Re: 8271 disc controller de-cap and craziness -- do not try this at home!
Post by Rich Talbot-Watkins » Thu Sep 10, 2020 5:17 pm
guesser wrote:
Thu Sep 10, 2020 5:06 pm
I think the second one from the left table has an error. The bits are 0000xxxx, not 0001xxxx. The '0' select line folds around from underneath the next row of bits.
Yes, that would make sense as there's already a 0001xxxx on the left hand side (and there isn't a 0000xxxx). It didn't make any difference to determining the opcode groups, thankfully!
Diminished
Post by Diminished » Thu Sep 10, 2020 5:48 pm
Rich Talbot-Watkins wrote:
Thu Sep 10, 2020 5:15 pm
Register banks are selected by opcodes $00...$0F. Each bank is 8 registers, so opcode $02 would suggest a base register of $10.
I see!
Now I said there were 32 internal registers, but this is literally only half the story! Because if you select register bank 4 (a base of $20), you get access to I/O ports which are mapped to registers $20...$27 (and mirrored every 8...): this was not just an abstraction in the read/write special register command, but is actually presented like this at the MPU level. Not only are the drive control ports here, but the bit processor functionality is exposed here too, for performing the actual bit serialization tasks, all appearing like simple basic registers!
I was really hoping for something like this. Are they writeable, then? Can you just bypass the byte processor, and program the bit processor directly? Because that would be rad.
The register banks (opcodes $00...$0F) have a second, perhaps primary, use: they specify the 4 bit segment index used as part of the key which jumping to one of the preset entry points. We don't fully understand all the mechanisms which exist for this, but one which is well understood is the opcode $EE which jumps to the entry point keyed by (2, RB, *) where 2 is the 2-bit ID, RB is the 4-bit selected register bank, and * is a "don't care" in this case.
So the register banks map to the segments? I know the patent alludes to a mechanism something like this.
I'm a little confused by which way around you're naming routines and segments. In your model, does each segment contain multiple routines, or does each routine contain multiple segments? I thought the patent named it the latter way round (i.e. one routine has multiple segments) ... but it seems weird to have an entrypoint that is wildcarded on routine ID, but requires a specific segment ID. Meh.
Post by Rich Talbot-Watkins » Thu Sep 10, 2020 6:14 pm
Externally you could "write special register" and hit the bit processor directly, yes; whether the latency involved in that round trip would let you do anything sensible is another question! But first we need to understand what all these various registers actually do!
The byte processor ROM liberally performs operations on those registers as if they were any other. Stuff like AND I0, #imm (which is doing the equivalent of a read-modify-write in one cycle!).
There's an opcode $EC, which is used by the command dispatcher. It takes the current register bank, and the command ID in the accumulator and jumps to (0, RB, A) (which I have documented as (2-bit page, segment, routine)). In this case it makes sense.
Then there's an opcode $EE ,which is used to jump to any entry point anywhere in the ROM, which goes to (2, RB, -). In this case the RB ("segment") is actually more kind of providing the routine.
And then there's the event/task system. We're only just starting to understand this, and it's this which makes me think that segments and routines are the wrong way round. Each event (of which there are 8 possible ones) corresponds to a seemingly hardcoded (page, segment). There are a set of registers into which you put the id of the routine you want it to jump to when the event occurs. On top of this, the opcodes $10-$1F seem to allow you to busy wait for the next event and then jump to routine x of $1x in the current task. This makes more sense with segments and routines the other way round.
Honestly, I haven't changed it in the doc so far for fear of further confusion, but we'll try and get the names sorted out once this stuff is better understood.
Diminished
Post by Diminished » Thu Sep 10, 2020 6:22 pm
Fascinating.
Might be better just to forget the patent and pick new names.
Diminished
Post by Diminished » Thu Sep 10, 2020 7:00 pm
In less groundbreaking news, I appear now to have code which can successfully decode the inputs to the address PLA from a marked-up image of the bits, and handle the don't-cares gracefully (slightly more annoying than I expected), so I'm set up for if and when we get a better 8273 pic. The good news is that with respect to the 8271 there don't appear to have been any mistakes in what guesser and me produced last time:
$ php -f 8273/interpret_pc_table_raw_bits.php
row 0: (0, 3, 4)
row 1: (0, 2, 13)
row 2: (0, 2, 4)
row 3: (0, 2, 5)
row 4: (0, 2, 6)
row 5: (0, 2, 7)
row 6: (0, 2, 2)
row 7: (0, 2, 3)
row 8: (0, 2, 8)
row 9: (0, 2, 10)
row 10: (0, 2, 0)
row 11: (0, 2, 1)
row 12: (0, 2, 11)
row 13: (0, 2, 14)
row 14: (0, 2, 15)
row 15: (0, 1, 0)
row 16: (0, 1, 1)
row 17: (0, 1, 2)
row 18: (0, 1, 3)
row 19: (0, 1, 4)
row 20: (0, 1, 5)
row 21: (0, 1, 6)
row 22: (0, 1, 7)
row 23: (0, 1, 8)
row 24: (0, 1, 9)
row 25: (0, 1, 10)
row 26: (0, 1, 11)
row 27: (1, 1, 8) -> (1, 1, 15)
row 28: (1, 1, 0) -> (1, 1, 7)
row 29: (1, 2, 8)
row 30: (1, 2, 3)
row 31: (1, 2, 5)
row 32: (1, 2, 10)
row 33: (1, 2, 11)
row 34: (1, 3, 0), (1, 3, 8)
row 35: (1, 3, 1), (1, 3, 9)
row 36: (1, 3, 2), (1, 3, 10)
row 37: (1, 3, 3), (1, 3, 11)
row 38: (1, 3, 4), (1, 3, 12)
row 39: (1, 3, 5), (1, 3, 13)
row 40: (2, 0, 0) -> (2, 0, 15)
row 41: (2, 1, 0) -> (2, 1, 15)
row 42: (2, 2, 0) -> (2, 2, 15)
row 43: (2, 3, 0) -> (2, 3, 15)
row 44: (2, 4, 0) -> (2, 4, 15)
row 45: (2, 5, 0) -> (2, 5, 15)
row 46: (2, 6, 0) -> (2, 6, 15)
row 47: (2, 7, 0) -> (2, 7, 15)
row 48: (2, 8, 0) -> (2, 8, 15)
row 49: (2, 9, 0) -> (2, 9, 15)
row 50: (2, 10, 0) -> (2, 10, 15)
row 51: (2, 11, 0) -> (2, 11, 15)
row 52: (2, 12, 0) -> (2, 12, 15)
row 53: (2, 13, 0) -> (2, 13, 15)
row 54: (2, 14, 0) -> (2, 14, 15)
row 55: (2, 15, 0) -> (2, 15, 15)
row 56: (3, 2, 0) -> (3, 2, 15)
row 57: (3, 3, 0) -> (3, 3, 15)
row 58: (3, 8, 0) -> (3, 8, 15)
row 59: (3, 13, 0) -> (3, 13, 15)
row 60: (3, 9, 0), (3, 9, 2), (3, 9, 8), (3, 9, 10)
row 61: (3, 9, 1), (3, 9, 3), (3, 9, 9), (3, 9, 11)
row 62: (3, 9, 4) -> (3, 9, 7), (3, 9, 12) -> (3, 9, 15)
row 63: (3, 4, 0)
row 64: (3, 4, 1)
row 65: (3, 4, 2)
row 66: (3, 4, 3)
row 67: (3, 4, 4)
row 68: (3, 4, 5)
row 69: (3, 4, 8)
row 70: (3, 5, 0)
row 71: (3, 5, 1)
row 72: (3, 5, 5)
row 73: (3, 5, 10) -> (3, 5, 11)
row 74: (3, 7, 0)
row 75: (3, 7, 1)
row 76: (3, 7, 3)
row 77: (3, 7, 5)
row 78: (3, 7, 6)
row 79: (3, 7, 8)
row 80: (3, 11, 0) -> (3, 11, 15)
row 81: (3, 12, 0) -> (3, 12, 15)
I'll do the output table in a bit -- should be easier than this.
