Making a cheap Electron WiFi housing...
Multiwizard
Post by Multiwizard » Wed Sep 09, 2020 5:02 pm
I tried to make a cheap housing for my ESP8862 WiFi module...
I could post some pics, but I made a slide-show of these pics in my short video:
https://www.youtube.com/watch?v=tPMbePZs0DQ
Greetings, Wim... :-)
Re: Making a cheap Electron WiFi housing...
Post by roland » Wed Sep 09, 2020 6:45 pm
This is really great. Amazing =D> =D> =D>
But I doubt that it is cheap when you have to use a Beeb housing for it :lol:
Can you post some more information like the measurements of the pieces. I'd like to build one in plexiglass.
oss003
Post by oss003 » Wed Sep 09, 2020 8:09 pm
Nice job Wim ....... you still got it ........ :wink:
Greetings
Kees
Post by Elminster » Fri Sep 11, 2020 9:56 am
Also if the measurements etc. Are available then someone can knock up a 3D printable design without redoing all the work you have already done.
Post by daveejhitchins » Fri Sep 11, 2020 10:59 am
I'm on with that! I'm taking a KiCAD DXF into AutoCAD today to sort out the board outlines and hole placements.
I'll be just modifying one of my existing cartridge cases so I'll post files, for folk to try, as and when they're available.
One thing I'v asked Roland to do, if possible and he hasn't invested €€s, is to use low profile sockets - this will allow a better (read easier!) design of the case as there will be just a flat surface to work with.
Dave H.
Post by roland » Fri Sep 11, 2020 11:15 am
Hi Dave,
I did search for low profile sockets but didn't find any. Do you perhaps have part numbers from Mouser or Farnell?
Greetings,
Roland
Multiwizard
Post by Multiwizard » Fri Sep 11, 2020 11:27 am
I did use a part of a Beeb housing which is (see top picture) a little bend at the edges...
So I only have the side & back part measurements...
Post by 1024MAK » Fri Sep 11, 2020 11:29 am
When I last really needed a low profile 28 pin DIL socket (more years than I care to try to remember) I spend ages comparing the physical dimensions of the available turn pinned sockets at Farnell, RS, and some other suppliers. I even bought one of each type. When I compared them, they were all within 1mm (as in less than 1mm different in height) of each other. So I suspect for turned pin sockets, they are most likely all low profile types now. Unless Dave knows differently...
The only way to reduce height any further, is to use bigger holes in the board so that socket fits lower or use the expensive special PCB socket strips which also need larger PCB holes.
Post by daveejhitchins » Fri Sep 11, 2020 12:08 pm
Hi Dave,
Greetings,
Roland
I'm sure I have some . . . take a look today.
Dave H.
Post by daveejhitchins » Fri Sep 11, 2020 12:11 pm
It's the PLCC sockets that are the main culprits. Phill (Prime) pointed the way for low profile mounting of DIL parts (see his MRB).
Dave H.
Post by Elminster » Sat Sep 12, 2020 9:27 am
Reuse is the name of the game. I am all cased our doing cases, onto reorganising my garage with aid of a skip at the moment. Hoping I can relocate 3D print there is I seal draft and rehouse spiders.
