NEED JOY STICK
drfloyd
NEED JOY STICK
Post by drfloyd »
So difficult to play without Stick on my Master 128
And the official sticks are very rare... on EBay i need to spend40-50£ + shipping to France !!!!!!!!!
Is this a solution :
https://monsterjoysticks.com/retro-joys ... on-adapter
I have some ATARI stick (like Speedking)
will it be compatible ?
Re: NEED JOY STICK
Post by tricky »
They look like they should be OK and are cheaper than mine ;)
There are some that won't fit with an RGB cable on a Master, but that looks narrow enough, you could ask before buying.
drfloyd
Re: NEED JOY STICK
Post by drfloyd »
i ask if it fit with a RGB cable ? (strange?)
OK thanks, i ask
Kazzie
Re: NEED JOY STICK
Post by Kazzie »
drfloyd wrote:
Sat Jul 04, 2020 2:05 pm
OK thanks, i ask
It's because the RGB connector on the Master is very close to the Analogue (joystick) connector, closer than on the Model B. If there is a big box at the end of the joystick, it may block the RGB connector.
RiscPC 600 under repair
Re: NEED JOY STICK
Post by tricky »
That one looks fine, but I do know that there is one that doesn't fit, but I don't know which one!
drfloyd
Re: NEED JOY STICK
Post by drfloyd »
I am waiting for the reply of the website
drfloyd
Re: NEED JOY STICK
Post by drfloyd »
they do not reply to my request... so I hesitate to order this cheap adapatator
Re: NEED JOY STICK
Post by tricky »
It'll probably be OK and it does say compatible with master, so you could probably ask for a refund if it isn't.
drfloyd
Re: NEED JOY STICK
Post by drfloyd »
is these joysticks good ? As they are sold "not tested" I hesitate :
Good for Elite perhaps ? But for arcade games ? it is better to buy an adapter Atari ?
Re: NEED JOY STICK
Post by RobC »
I have a pair of those but don't really like them. They are okay for Elite (as you suggest) but I prefer the Voltmace ones.
For arcade games, I use the BBC version of the Competition Pro or Zipstick.
drfloyd
Re: NEED JOY STICK
Post by drfloyd »
ok, so not good for arcade
Julz
Re: NEED JOY STICK
Post by Julz »
If it's any use to you, I have a spare Voltmace. I was only using it the other day when I got my BeeB back from RetroClinic.
If you're interested, I'll plug into the back on my Master 128 to see if it fits OK without clashing with the RGB socket.