Edit: checked the PC table -- again, the existing readout is fine, and I have another script all ready for the 8273.
Diminished
Post by Diminished » Thu Sep 10, 2020 8:32 pm
This should be a pretty accurate rendition of the 8273's entrypoints -- the output table was much easier to read than the input one.
0x30
0x3a
0x27
0x1a8
0x10c
0x1a8
0x119
0x11f
0x120
0x1a2
0x197
0x19b
0x173
0x1c3
0x180
0x308
0x299
0x2e3
0x2f2
0x332
0x2ff
0x302
0x305
0x2fc
0x356
0x340
0x91
0x9a
0x31c
0x323
0x122
0x151
0x16f
0x158
0x20f
0x1a9
0xd4
0x380
0x390
0x3a0
0x0
0x100
0x200
0x300
0xe0
0xe0
0xff
0xe5
0xfa
0xf3
0x200
0x1f5
0x104
0x109
0x11c
0x11c
0x170
0x1fc
0x2fa
0x24b
0x26f
0x27d
0x281
0x288
0x260
0x290
0x2a2
0x2a9
0x2ad
0x2b6
0x2c6
0x2d0
0x2c9
0x2ef
0x63
0x19
0x4c
0x4f
0x58
0x20b
0x20e
0xa6
If anyone wants the (very provisional) ROM image (since I only posted it in unhelpful hex before), here you go:
(edit: updated with six bytes fixed, see here)
I'll try to check my markup of the bits at some point, but there are thousands of them and I'm feeling indolent. Maybe we'll get another 8273 snap this weekend.
Diminished
Post by Diminished » Thu Sep 10, 2020 11:35 pm
Quick and dirty bash at the 8273.
I was hoping there might be an EF in here, but it doesn't look like there is.
; entrypoint:
000    04         SEL RB 4
001    f0 08      MOV I0, #0x8
003    f4 00      MOV I4, #0x0
005    f5 ff      MOV I5, #0xff
007    b8 00      ???, #0x0
009    b9 00      ???, #0x0
00b    bb 00      ???, #0x0
00d    bc 01      ???, #0x1
00f    c8 f7      AND I0, #0xf7
011    02         SEL RB 2
012    cf c0      AND I7, #0xc0
014    f1 00      MOV I1, #0x0
016    f0 00      MOV I0, #0x0
018    ff         YIELD
; entrypoint:
019    03         SEL RB 3
01a    2e         MOV A, I14
01b    00         SEL RB 0
01c    e8         MOV [I0], A
01d    00         SEL RB 0
01e    80         ADC A, I0
01f    a1         DEC I1
020    88 23      BMI 0x023
022    ff         YIELD
023    03         SEL RB 3
024    2f         MOV A, I15
025    00         SEL RB 0
026    ec         SYS 0, RB, A
; entrypoint:
027    a9         ???
028    9c 0f      AND A, #0xf
02a    8b 49      BNZ 0x049
02c    b9 01      ???, #0x1
02e    fe 49      JMP 0x049
; entrypoint:
030    ab         ???
031    9c 0f      AND A, #0xf
033    8a 47      BZ 0x047
035    02         SEL RB 2
036    d8 20      OR I0, #0x20
038    fe 49      JMP 0x049
; entrypoint:
03a    02         SEL RB 2
03b    71 01 47   TBNZ I1, #0x1, 0x047
03e    d9 01      OR I1, #0x1
040    f5 7e      MOV I5, #0x7e
042    04         SEL RB 4
043    dc 90      OR I4, #0x90
045    f5 7e      MOV I5, #0x7e
047    bb 02      ???, #0x2
049    fc a2      CALL 0x0a2
04b    11         WAIT 1
; entrypoint:
04c    03         SEL RB 3
04d    2e         MOV A, I14
04e    ff         YIELD
; entrypoint:
04f    fc 5e      CALL 0x05e
051    03         SEL RB 3
052    d6         OR A, I6
053    00         SEL RB 0
054    e1         XOR A, I1
055    e8         MOV [I0], A
056    fe 49      JMP 0x049
; entrypoint:
058    fc 5e      CALL 0x05e
05a    03         SEL RB 3
05b    c6         AND A, I6
05c    fe 53      JMP 0x053
05e    00         SEL RB 0
05f    f8         MOV A, [I0]
060    00         SEL RB 0
061    e1         XOR A, I1
062    fd         RET
; entrypoint:
063    02         SEL RB 2
064    cf bf      AND I7, #0xbf
066    2f         MOV A, I15
067    f9         SHL A
068    89 70      BPL 0x070
06a    f9         SHL A
06b    89 70      BPL 0x070
06d    2f         MOV A, I15
06e    0a         SEL RB 10
06f    ec         SYS 0, RB, A
070    2f         MOV A, I15
071    00         SEL RB 0
072    30         MOV I0, A
073    c8 3f      AND I0, #0x3f
075    40 23 7c   BEQ I0, #0x23, 0x07c
078    f1 00      MOV I1, #0x0
07a    fe 7e      JMP 0x07e
07c    f1 ff      MOV I1, #0xff
07e    03         SEL RB 3
07f    6f c0 8b   TBZ I15, #0xc0, 0x08b
082    7f 40 88   TBNZ I15, #0x40, 0x088
085    bc 02      ???, #0x2
087    ff         YIELD
088    bc 03      ???, #0x3
08a    ff         YIELD
08b    fc 5e      CALL 0x05e
08d    02         SEL RB 2
08e    36         MOV I6, A
08f    fe 49      JMP 0x049
; entrypoint:
091    02         SEL RB 2
092    cf ef      AND I7, #0xef
094    b9 00      ???, #0x0
096    11         WAIT 1
097    39         MOV I9, A
098    fe 49      JMP 0x049
; entrypoint:
09a    01         SEL RB 1
09b    38         MOV I8, A
09c    fc a2      CALL 0x0a2
09e    98 10      MOV A, #0x10
0a0    fe d4      JMP 0x0d4
0a2    02         SEL RB 2
0a3    cf 7f      AND I7, #0x7f
0a5    fd         RET
; entrypoint:
0a6    70 04 af   TBNZ I0, #0x4, 0x0af
0a9    62 02 b0   TBZ I2, #0x2, 0x0b0
0ac    62 01 be   TBZ I2, #0x1, 0x0be
0af    ff         YIELD
0b0    a9         ???
0b1    9c 0e      AND A, #0xe
0b3    8a af      BZ 0x0af
0b5    98 0a      MOV A, #0xa
0b7    fc bc      CALL 0x0bc
0b9    b9 00      ???, #0x0
0bb    ff         YIELD
0bc    01         SEL RB 1
0bd    ee         SYS 2, RB
0be    ab         ???
0bf    01         SEL RB 1
0c0    3b         MOV I11, A
0c1    4b f0 af   BEQ I11, #0xf0, 0x0af
0c4    4b f1 af   BEQ I11, #0xf1, 0x0af
0c7    4b f2 af   BEQ I11, #0xf2, 0x0af
0ca    5b ff d2   BNE I11, #0xff, 0x0d2
0cd    aa         ???
