watchdog input, but on reflection that was probably not the wisest choice. I picked that line because it was easy to route on the PCB.
So, before getting the soldering iron out, my question is - should this work as I've designed, or have I missed something altogether here? Do I just need to use a different address line (like A0) which is probably going to be toggling more frequently, or should I scrap this idea altogether and just get the CPLD to drive /CE directly?
Once again TIA.
