[SOLVED] Elementary question about the audio amp on a BBC B
JasonStonier
Post by JasonStonier » Thu Sep 17, 2020 9:06 am
So, the Beeb has an onboard mono audio amp, and the speaker in mine is 8Ω.
Does anyone happen to know if the amp can safely drive a 4Ω speaker? Reason for asking is I have two nice little 8Ω speakers I want to use in a case mod, and I can either wire them in parallel for 4Ω or series for 16Ω. I think at 16Ω they'll be too quiet - if I put them in parallel I can add a 4Ω resistor in series to bring it back up, but just wondering if that's necessary.
Diminished
Re: Elementary question about the audio amp on a BBC B
Post by Diminished » Thu Sep 17, 2020 10:47 am
IIRC the audio amp is an LM386. Data sheet here. Seems to suggest 4 to 32 ohms is an acceptable range.
JasonStonier
Post by JasonStonier » Thu Sep 17, 2020 11:24 am
Perfect, thanks for the help. Confirmed it's an LM386N.