0ce    9c 0f      AND A, #0xf
0d0    89 af      BPL 0x0af
0d2    98 0f      MOV A, #0xf
; entrypoint:
0d4    01         SEL RB 1
0d5    d8 00      OR I0, #0x0
0d7    06         SEL RB 6
0d8    34         MOV I4, A
0d9    cf df      AND I7, #0xdf
0db    bb 0f      ???, #0xf
0dd    ba 03      ???, #0x3
0df    ff         YIELD
; entrypoint:
0e0    cf f7      AND I7, #0xf7
0e2    b8 00      ???, #0x0
0e4    fd         RET
; entrypoint:
0e5    28         MOV A, I8
0e6    33         MOV I3, A
0e7    61 04 ed   TBZ I1, #0x4, 0x0ed
0ea    b8 02      ???, #0x2
0ec    fd         RET
0ed    70 08 f7   TBNZ I0, #0x8, 0x0f7
0f0    b8 05      ???, #0x5
0f2    fd         RET
; entrypoint:
0f3    22         MOV A, I2
0f4    33         MOV I3, A
0f5    fe ed      JMP 0x0ed
0f7    b8 06      ???, #0x6
0f9    fd         RET
; entrypoint:
0fa    2a         MOV A, I10
0fb    33         MOV I3, A
0fc    b8 01      ???, #0x1
0fe    fd         RET
; entrypoint:
0ff    29         MOV A, I9
; entrypoint:
100    33         MOV I3, A
101    b8 03      ???, #0x3
103    fd         RET
; entrypoint:
104    21         MOV A, I1
105    02         SEL RB 2
106    c8 fb      AND I0, #0xfb
108    ff         YIELD
; entrypoint:
109    21         MOV A, I1
10a    04         SEL RB 4
10b    ec         SYS 0, RB, A
; entrypoint:
10c    02         SEL RB 2
10d    60 04 a8   TBZ I0, #0x4, 0x1a8
110    c8 fb      AND I0, #0xfb
112    98 05      MOV A, #0x5
114    fc a9      CALL 0x1a9
116    b8 05      ???, #0x5
118    10         WAIT 0
; entrypoint:
119    fc bd      CALL 0x1bd
11b    12         WAIT 2
; entrypoint:
11c    21         MOV A, I1
11d    05         SEL RB 5
11e    ec         SYS 0, RB, A
; entrypoint:
11f    11         WAIT 1
; entrypoint:
120    00         SEL RB 0
121    ed         ???
; entrypoint:
122    26         MOV A, I6
123    01         SEL RB 1
124    36         MOV I6, A
125    49 c0 31   BEQ I9, #0xc0, 0x131
128    26         MOV A, I6
129    e6         XOR A, I6
12a    8a 31      BZ 0x131
12c    26         MOV A, I6
12d    e7         XOR A, I7
12e    8a 36      BZ 0x136
130    11         WAIT 1
131    02         SEL RB 2
132    c8 ef      AND I0, #0xef
134    fe 39      JMP 0x139
136    02         SEL RB 2
137    d8 10      OR I0, #0x10
139    01         SEL RB 1
13a    59 c2 50   BNE I9, #0xc2, 0x150
13d    04         SEL RB 4
13e    f5 7e      MOV I5, #0x7e
140    dc 90      OR I4, #0x90
142    02         SEL RB 2
143    d9 01      OR I1, #0x1
145    f5 7e      MOV I5, #0x7e
147    ab         ???
148    9c 0f      AND A, #0xf
14a    8b 50      BNZ 0x150
14c    bb 0f      ???, #0xf
14e    ba 02      ???, #0x2
150    13         WAIT 3
; entrypoint:
151    26         MOV A, I6
152    00         SEL RB 0
153    37         MOV I7, A
154    02         SEL RB 2
155    71 04 6e   TBNZ I1, #0x4, 0x16e
; entrypoint:
158    a8         ???
159    9c 0f      AND A, #0xf
15b    8b a9      BNZ 0x1a9
15d    00         SEL RB 0
15e    27         MOV A, I7
15f    0a         SEL RB 10
160    df 10      OR I7, #0x10
162    32         MOV I2, A
163    d8 04      OR I0, #0x4
165    00         SEL RB 0
166    26         MOV A, I6
167    03         SEL RB 3
168    3a         MOV I10, A
169    f0 00      MOV I0, #0x0
16b    f1 00      MOV I1, #0x0
16d    19         WAIT 9
16e    14         WAIT 4
; entrypoint:
16f    15         WAIT 5
; entrypoint:
170    21         MOV A, I1
171    07         SEL RB 7
172    ec         SYS 0, RB, A
; entrypoint:
173    fc bd      CALL 0x1bd
175    98 03      MOV A, #0x3
177    fc a9      CALL 0x1a9
179    b8 05      ???, #0x5
17b    12         WAIT 2
17c    98 07      MOV A, #0x7
17e    fe 77      JMP 0x177
; entrypoint:
180    03         SEL RB 3
181    81         ADC A, I1
182    90         ???
183    01         SEL RB 1
184    a4         DEC I4
185    b5         ???
186    88 90      BMI 0x190
188    2c         MOV A, I12
189    d5         OR A, I5
18a    8b 6d      BNZ 0x16d
18c    02         SEL RB 2
18d    cf ef      AND I7, #0xef
18f    ff         YIELD
190    98 09      MOV A, #0x9
192    fc a9      CALL 0x1a9
194    b8 05      ???, #0x5
196    10         WAIT 0
; entrypoint:
197    02         SEL RB 2
198    61 20 a2   TBZ I1, #0x20, 0x1a2
; entrypoint:
19b    98 04      MOV A, #0x4
19d    fc a9      CALL 0x1a9
19f    b8 05      ???, #0x5
1a1    11         WAIT 1
; entrypoint:
1a2    02         SEL RB 2
1a3    98 06      MOV A, #0x6
1a5    71 10 14   TBNZ I1, #0x10, 0x114
; entrypoint:
1a8    ff         YIELD
; entrypoint:
1a9    02         SEL RB 2
1aa    cf ef      AND I7, #0xef
1ac    01         SEL RB 1
1ad    3a         MOV I10, A
1ae    a8         ???
1af    9c 0f      AND A, #0xf
1b1    8a b7      BZ 0x1b7
1b3    02         SEL RB 2
1b4    d8 08      OR I0, #0x8
1b6    10         WAIT 0
1b7    2a         MOV A, I10
1b8    02         SEL RB 2
1b9    33         MOV I3, A
1ba    df 08      OR I7, #0x8
1bc    fd         RET
1bd    04         SEL RB 4
1be    cb df      AND I3, #0xdf
1c0    db 20      OR I3, #0x20
1c2    fd         RET
; entrypoint:
1c3    02         SEL RB 2
1c4    cf ef      AND I7, #0xef
1c6    fc bd      CALL 0x1bd
1c8    03         SEL RB 3
1c9    78 ff e2   TBNZ I8, #0xff, 0x1e2
1cc    29         MOV A, I9
1cd    01         SEL RB 1
1ce    3a         MOV I10, A
1cf    02         SEL RB 2
1d0    71 04 da   TBNZ I1, #0x4, 0x1da
1d3    01         SEL RB 1
1d4    a2         DEC I2
1d5    88 7c      BMI 0x17c
1d7    a2         DEC I2
1d8    88 7c      BMI 0x17c
1da    01         SEL RB 1
1db    7a ff e2   TBNZ I10, #0xff, 0x1e2
1de    04         SEL RB 4
1df    56 e0 7c   BNE I6, #0xe0, 0x17c
1e2    04         SEL RB 4
1e3    26         MOV A, I6
1e4    01         SEL RB 1
1e5    3a         MOV I10, A
1e6    98 01      MOV A, #0x1
1e8    02         SEL RB 2
1e9    70 10 ee   TBNZ I0, #0x10, 0x1ee
1ec    98 00      MOV A, #0x0
1ee    01         SEL RB 1
1ef    d2         OR A, I2
1f0    fc ac      CALL 0x1ac
1f2    b8 04      ???, #0x4
1f4    12         WAIT 2
; entrypoint:
1f5    98 08      MOV A, #0x8
1f7    fc a9      CALL 0x1a9
1f9    b9 00      ???, #0x0
1fb    ff         YIELD
; entrypoint:
1fc    98 0e      MOV A, #0xe
1fe    02         SEL RB 2
1ff    ee         SYS 2, RB
; entrypoint:
200    cf f7      AND I7, #0xf7
202    f3 0b      MOV I3, #0xb
204    df 08      OR I7, #0x8
206    c8 f7      AND I0, #0xf7
208    b8 05      ???, #0x5
20a    fd         RET
; entrypoint:
20b    02         SEL RB 2
20c    cf fb      AND I7, #0xfb
; entrypoint:
20e    ff         YIELD
; entrypoint:
20f    02         SEL RB 2
210    71 01 19   TBNZ I1, #0x1, 0x219
213    f5 ff      MOV I5, #0xff
215    04         SEL RB 4
216    f5 ff      MOV I5, #0xff
218    fd         RET
219    f5 7e      MOV I5, #0x7e
21b    04         SEL RB 4
21c    f5 7e      MOV I5, #0x7e
21e    fd         RET
21f    04         SEL RB 4
220    70 01 29   TBNZ I0, #0x1, 0x229
223    f5 55      MOV I5, #0x55
225    02         SEL RB 2
226    f5 55      MOV I5, #0x55
228    fd         RET
229    f5 00      MOV I5, #0x0
22b    02         SEL RB 2
22c    f5 00      MOV I5, #0x0
22e    fd         RET
22f    01         SEL RB 1
230    48 c9 36   BEQ I8, #0xc9, 0x236
233    04         SEL RB 4
234    dc 04      OR I4, #0x4
236    00         SEL RB 0
237    a2         DEC I2
238    b3         ???
