Diminished
Re: 8271 disc controller craziness -- do not try this at home!
Post by Diminished » Sun Aug 23, 2020 12:11 am
Well, this is kind of interesting, although it produces more questions than answers.
I had a bash at tracing the rightmost connections in each of the clusters of 3 at the very bottom of the 10-way structure, immediately to the right of where they connect to the bus (with the exception of the far-left one, which is clearly a little bit different).
It is difficult to see precisely where they go with that big horizontal power line in the way, but they seem to hook up to the nine structures directly below the horizontal coloured bus lines, which are obscured by the big horizontal VCC line (there is clearly something there).
Each of these structures has two connections emerging from the bottom. I have (mostly) coloured these as before.
Interestingly, each of these pairs of connections then seem to go to various points in the ROMish thing in the bottom left. The white, green and yellow lines appear to talk directly to the top three (obviously all uniform) rows of the huge ROMish thing (maybe all 0s or all 1s). Meanwhile the orange, light blue, red, dark blue, pink lines (plus the ninth bit which I coloured white again) head towards the device on the left, which (I think) Kazzie convincingly argued was an address decoder.
Hypothesis: perhaps the nine chunky structures are flip-flops, or latches. Since each of these objects has a pair of outputs, it seems likely that these pairs are complementary; "Q" and "not Q". Signals emerge from the 10-bit thing and are then clocked into these latches, where their values are held for as long as is needed, freeing up the internal bus to accept the *output* from the ROM.
One thing that is really interesting here is that the white, green and yellow lines (maybe D0, D1, D2) are the ones that are connected *directly* to the big table, and they also happen to seem to connect to the three rows that are all *uniform* (presumably either all 0s or all 1s). I don't know what it means. It could be a coincidence. Or, do these three bits pick one of eight columns to output to each bus line via the 4-way connection at the top that I pointed out earlier? Where is the decoding logic for demultiplexing 3 bits into 8 lines, though?
The other six bits feed that address decoder thing in (perhaps) complementary pairs (potentially with a seventh bit arriving from somewhere else). Maybe this is why that address decoder table has a weird number of rows at 108; three bits are connected directly to the big ROM, so they don't need decoding?
Is the 7/3 (or 6/3) split in the logic lines here reflected in any way in the characteristics of those famous five internal registers, as per the datasheet?
My brain hurts.
guesser
Post by guesser » Sun Aug 23, 2020 1:07 am
Yeah I noticed the lines going to the top rows of the rom thing yesterday, weird.
Like you say each column in the possible address decoder gets two lines in which I had thought was a Q/!Q input too.
The little ROM to the side looks to have the same thing going on as you'd expect, and the ROM itself looks the same kind of thing just rotated 90°.
I'm really hoping to see under the metal of the ROM like structures to see what's actually connected to what.
I think that the "blobs" on the grids were a bit of a red herring. I got target fixation trying to make turn that pattern into something resembling binary, which I now realise wouldn't make sense anyway.
I'm expecting to see bits sticking in towards them from one side or other. The issue with that, and where I've been stuck since yesterday, is that that would make all those spots without a "blob" a "don't care" bit. I'm hoping we can decode what each line is and reason for the missing ones will then be obvious!
Diminished
Post by Diminished » Sun Aug 23, 2020 9:07 am
new pics this morning!
go go go!
Diminished
Post by Diminished » Sun Aug 23, 2020 10:59 am
It was under the metal layer, predictably enough.
Perhaps this is how the column decoding works? The address decoder rom energises one of the rows (not shown here), and then these three bits select one of eight columns?
Flipping one of D0 to D2 would swap the 1 and 0, so the complementary set of switches would open, and those currently open would close.
Post by Pernod » Sun Aug 23, 2020 12:04 pm
More updates from Sean:
I didn’t have much luck using Whink to remove the top metal layer of the dies. I suppose it’s because they are still attached to giant ceramic slabs. I usually clean dies for 2 minutes, but I did that 3 times and there’s still metal on these. I’m taking pictures each time, so that makes it go very slowly. Tomorrow I think I’ll boil one of them in sulfuric acid and see if that does the trick.
I didn’t have time to process the pics, so I’m uploading the raw stitched pics. I also uploaded a text file called process.txt that lists the steps I take with GIMP to process the pics. Hopefully I’ll be able to clean off the rest of the metal tomorrow.
