Master 128 CMOS Fault - SOLVED
DaveLecky
Post by DaveLecky »
Hi Folks,
I was given this master 128 and can’t find a solution to the problem, can anyone help please.
It appears that the configure settings are scrambled and won’t reset.
I have checked the keyboard and MOS 3.2 chip on working 128, a new backup battery has been fitted, the voltages are ok when switched on or off.
Switching power on I get a lot of bagpipe tones and,
TERMINAL
Power light and Caps Lock on, keyboard is mainly inactive, except for Ctrl Break, so nothing changes with the usual resets, Ctrl F break etc.
On occasion Ctrl Break has a reaction which gives , Acorn MOS, Acorn ADFS/DFS and flashing cursor. If I connect a disc drive it attempts to read it, displaying,
**BASIC
Bad Command
**LIB $.Library
**DIR $.Welcome
*CHAIN “Init”
Bad Command
Keyboard won’t function other than Ctrl Break which takes me back to TERMINAL =
Switching on with R pressed I get Acorn MOS, Acorn ADFS/DFS etc again as above, and reads the disc again.
Sometimes it refers to Acorn MOS, Acorn 1770 DFS with cursor.
While Ctrl Breaking, the screen mode sometimes changes too.
Can display *this is not a language
I have been searching the forum and got some pointers,
IC 11 CMOS/RTC
IC10 which was the solution for one member
IC8 VIA
But which one should I change first.....?
My soldering skills are very basic, I have changed IC’s before but I’m not exactly a pro, so don’t want to change too many unnecessarily.
Another question, I have sourced these three ic’s , but IC11 on the pcb is HD146818P, the one I have sourced is HD146818AP, is this Ic ok to use.
Any hints/tips will be appreciated.
Electron Plus 3 and plus 1, AP6 and Home made MMFS PP SD interface
Electron Plus 1 Pres AP3/4
Beeb issue 7 with IFEL 16 socket Rom/Ram board
Master 128, BooBip multi OS,IFEL SD card
StrongA RPC,
Atom
Re: Master 128 CMOS Fault
Post by 8271 »
You might not need to replace the ICs. On all the masters with dodgy CMOS I have been able to fix them by removing the 3 pin header from the MB and soldering a new one in. The original battery (the 3 AA cell type wrapped in cellophane) sometimes leaks and the electrolyte tracks up the wires and corrodes the connector and board.
If you take the header off and replace and reflow the solder around the resistors closest to the header. I would try that before replacing ICs.
Then if you can get to a star prompt you can reconfigure the machine.
*configure mode 7
*configure file 9
*configure lang 12
*configure noboot
You may also need to check the roms are inserted - try
*insert 9
*insert 10
*insert 11
*insert 12
*insert 13
Serial computer hoarder & econetophile
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
Post by Coeus »
You probably do have rubbish in the CMOS RAM but I suspect the fault is not there. It may be with the KB or something else.
DaveLecky
Post by DaveLecky »
Thanks guys.....I’ll have a look at your suggestions this morning.
StrongA RPC,
Atom
DaveLecky
Post by DaveLecky »
Hi folks,
I’ve checked the battery connections, belled out the tracks......all ok.
I’ve also swapped over the mainboard to my working master 128 and the problem is still present.
Is suppose I’ll have to replace the above IC’s one at a time.... :(
StrongA RPC,
Atom
MJS
Post by MJS »
Mine did some of the symptoms you're having (no keyboard, often saw TERMINAL). I went straight for IC8 - the VIA that handles keyboard/sound etc and that was the culprit. I ordered a new, compatible, one here: https://www.ebay.co.uk/itm/164245883607
It's worth putting a socket in if you replace it or just test with an alternative one.
Model B Issue 7
Master128
Gotek, MMC, Pi Tube, MD220 disc drive
DaveLecky
Post by DaveLecky »
Thanks for the info MJS,
I’ll be checking what I need and ordering bases to suit.
I may try reflowing, just in case I’m lucky, then change them one by one.
StrongA RPC,
Atom
DaveLecky
Post by DaveLecky »
SOLVED....
I decided to socket and change IC8 first and BINGO......IT WORKED.
Thanks everyone for your suggestions and help.
Another Master 128 lives to fight another day.
Dave.
StrongA RPC,
Atom