239    02         SEL RB 2
23a    89 45      BPL 0x245
23c    cf df      AND I7, #0xdf
23e    00         SEL RB 0
23f    f3 00      MOV I3, #0x0
241    f2 00      MOV I2, #0x0
243    ea         SEC
244    fd         RET
245    df 20      OR I7, #0x20
247    d8 02      OR I0, #0x2
249    eb         CLC
24a    fd         RET
; entrypoint:
24b    63 01 53   TBZ I3, #0x1, 0x253
24e    cb fe      AND I3, #0xfe
250    02         SEL RB 2
251    c8 fe      AND I0, #0xfe
253    04         SEL RB 4
254    70 04 5b   TBNZ I0, #0x4, 0x25b
257    72 01 5b   TBNZ I2, #0x1, 0x25b
25a    11         WAIT 1
25b    02         SEL RB 2
25c    61 02 60   TBZ I1, #0x2, 0x260
25f    15         WAIT 5
; entrypoint:
260    bb 07      ???, #0x7
262    01         SEL RB 1
263    48 c9 6a   BEQ I8, #0xc9, 0x26a
266    02         SEL RB 2
267    71 04 8f   TBNZ I1, #0x4, 0x28f
26a    02         SEL RB 2
26b    71 80 81   TBNZ I1, #0x80, 0x281
26e    14         WAIT 4
; entrypoint:
26f    02         SEL RB 2
270    c8 fd      AND I0, #0xfd
272    04         SEL RB 4
273    cc 6f      AND I4, #0x6f
275    73 01 4e   TBNZ I3, #0x1, 0x24e
278    02         SEL RB 2
279    d8 01      OR I0, #0x1
27b    fe 53      JMP 0x253
; entrypoint:
27d    cc 5b      AND I4, #0x5b
27f    f5 7e      MOV I5, #0x7e
; entrypoint:
281    fc 36      CALL 0x236
283    01         SEL RB 1
284    48 c9 a1   BEQ I8, #0xc9, 0x2a1
287    17         WAIT 7
; entrypoint:
288    fc 1f      CALL 0x21f
28a    bb 06      ???, #0x6
28c    61 80 62   TBZ I1, #0x80, 0x262
28f    ff         YIELD
; entrypoint:
290    cc 5b      AND I4, #0x5b
292    f5 7e      MOV I5, #0x7e
294    02         SEL RB 2
295    61 04 9f   TBZ I1, #0x4, 0x29f
298    18         WAIT 8
; entrypoint:
299    02         SEL RB 2
29a    f4 0d      MOV I4, #0xd
29c    ba 09      ???, #0x9
29e    ff         YIELD
29f    fc 36      CALL 0x236
2a1    1a         WAIT 10
; entrypoint:
2a2    00         SEL RB 0
2a3    24         MOV A, I4
2a4    04         SEL RB 4
2a5    35         MOV I5, A
2a6    fc 33      CALL 0x233
2a8    19         WAIT 9
; entrypoint:
2a9    00         SEL RB 0
2aa    25         MOV A, I5
2ab    04         SEL RB 4
2ac    35         MOV I5, A
; entrypoint:
2ad    fc 2f      CALL 0x22f
2af    89 a1      BPL 0x2a1
2b1    02         SEL RB 2
2b2    60 02 bd   TBZ I0, #0x2, 0x2bd
2b5    1b         WAIT 11
; entrypoint:
2b6    02         SEL RB 2
2b7    c8 df      AND I0, #0xdf
2b9    01         SEL RB 1
2ba    48 c9 cd   BEQ I8, #0xc9, 0x2cd
2bd    02         SEL RB 2
2be    61 08 c5   TBZ I1, #0x8, 0x2c5
2c1    f4 0c      MOV I4, #0xc
2c3    df 04      OR I7, #0x4
2c5    1c         WAIT 12
; entrypoint:
2c6    dc 60      OR I4, #0x60
2c8    1d         WAIT 13
; entrypoint:
2c9    cc db      AND I4, #0xdb
2cb    f5 7e      MOV I5, #0x7e
2cd    ba 00      ???, #0x0
2cf    1f         WAIT 15
; entrypoint:
2d0    cc bf      AND I4, #0xbf
2d2    02         SEL RB 2
2d3    70 20 d7   TBNZ I0, #0x20, 0x2d7
2d6    1e         WAIT 14
2d7    71 04 e1   TBNZ I1, #0x4, 0x2e1
2da    71 40 e2   TBNZ I1, #0x40, 0x2e2
2dd    df 20      OR I7, #0x20
2df    fc 36      CALL 0x236
2e1    17         WAIT 7
2e2    13         WAIT 3
; entrypoint:
2e3    f5 7e      MOV I5, #0x7e
2e5    cc 6f      AND I4, #0x6f
2e7    02         SEL RB 2
2e8    71 01 9e   TBNZ I1, #0x1, 0x29e
2eb    04         SEL RB 4
2ec    dc 80      OR I4, #0x80
2ee    10         WAIT 0
; entrypoint:
2ef    08         SEL RB 8
2f0    aa         ???
2f1    ec         SYS 0, RB, A
; entrypoint:
2f2    cc 4b      AND I4, #0x4b
2f4    ba 04      ???, #0x4
2f6    01         SEL RB 1
2f7    28         MOV A, I8
2f8    09         SEL RB 9
2f9    ec         SYS 0, RB, A
; entrypoint:
2fa    cc db      AND I4, #0xdb
; entrypoint:
2fc    fc 0f      CALL 0x20f
2fe    ff         YIELD
; entrypoint:
2ff    aa         ???
