Here's Rev 2 of my user port extender, with the extra mounting holes to secure the MicroSD card adaptor if you want to use user port for MicroSD card based floppy drive. With the use of a couple of stand off pillars, the MicroSD adaptor is now held securely in place. Many thanks to Wheel_nut for posting a few of these pillars to me for testing.
As with the original user port extender, the primary purpose of this board is to provide a power pass through feature from the user port, whilst still being able to connect a cable to the user port for it's original intended purpose. The ability to directly connect a MicroSD card adaptor was a secondary benefit.
As before, it is important to stress that if you want to use the MicroSD card adaptor with this user port extender, then you shouldn't try plugging an additional user port device into the extension connector at the same time. That would be the same as trying to plug two devices into the user port at the same time!
Also, this board is not to be confused with the 'Universal' MicroSD adaptor board that I designed for Wheel-nut. The purpose of that board is solely to interface a MicroSD card adaptor to either the User port or the Printer port using the same adaptor board. That board does NOT have any User port pass through capability.
Here's a photo showing the User port extender without the MicroSD adaptor plugged in. Note that the cut out notch in the PCB is so that the board can clear the securing lugs on the User port connector:
- User port extender. Can you spot the stupid silk screen error???
and here's a couple of photos showing the User port extender with the MicroSD adaptor plugged in, and the pass through power cable connected:
- User port extender with MicroSD card adaptor plugged in
- ...and the underside of the User port extender
and here's a couple of photos showing the board plugged into the Master. I've shown it with a printer cable plugged into the printer port, and PiTubeDirect and Pi1MHz plugged into the Tube port and 1MHz port respectively to show how everything can be plugged in at the same time:
- Master: Close up of User port extender with MicroSD card adaptor plugged in plus a cable connected to the printer port
- Master:...and also with a couple of PiZeros for TubePiZero and PI1MHz
And finally, the same on the beeb. There's much more space under the beeb than there is in the Master:
- Beeb: Close up of User port extender with MicroSD card adaptor plugged in plus a cable connected to the printer port
- Beeb:...and also with a couple of PiZeros for TubePiZero and PI1MHz
