8271 disc controller de-cap and craziness -- do not try this at home!
Re: 8271 disc controller craziness -- do not try this at home!
Post by daveejhitchins »
Why not use both avenues? Just in case . . . And wouldn't a working part be better to de-cap? Or wouldn't it matter?
Pernod
Post by Pernod »
Thanks to BeebMaster for donating the 8271's and Sean Riddle for decapping them, we now have preliminary pics at www.seanriddle.com/8271.
scarybeasts
Post by scarybeasts »
What a treat!
It's a beautiful picture but I have no real idea what I'm looking at. Anyone have any thoughts?
Chris
Post by BigEd »
Certainly looks like a microcontroller - and the ROM looks readily decodable.
Here's a smaller version, for looking around - my computer can't deal with the full size:
https://www.dropbox.com/s/shkcidjtxl2t0 ... r.jpg?dl=0
guesser
Post by guesser »
It does look somewhat micro-controller-ey, but my level of expertise is at the "enjoys reading Ken Shirriff's blog" level.
The bottom left corner looks rather ROM-like. There's a big array and a small one (microcode ROM and instruction decoding ROM?)
It does say "© intel 1978 μCODE" next to it but whether that means anything I've no idea. :lol:
Post by BigEd »
I might have over-played my confidence there, but perhaps wiser heads can chip in.
Post by Rich Talbot-Watkins »
Great job! =D>
Don't really make much sense of it either, other than that there seems to be various ROM-like bits in the bottom left and the top right, and what looks a bit like RAM or registers bottom right and top left. There are also various other regular looking structures which also look a bit like ROMs of some sort.
What I can't find are the (at least) 35 8-bit "special registers" which we always assumed were equivalent to the microcontroller on-board RAM.
dp11
Post by dp11 »
bottom left looks like 256 bytes of ROM.
Post by BigEd »
That thing bottom right could be 22 bytes of register. Maybe, just maybe, 44.
guesser
Post by guesser »
Counting things and guessing wildly (username checks out etc :lol:) the registery stuff in the bottom right looks 16 bits wide, and there's 10 rows the same with some more 16 bit wide things of a different design.
The big ROM-thing is vaguely binary-ish down the left side, but only has 54 rows and some combinations appear duplicated so not sure what's going on there. The columns are grouped into 8 groups of 4.
The smaller one to the side seems to be 82 x 10.
There's another 10 bit wide structure above the ROM-thing.
Top left looks like eight 8-bit wide registery-things.
I look forward to reading how wrong I was when someone who knows what they're doing looks at it :D
dp11
Post by dp11 »
I wonder if the 10 bit structure is either a timer or divider ?
dp11
Post by dp11 »
have we actually got two different controllers ? one at the top and one at the bottom ?
There's another ROM-like structure kind of centre-right which has exactly 64 columns. No idea what that might be either.
dp11
Post by dp11 »
My guess in right hand side power pad in GND with the data bus going down and around the corner
Diminished
Post by Diminished »
Pretty.
If it's a microcontroller, or a microprocessor, do we have any guess as to what kind? I don't think there can have been too many candidates back then.
Perhaps one of these:
https://en.wikipedia.org/wiki/Intel_MCS-48
Or there were the proper CPU cores available at that time. Here are the 4-bit ones:
https://en.wikipedia.org/wiki/List_of_I ... processors
The 8271 data sheet itself mentions that the 8271 is compatible with the MCS-80 and MCS-85, so those chips were presumably around at the same time? Wikipedia thinks the MCS-80 was based on an 8080. The 8-bit ones are here:
I don't know if we can find die shots of any of these to compare.
Also, perhaps this might be worth keeping in mind:
guesser
Post by guesser »
I was looking at die shots of the intel microcontrollers earlier. Couldn't find any similar, but of course there's only odd ones online.
Diminished
The bus in the top-left is interesting. I'm wondering if this is the "internal data bus" mentioned in the block diagram:
https://drive.google.com/file/d/19b-AsH ... sp=sharing
It continues across the width of the chip and no doubt connects up to various other things.
(Disclaimer: I have absolutely no idea what I am doing)
dp11
Post by dp11 »
Anyone go any good ways of us group working on identifying bits of this chip ?
The data sheet says it has a 16bit CRC generator. I haven't yet spotted a 16bit structure.
Dominic
Post by BeebMaster »
This is very exciting, and all happened before I got the chance to say "it's been delivered today"!
Can anyone open the 120MB picture?
guesser
Post by guesser »
I think there's a limit to what can be done by looking for repeating structures in the metal layer. To work out what all the messy logic stuff is doing would need another image of the silicon with the appropriate illumination to discern the doped regions etc. (Plus someone competent at reversing gates from transistors!)
I seem to remember there being a way for newbies to contribute to reversing chips by tracing over the layers for a chunked up set of die shots, that's then processed into transistors and gates semi-automatically, guided by someone who knows what they're looking at. I think it was probably part of the visual6502 project?
guesser
Post by guesser »
BeebMaster wrote:
Fri Aug 21, 2020 12:06 pm
I opened it in irfanview. Very slowly 😃
There's a new picture in that link now as well, the previous one everyone has been looking at so far is an 8271-6 variety, I also sent an 8271 which has now been photographed.
There's no hope on the Pi4, but my laptop loaded the big pictures in GThumb no problem in a few seconds.
Pernod
Post by Pernod »
BeebMaster wrote:
Fri Aug 21, 2020 12:10 pm
Some notes from Sean:
One of the die shots is out there now and I’ll upload the other later today. The 2 dies look identical to me, but I haven’t compared them closely yet.
I’m not sure how I’ll remove the top metal layer; I normally put the die in a test tube with Whink and heat that in boiling water, but the die is stuck to the ceramic bottom and that’s too large to put in a test tube. I’ll figure something out.
I copied the pic of the 2nd die out to the same folder. I’ll do some more work this weekend.
Oh, and there's a 8272 at www.seanriddle.com/8272metal.jpg if anyone's interested.
Post by BigEd »
There was a brief effort at crowdsourcing polygon capture within the visual6502 world, but it didn't come to anything.
Best results have come from individuals putting in the hours, using a tool like Inkscape or a photo editors.
Diminished
Diminished wrote:
Fri Aug 21, 2020 11:47 am
Furthermore, these look like the connections from the bus to the big ROM looking thing in the bottom left. 8 bits seem to be tapped off the bus, and each bit makes four connections to the top of that structure, making it some sort of 8x4 thing:
https://drive.google.com/file/d/1YNsx49 ... sp=sharing
Hard to see the vertical lines from this photo. There's probably some logic there in between the bus taps and the ROM thing.
guesser
Post by guesser »
It's hard to tell because the 8271 image is dirty and a couple of the "bits" are completely obscured, but the big ROM in the bottom left looks identical to me. There's one bit that looks different but I think it's an illusion caused by a spec of dirt.
guesser
Post by guesser »
BigEd wrote:
Fri Aug 21, 2020 12:36 pm
I was just thinking in terms of several people not all starting vectorising the same part of the chip in an incompatible format :)
guesser
Post by guesser »
I must say I find this stuff fascinating and have been well and truly nerd-sniped :lol:
English Invader
Post by English Invader »
I tried to open the first picture in the list and it froze up my system :lol:.
May I ask why this is of interest to the MAME community?