; entrypoint:
300    0b         SEL RB 11
301    ec         SYS 0, RB, A
; entrypoint:
302    f5 ff      MOV I5, #0xff
304    ff         YIELD
; entrypoint:
305    f5 7e      MOV I5, #0x7e
307    ff         YIELD
; entrypoint:
308    fc 3e      CALL 0x33e
30a    01         SEL RB 1
30b    48 ca 11   BEQ I8, #0xca, 0x311
30e    ba 01      ???, #0x1
310    ff         YIELD
311    02         SEL RB 2
312    f4 0d      MOV I4, #0xd
314    02         SEL RB 2
315    c9 fe      AND I1, #0xfe
317    04         SEL RB 4
318    dc 80      OR I4, #0x80
31a    fe 23      JMP 0x323
; entrypoint:
31c    01         SEL RB 1
31d    68 04 23   TBZ I8, #0x4, 0x323
320    ba 0b      ???, #0xb
322    ff         YIELD
; entrypoint:
323    02         SEL RB 2
324    70 01 2a   TBNZ I0, #0x1, 0x32a
327    04         SEL RB 4
328    db 01      OR I3, #0x1
32a    02         SEL RB 2
32b    df 04      OR I7, #0x4
32d    70 20 31   TBNZ I0, #0x20, 0x331
330    10         WAIT 0
331    12         WAIT 2
; entrypoint:
332    fc 3e      CALL 0x33e
334    02         SEL RB 2
335    c8 df      AND I0, #0xdf
337    01         SEL RB 1
338    48 ce 14   BEQ I8, #0xce, 0x314
33b    ba 09      ???, #0x9
33d    ff         YIELD
33e    00         SEL RB 0
33f    ee         SYS 2, RB
; entrypoint:
340    00         SEL RB 0
341    f0 02      MOV I0, #0x2
343    38         MOV I8, A
344    58 c9 4d   BNE I8, #0xc9, 0x34d
347    00         SEL RB 0
348    f1 01      MOV I1, #0x1
34a    bc 00      ???, #0x0
34c    ff         YIELD
34d    02         SEL RB 2
34e    61 04 47   TBZ I1, #0x4, 0x347
351    00         SEL RB 0
352    f1 03      MOV I1, #0x3
354    fe 4a      JMP 0x34a
; entrypoint:
356    00         SEL RB 0
357    39         MOV I9, A
358    f0 0c      MOV I0, #0xc
35a    49 c0 47   BEQ I9, #0xc0, 0x347
35d    f6 59      MOV I6, #0x59
35f    00         SEL RB 0
scarybeasts
Post by scarybeasts » Fri Sep 11, 2020 2:29 am
Wow! How very productive!
I'm probably not going to get involved in anything 8273 related (other than using it as a tool to learn about the 8271 if necessary).
But from a quick glance, the entry points for curious minds look to be as follows:
$063: wakeup when command register ($FE80 in beeb terms) is written. Does command dispatch based on various comparisons of R31 (RB 2 + I15), and a jump table invoked at $06F.
$019: wakeup when parameter register ($FE81 in beeb terms), but probably only if the command dispatch enabled this particular wakeup. (There could be three different parameter handlers, selected with BC xx if the dispatcher request assignments are the same as the 8271.) Reads R30 (RB 3 + I14) and writes it to an incrementing register address pointer. ($01E should be INC I0).
Chris
Diminished
Post by Diminished » Fri Sep 11, 2020 9:26 am
Yeah, I'm disappointed, honestly. I was hoping to find some opcodes not used by the other chip, but I don't think there are any. (edit: actually not true!)
Probably time I went back to doing something else.
Diminished
Post by Diminished » Fri Sep 11, 2020 7:48 pm
(Here's the trashy disassembler I scraped together to list the 8273 program. Basically useless but hey.)
<?php
  define("OPARG_IMM", 1);
  define("OPARG_ABS", 2);
  define("OPARG_UNK", 3);
  define("OPARG_IMM_NOCOMMA", 4);
  define("OPARG_ABS_NOCOMMA", 5);
  //$s = file_get_contents("my8271.bin");
  $argv = $_SERVER['argv'];
  if (! isset ($argv[1])) {
    print "Usage:\n  php -f 827xdis.php <binary file> [starting PC in hex]\n";
    die();
  $s = file_get_contents($argv[1]);
  $a = 0;
  if (isset($argv[2])) {
    if (! ctype_xdigit($argv[2])) {
      print "Bad start PC value \"".$argv[2]."\".\n";
      die();
    $a = hexdec($argv[2]);
    if ($a > 0x3ff) {
      print "Bad start PC value ".$argv[2]." (max 3ff).\n";
      die();
  $opcodes = array();
  $opargs  = array();
  for ($i=0;$i<=0xff;$i++) {
    $opcodes[$i] = "???";
    $opargs[$i] = array();
  for ($i=0x0; $i<=0xf; $i++) {
    $opcodes[$i]      = "SEL RB ".$i;
    $opcodes[$i+0x10] = "YIELDTO ".$i;
    $opcodes[$i+0x20] = "MOV A, I".$i;
    $opcodes[$i+0x30] = "MOV I".$i.", A";
    $opcodes[$i+0x40] = "BEQ I".$i;
    $opargs[$i+0x40]  = array(0=>OPARG_IMM, 1=>OPARG_ABS);
    $opcodes[$i+0x50] = "BNE I".$i;
    $opargs[$i+0x50]  = array(0=>OPARG_IMM, 1=>OPARG_ABS);
    $opcodes[$i+0x60] = "TBZ I".$i;
    $opargs[$i+0x60]  = array(0=>OPARG_IMM, 1=>OPARG_ABS);
    $opcodes[$i+0x70] = "TBNZ I".$i;
    $opargs[$i+0x70]  = array(0=>OPARG_IMM, 1=>OPARG_ABS);
  for ($i=0x0; $i<=3; $i++) {
    $opcodes[$i+0x80] = "INC I".$i;
    $opcodes[$i+0x84] = "ADC I".$i;
    //$opcodes[$i+0x80] = "ADC A, I".$i;
  $opcodes[0x88] = "BMI";
  $opargs[0x88] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0x89] = "BPL";
  $opargs[0x89] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0x8a] = "BZ";
  $opargs[0x8a] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0x8b] = "BNZ";
  $opargs[0x8b] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0x8c] = "B??";
  $opargs[0x8c] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0x8d] = "B??";
  $opargs[0x8d] = array(0=>OPARG_ABS_NOCOMMA);
  //$opcodes[0x8e] = "!!!";
  for ($i=0; $i<=3; $i++) {
    $opcodes[0x94 + $i] = "SBC I".$i;
  $opcodes[0x98] = "MOV A";
  $opargs[0x98] = array(0=>OPARG_IMM);
  $opcodes[0x9c] = "AND A";
  $opargs[0x9c] = array(0=>OPARG_IMM);
  $opcodes[0x9d] = "OR A";
  $opargs[0x9d] = array(0=>OPARG_IMM);
  for ($i=0; $i<=7; $i++) {
    $opcodes[0xa0 + $i] = "DEC I".$i;
    $opcodes[0xb8 + $i] = "TASK ".$i;
    $opargs[0xb8 + $i]  = array(0=>OPARG_IMM);
    $opcodes[0xc0 + $i] = "AND A, I".$i;
    $opcodes[0xc8 + $i] = "AND I".$i;
    $opargs[0xc8 + $i]  = array(0=>OPARG_IMM);
    $opcodes[0xd0 + $i] = "OR A, I".$i;
    $opcodes[0xd8 + $i] = "OR I".$i;
    $opargs[0xd8 + $i]  = array(0=>OPARG_IMM);
    $opcodes[0xe0 + $i] = "XOR A, I".$i;
    $opcodes[0xf0 + $i] = "MOV I".$i;
    $opargs[0xf0 + $i]  = array(0=>OPARG_IMM);
  $opcodes[0xe8] = "MOV [I0], A";
  $opcodes[0xe9] = "SHR A";
  $opcodes[0xea] = "SEC";
  $opcodes[0xeb] = "CLC";
  $opcodes[0xec] = "SYS 0, RB, A";
  $opcodes[0xee] = "SYS 2, RB";
  $opcodes[0xf8] = "MOV A, [I0]";
  $opcodes[0xf9] = "SHL A";
  $opcodes[0xfc] = "CALL";
  $opargs[0xfc] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0xfd] = "RET";
  $opcodes[0xfe] = "JMP";
  $opargs[0xfe] = array(0=>OPARG_ABS_NOCOMMA);
  $opcodes[0xff] = "YIELD";
  $len = strlen($s);
  $new_op = 1;
  $bytes_left = 0;
  $addr_s="";
  $hex_s="";
  $op_s="";
//print_r($opargs); die();
  $argnum = 0;
  for ($i=0; $i < $len; $i++, $a++) {
    if ($a > 0x3ff) {
      print "-- Error: PC exceeded 3ff, aborting.\n";
      die();
    $b = ord($s[$i]);
//print "b=".sprintf("0x%x ", $b)."bl=".$bytes_left."\n";
    $hex_s.=sprintf("%02x ", $b);
    switch ($bytes_left) {
      case 0:
        $args = $opargs[$b];
        // print address
        $addr_s = sprintf("%03x", $a);
        $bytes_left = 1 + count($args);
        $op_s .= $opcodes[$b];
        break;
      default:
//print_r($args[0]); die();
        $op_s .= process_arg($b, array_shift($args), $a, $argnum);
        $argnum++;
        break;
    $bytes_left--;
    if ($bytes_left <= 0) {
      $addr_s = str_pad($addr_s, 6, " ");
      $hex_s = str_pad($hex_s, 10, " ");
      $op_s = str_pad($op_s, 7, " ");
      print $addr_s." ".$hex_s." ".$op_s."\n";
      $addr_s="";
      $hex_s="";
      $op_s="";
      $bytes_left = 0;
      $argnum = 0;
  function process_arg($b, $arg, $addr, $argnum) {
    $s="";
    if ($argnum == 0) { $s = " "; }
    switch ($arg) {
      case OPARG_IMM:
        return ", #".sprintf("0x%x", $b);
      case OPARG_ABS:
        $s = ", ";
      case OPARG_ABS_NOCOMMA:
        $s .= sprintf("0x%03x", $addr&0xf00 | 0xff&$b);
        return $s;
      case OPARG_UNK:
        return "";
      default:
        print "say what? [".$b."]\n";
        die();
Post by Rich Talbot-Watkins » Fri Sep 11, 2020 8:02 pm
That's awesome.
And you may also possibly have written the most niche program ever written! :lol:
scarybeasts
Post by scarybeasts » Sat Sep 12, 2020 9:35 am
We still have opcodes in the 8271 ROM that we have no clue about. It's possible the the same opcodes in the 8273 might appear in different contexts, and with better clues.
The unknown opcodes include $9A, $9B, $8C.
We also have a _lot_ of fuzziness on $E7, as well as all of the ADD / SUB type instructions and carry flag setting. I managed to get the seek code sort-of sane (it does a lot of track number comparisons, and has to do things like negate) but I'm not confident in it...
Chris
guesser
Post by guesser » Sat Sep 12, 2020 10:21 am
I believe the first left column is 111x1xxx rather than 111xxxxx.
Diminished
Post by Diminished » Sat Sep 12, 2020 10:31 am
Sean wasn't kidding when he said he chipped one of those 8273 dies.
Anyway, he picked the correct corner to chip and the tables are readable on this sample, so I was able to complete the (preliminary) job on the 8273.
EDIT: there were six errors in this transcription, hopefully now fixed:
; entry point #40 (2, 6, 0) -> (2, 6, 15):
000    04         SEL RB 4
007    b8 00      TASK 0, #0x0
009    b9 00      TASK 1, #0x0
00b    bb 00      TASK 3, #0x0
00d    bc 01      TASK 4, #0x1
011    02         SEL RB 2
018    ff         YIELD
; entry point #75 (3, 9, 0):
019    03         SEL RB 3
01a    2e         MOV A, I14
01b    00         SEL RB 0
01c    e8         MOV [I0], A
01d    00         SEL RB 0
01e    80         INC I0
01f    a1         DEC I1
020    88 23      BMI 0x023
022    ff         YIELD
023    03         SEL RB 3
024    2f         MOV A, I15
025    00         SEL RB 0
026    ec         SYS 0, RB, A
; entry point #2 (0, 0, 0) -> (0, 0, 3):
027    a9         ???
02a    8b 49      BNZ 0x049
02c    b9 01      TASK 1, #0x1
02e    fe 49      JMP 0x049
; entry point #0 (0, 0, 8) -> (0, 0, 9):
030    ab         ???
033    8a 47      BZ 0x047
035    02         SEL RB 2
038    fe 49      JMP 0x049
; entry point #1 (0, 0, 10) -> (0, 0, 11):
03a    02         SEL RB 2
042    04         SEL RB 4
047    bb 02      TASK 3, #0x2
04b    11         YIELDTO 1
; entry point #76 (3, 9, 1):
04c    03         SEL RB 3
04d    2e         MOV A, I14
04e    ff         YIELD
; entry point #77 (3, 9, 2):
051    03         SEL RB 3
052    d6         OR A, I6
053    00         SEL RB 0
054    e1         XOR A, I1
055    e8         MOV [I0], A
056    fe 49      JMP 0x049
; entry point #78 (3, 9, 3):
05a    03         SEL RB 3
05b    c6         AND A, I6
05c    fe 53      JMP 0x053
05e    00         SEL RB 0
05f    f8         MOV A, [I0]
060    00         SEL RB 0
061    e1         XOR A, I1
062    fd         RET
; entry point #74 (3, 8, 0) -> (3, 8, 15):
063    02         SEL RB 2
066    2f         MOV A, I15
067    f9         SHL A
068    89 70      BPL 0x070
06a    f9         SHL A
06b    89 70      BPL 0x070
06d    2f         MOV A, I15
06e    0a         SEL RB 10
06f    ec         SYS 0, RB, A
070    2f         MOV A, I15
071    00         SEL RB 0
072    30         MOV I0, A
07a    fe 7e      JMP 0x07e
07e    03         SEL RB 3
085    bc 02      TASK 4, #0x2
087    ff         YIELD
088    bc 03      TASK 4, #0x3
08a    ff         YIELD
08d    02         SEL RB 2
08e    36         MOV I6, A
08f    fe 49      JMP 0x049
; entry point #26 (0, 10, 5):
091    02         SEL RB 2
094    b9 00      TASK 1, #0x0
096    11         YIELDTO 1
097    39         MOV I9, A
098    fe 49      JMP 0x049
; entry point #27 (0, 10, 12) -> (0, 10, 15):
09a    01         SEL RB 1
09b    38         MOV I8, A
0a0    fe d4      JMP 0x0d4
0a2    02         SEL RB 2
0a5    fd         RET
; entry point #81 (3, 13, 0) -> (3, 13, 15):
0af    ff         YIELD
0b0    a9         ???
0b3    8a af      BZ 0x0af
0b9    b9 00      TASK 1, #0x0
0bb    ff         YIELD
0bc    01         SEL RB 1
0bd    ee         SYS 2, RB
0be    ab         ???
0bf    01         SEL RB 1
0c0    3b         MOV I11, A
0cd    aa         ???
0d0    8b af      BNZ 0x0af
; entry point #36 (2, 2, 0) -> (2, 2, 15):
0d4    01         SEL RB 1
0d5    d8 04      OR I0, #0x4
0d7    02         SEL RB 2
0d8    34         MOV I4, A
0db    bb 0f      TASK 3, #0xf
0dd    ba 03      TASK 2, #0x3
0df    ff         YIELD
; entry point #45 (3, 1, 5):
0e2    b8 00      TASK 0, #0x0
0e4    fd         RET
; entry point #47 (3, 1, 3):
0e5    28         MOV A, I8
0e6    33         MOV I3, A
0ea    b8 02      TASK 0, #0x2
0ec    fd         RET
0f0    b8 05      TASK 0, #0x5
0f2    fd         RET
; entry point #49 (3, 1, 1):
0f3    22         MOV A, I2
0f4    33         MOV I3, A
0f5    fe ed      JMP 0x0ed
0f7    b8 06      TASK 0, #0x6
0f9    fd         RET
; entry point #48 (3, 1, 2):
0fa    2a         MOV A, I10
0fb    33         MOV I3, A
0fc    b8 01      TASK 0, #0x1
0fe    fd         RET
; entry point #46 (3, 1, 4):
0ff    29         MOV A, I9
; entry point #41 (2, 7, 0) -> (2, 7, 15):
100    33         MOV I3, A
101    b8 03      TASK 0, #0x3
103    fd         RET
; entry point #52 (3, 4, 0):
104    21         MOV A, I1
105    02         SEL RB 2
108    ff         YIELD
; entry point #53 (3, 4, 1):
109    21         MOV A, I1
10a    04         SEL RB 4
10b    ec         SYS 0, RB, A
; entry point #4 (0, 4, 9):
10c    02         SEL RB 2
116    b8 05      TASK 0, #0x5
118    10         YIELDTO 0
; entry point #6 (0, 4, 12) -> (0, 4, 15), (0, 5, 12) -> (0, 5, 15):
11b    12         YIELDTO 2
; entry point #55 (3, 4, 4) -> (3, 4, 5):
11c    21         MOV A, I1
11d    05         SEL RB 5
11e    ec         SYS 0, RB, A
; entry point #7 (0, 5, 10):
11f    11         YIELDTO 1
; entry point #8 (0, 5, 0):
120    00         SEL RB 0
121    ed         ???
; entry point #30 (1, 0, 2):
122    26         MOV A, I6
123    01         SEL RB 1
124    36         MOV I6, A
128    26         MOV A, I6
129    e6         XOR A, I6
12a    8a 31      BZ 0x131
12c    26         MOV A, I6
12d    e7         XOR A, I7
12e    8a 36      BZ 0x136
130    11         YIELDTO 1
131    02         SEL RB 2
134    fe 39      JMP 0x139
136    02         SEL RB 2
139    01         SEL RB 1
13d    04         SEL RB 4
142    02         SEL RB 2
147    ab         ???
14a    8b 50      BNZ 0x150
14c    bb 0f      TASK 3, #0xf
14e    ba 02      TASK 2, #0x2
150    13         YIELDTO 3
; entry point #31 (1, 0, 3):
151    26         MOV A, I6
152    00         SEL RB 0
153    37         MOV I7, A
154    02         SEL RB 2
; entry point #33 (1, 0, 5):
158    a8         ???
15b    8b a9      BNZ 0x1a9
15d    00         SEL RB 0
15e    27         MOV A, I7
15f    02         SEL RB 2
162    32         MOV I2, A
165    00         SEL RB 0
166    26         MOV A, I6
167    03         SEL RB 3
168    3a         MOV I10, A
16d    19         YIELDTO 9
16e    14         YIELDTO 4
; entry point #32 (1, 0, 4):
16f    15         YIELDTO 5
; entry point #56 (3, 4, 9):
170    21         MOV A, I1
171    07         SEL RB 7
172    ec         SYS 0, RB, A
; entry point #12 (0, 7, 12):
179    b8 05      TASK 0, #0x5
17b    12         YIELDTO 2
17e    fe 77      JMP 0x177
; entry point #14 (0, 7, 0):
180    03         SEL RB 3
181    81         INC I1
182    90         ???
183    01         SEL RB 1
184    a4         DEC I4
185    b5         ???
186    88 90      BMI 0x190
188    2c         MOV A, I12
189    d5         OR A, I5
18a    8b 6d      BNZ 0x16d
18c    02         SEL RB 2
18f    ff         YIELD
194    b8 05      TASK 0, #0x5
196    10         YIELDTO 0
; entry point #10 (0, 7, 8):
197    02         SEL RB 2
; entry point #11 (0, 7, 10):
19f    b8 05      TASK 0, #0x5
1a1    11         YIELDTO 1
; entry point #9 (0, 5, 8):
1a2    02         SEL RB 2
; entry point #5 (0, 4, 8), (0, 4, 10):
1a8    ff         YIELD
; entry point #35 (2, 1, 0) -> (2, 1, 15):
1a9    02         SEL RB 2
1ac    01         SEL RB 1
1ad    3a         MOV I10, A
1ae    a8         ???
1b1    8a b7      BZ 0x1b7
1b3    02         SEL RB 2
1b6    10         YIELDTO 0
1b7    2a         MOV A, I10
1b8    02         SEL RB 2
1b9    33         MOV I3, A
1bc    fd         RET
1bd    04         SEL RB 4
1c2    fd         RET
; entry point #13 (0, 7, 13), (0, 7, 15):
1c3    02         SEL RB 2
1c8    03         SEL RB 3
1cc    29         MOV A, I9
1cd    01         SEL RB 1
1ce    3a         MOV I10, A
1cf    02         SEL RB 2
1d3    01         SEL RB 1
1d4    a2         DEC I2
1d5    88 7c      BMI 0x17c
1d7    a2         DEC I2
1d8    88 7c      BMI 0x17c
1da    01         SEL RB 1
1de    04         SEL RB 4
1e2    04         SEL RB 4
1e3    26         MOV A, I6
1e4    01         SEL RB 1
1e5    3a         MOV I10, A
1e8    02         SEL RB 2
1ee    01         SEL RB 1
1ef    d2         OR A, I2
1f2    b8 04      TASK 0, #0x4
1f4    12         YIELDTO 2
; entry point #51 (3, 3, 0) -> (3, 3, 15):
1f9    b9 00      TASK 1, #0x0
1fb    ff         YIELD
; entry point #57 (3, 6, 0) -> (3, 6, 15):
1fe    02         SEL RB 2
1ff    ee         SYS 2, RB
; entry point #50 (3, 1, 6):
208    b8 05      TASK 0, #0x5
20a    fd         RET
; entry point #79 (3, 10, 0) -> (3, 10, 15):
20b    02         SEL RB 2
; entry point #80 (3, 11, 0) -> (3, 11, 15):
20e    ff         YIELD
; entry point #34 (2, 0, 0) -> (2, 0, 15):
20f    02         SEL RB 2
215    04         SEL RB 4
218    fd         RET
21b    04         SEL RB 4
21e    fd         RET
21f    04         SEL RB 4
225    02         SEL RB 2
228    fd         RET
22b    02         SEL RB 2
22e    fd         RET
22f    01         SEL RB 1
233    04         SEL RB 4
236    00         SEL RB 0
237    a2         DEC I2
238    b3         ???
239    02         SEL RB 2
23a    89 45      BPL 0x245
23e    00         SEL RB 0
243    ea         SEC
244    fd         RET
249    eb         CLC
24a    fd         RET
; entry point #59 (3, 7, 1):
250    02         SEL RB 2
253    04         SEL RB 4
25a    11         YIELDTO 1
25b    02         SEL RB 2
25f    15         YIELDTO 5
; entry point #64 (3, 7, 6):
260    bb 07      TASK 3, #0x7
262    01         SEL RB 1
266    02         SEL RB 2
26a    02         SEL RB 2
26e    14         YIELDTO 4
; entry point #60 (3, 7, 2):
26f    02         SEL RB 2
272    04         SEL RB 4
278    02         SEL RB 2
27b    fe 53      JMP 0x253
; entry point #61 (3, 7, 3):
; entry point #62 (3, 7, 4):
283    01         SEL RB 1
287    17         YIELDTO 7
; entry point #63 (3, 7, 5):
28a    bb 06      TASK 3, #0x6
28f    ff         YIELD
; entry point #65 (3, 7, 7):
294    02         SEL RB 2
298    18         YIELDTO 8
; entry point #16 (0, 8, 1):
299    02         SEL RB 2
29c    ba 09      TASK 2, #0x9
29e    ff         YIELD
2a1    1a         YIELDTO 10
; entry point #66 (3, 7, 8):
2a2    00         SEL RB 0
2a3    24         MOV A, I4
2a4    04         SEL RB 4
2a5    35         MOV I5, A
2a8    19         YIELDTO 9
; entry point #67 (3, 7, 9):
2a9    00         SEL RB 0
2aa    25         MOV A, I5
2ab    04         SEL RB 4
2ac    35         MOV I5, A
; entry point #68 (3, 7, 10):
2af    89 a1      BPL 0x2a1
2b1    02         SEL RB 2
2b5    1b         YIELDTO 11
; entry point #69 (3, 7, 11):
2b6    02         SEL RB 2
2b9    01         SEL RB 1
2bd    02         SEL RB 2
2c5    1c         YIELDTO 12
; entry point #70 (3, 7, 12):
2c8    1d         YIELDTO 13
; entry point #72 (3, 7, 14):
2cd    ba 00      TASK 2, #0x0
2cf    1f         YIELDTO 15
; entry point #71 (3, 7, 13):
2d2    02         SEL RB 2
2d6    1e         YIELDTO 14
2e1    17         YIELDTO 7
2e2    13         YIELDTO 3
; entry point #17 (0, 8, 2):
2e7    02         SEL RB 2
2eb    04         SEL RB 4
2ee    10         YIELDTO 0
; entry point #73 (3, 7, 15):
2ef    08         SEL RB 8
2f0    aa         ???
2f1    ec         SYS 0, RB, A
; entry point #18 (0, 8, 3):
2f4    ba 04      TASK 2, #0x4
2f6    01         SEL RB 1
2f7    28         MOV A, I8
2f8    09         SEL RB 9
2f9    ec         SYS 0, RB, A
; entry point #58 (3, 7, 0):
; entry point #23 (0, 9, 13):
2fe    ff         YIELD
; entry point #20 (0, 8, 9), (0, 8, 11):
2ff    aa         ???
; entry point #43 (2, 9, 0) -> (2, 9, 15):
300    0b         SEL RB 11
301    ec         SYS 0, RB, A
; entry point #21 (0, 9, 12):
304    ff         YIELD
; entry point #22 (0, 9, 14):
307    ff         YIELD
; entry point #15 (0, 8, 0):
30a    01         SEL RB 1
30e    ba 01      TASK 2, #0x1
310    ff         YIELD
311    02         SEL RB 2
314    02         SEL RB 2
317    04         SEL RB 4
31a    fe 23      JMP 0x323
; entry point #28 (0, 11, 9):
31c    01         SEL RB 1
320    ba 0b      TASK 2, #0xb
322    ff         YIELD
; entry point #29 (0, 11, 11):
323    02         SEL RB 2
327    04         SEL RB 4
32a    02         SEL RB 2
330    10         YIELDTO 0
331    12         YIELDTO 2
; entry point #19 (0, 8, 4):
334    02         SEL RB 2
337    01         SEL RB 1
33b    ba 09      TASK 2, #0x9
33d    ff         YIELD
33e    00         SEL RB 0
33f    ee         SYS 2, RB
; entry point #25 (0, 10, 8) -> (0, 10, 11):
340    00         SEL RB 0
343    38         MOV I8, A
347    00         SEL RB 0
34a    bc 00      TASK 4, #0x0
34c    ff         YIELD
34d    02         SEL RB 2
351    00         SEL RB 0
354    fe 4a      JMP 0x34a
; entry point #24 (0, 10, 0) -> (0, 10, 3):
356    00         SEL RB 0
357    39         MOV I9, A
35d    fe 51      JMP 0x351
35f    00         SEL RB 0
I can update the disassembler and just run it through again if any of the opcodes change.
I have some confidence in the entrypoints, but it's hard to transcribe the program ROM without making mistakes, so the code itself should be treated with a degree of suspicion.
Literally none of those even seem to appear in the 8273 :(
Although I suppose that's a little clue in itself? They might be relatively specialised.
e7 appears to get a single workout in the '3, at 12d.
128    26         MOV A, I6
129    e6         XOR A, I6
12a    8a 31      BZ 0x131
12c    26         MOV A, I6
12d    e7         XOR A, I7
12e    8a 36      BZ 0x136
130    11         YIELDTO 1
131    02         SEL RB 2
134    fe 39      JMP 0x139
136    02         SEL RB 2
139    01         SEL RB 1
Looking again, there are some ABs, A9s and AAs in the 8273, which I don't think the 8271 uses? Which is interesting.
Diminished
Post by Diminished » Sat Sep 12, 2020 2:43 pm
Checked my 8273 program ROM dump against the new photograph and found six errors.
I've corrected my previous post with the disassembly.
The changes to the listing are as follows:
 0cd    aa         ???
-0d0    89 af      BPL 0x0af
+0d0    8b af      BNZ 0x0af
 0d4    01         SEL RB 1
-0d5    d8 00      OR I0, #0x0
-0d7    06         SEL RB 6
+0d5    d8 04      OR I0, #0x4
+0d7    02         SEL RB 2
 0d8    34         MOV I4, A
@@ -284,7 +284,7 @@
 15b    8b a9      BNZ 0x1a9
 15d    00         SEL RB 0
 15e    27         MOV A, I7
-15f    0a         SEL RB 10
+15f    02         SEL RB 2
 162    32         MOV I2, A
@@ -697,6 +697,6 @@
 357    39         MOV I9, A
-35d    f6 59      MOV I6, #0x59
+35d    fe 51      JMP 0x351
 35f    00         SEL RB 0
A fixed ROM binary is here:
8273_program_rom_2.zip
(991 Bytes) Downloaded 6 times
(I'll delete the previous one I posted.)
Post by BeebMaster » Thu Oct 15, 2020 7:35 pm
What happened next? Or have all the secrets of the world's finest floppy disc controller been discovered now?
guesser
Post by guesser » Thu Oct 15, 2020 7:43 pm
I've been preoccupied with preparing various bits of teletext stuff for the upcoming virtual block party event, which is why I've not made any progress on the vectorising for a while (also getting ill :( ).
Hopefully I can give it some attention again next month.
scarybeasts
Post by scarybeasts » Thu Oct 15, 2020 8:28 pm
I'm still working on this and do intend to drive it to some form of resolution. Certainly some blog posts.
I did rewrite beebjit's 8271 driver based on the ROM disassembly, and accordingly it now handles things like "bad tracks" correctly.
I've managed to get the 8271 to read sectors it cannot normally read. To finish up, I'm trying to get a few examples of writing things the 8271 cannot normally write.
Chris
Post by BeebMaster » Thu Oct 15, 2020 8:30 pm
Ooo this sounds good - is the code going to be in a form that can be used on a Beeb?
Post by BigEd » Thu Oct 15, 2020 8:43 pm
...some blog posts.
... writing things the 8271 cannot normally write.
Sounds very interesting indeed!
scarybeasts
Post by scarybeasts » Fri Oct 16, 2020 12:15 am
Are you referring to making the 8271 do things it "shouldn't" be able to?
Chris
Post by BeebMaster » Fri Oct 16, 2020 4:41 pm
Yes I am. Are you testing this stuff with an 8271 in a Beeb, or somewhere else? Or is it even all theoretical as yet?
scarybeasts
Post by scarybeasts » Sat Oct 17, 2020 9:49 am
I'm testing in a real model B with 8271. So far, some simple but weird tests I've done are matching results predicted from the ROM source code (i.e. commands with the "wrong" parameter count bit mask, etc.)
I'll release any little demo programs I make. Not sure any of them will be useful, but there will be some simple demos of "impossible" things.
Chris