Diminished
Post by Diminished » Sun Aug 23, 2020 12:23 pm
Yeah, it's a little disappointing how much muck there is on the new pictures ... but they're certainly enough for some more poking around.
I suppose you can chalk up yet another reason why the 8271 was a poor choice for the Proton's FDC ...
Post by BeebMaster » Sun Aug 23, 2020 12:35 pm
Never thought I'd be responsible for a "picture that broke the internet"!
Has anyone spotted any differences between the 8271 and the 8271-6? Only difference according to the datasheet is the operating temperature range, so maybe it only comes about at the testing/certification stage after manufacture. I think there was a -8 once upon a time as well, haven't seen one of those.
guesser
Post by guesser » Sun Aug 23, 2020 12:36 pm
Yeah I guessed there'd be something like this under those top rows, but the question is how does it work to block or select lines! :?
guesser
Post by guesser » Sun Aug 23, 2020 12:41 pm
I'm a bit baffled by the ROMs as they have broadly speaking the structure I was expecting of bits going to one side or other, except some see to go to both. *hair pulling emote*
Diminished
Post by Diminished » Sun Aug 23, 2020 1:18 pm
I don't understand the circuit either ... I don't get how those top six rows somehow act as switches (although they're fed with assumed complementary pairs of inputs, whereas the other rows presumably aren't), but the logic might work like this:
guesser
Post by guesser » Sun Aug 23, 2020 1:34 pm
I'm going to really take a step way out of my depth now, and suggest that a signal coming in from the left forms the gate of a transistor which pulls the column to ground. So for each combination of those three bits only one of the 8 columns in each group is not pulled to ground.
The thing at the top with all the groups of four must also be some kind of transistor (but working the opposite way round?) where the columns coming up are the gates? Each one of those crosses over the layer all the groups of four are connected to, which is also connected to ground.
guesser
Post by guesser » Sun Aug 23, 2020 1:40 pm
They either ground a column or don't, so I don't think the stuff coming in from the decoder is complimentary inputs any more.
Some points in the ROM have the column connected up and down to both inputs, so they must be separate addresses.
This also explains why some places have no via up to the column metal, because neither of the two addresses in that pair are set. i.e. each via can connect to the top input, bottom input, both inputs, or neither input. 4 options because it's two bits of the ROM. :D
I think we might be getting somewhere now :)
I need to apply the same thinking to the address decoder!
guesser
Post by guesser » Sun Aug 23, 2020 1:46 pm
At the bottom of all the columns they're connected down to Vcc in parallel by what must be a big pull up resistor! It's all starting to make sense in my head now :D
guesser
Post by guesser » Sun Aug 23, 2020 2:40 pm
Ok, I've worked out the address decoder, it is just counting up sequentially in binary from 0000000 to 1101011 (108).
So 7 row bits there, and the three column select bits makes a 10 bit address, but because of the missing rows that's an 864 byte ROM.
Shall I transcribe the bits into a spreadsheet then we can worry about what order they're in and which state is high/low later?
guesser
Post by guesser » Sun Aug 23, 2020 5:23 pm
The small 10-bit decoder has the order of the rows jumbled up a lot, and many "don't care" states. I'm working my way through converting them into a range of values.
dp11
Post by dp11 » Sun Aug 23, 2020 5:42 pm
Sounds like micro code?
guesser
Post by guesser » Sun Aug 23, 2020 5:59 pm
It looks like instruction decoding to me. I just did a bunch where there were 16 lines each with incrementing values in the upper 6 bits and "don't care" in the lower 4. I could imagine that being 16 register to register loads say :)
Once I've decoded them I'll put them all in a grid along with what they select from the ROM.
Edit: or is this decoding the commands from outside! I will have to study the datasheet! :)
dp11
Post by dp11 » Sun Aug 23, 2020 6:03 pm
Could be I wonder if a few of the address bits are a cycle counter.
guesser
Post by guesser » Sun Aug 23, 2020 6:05 pm
/me stops speculating and gets back to transcribing bits
Post by Kazzie » Sun Aug 23, 2020 6:19 pm
(I wish I had the time to get more involved with this analysis, it looks really fun!)
Looking at the structure of the gates between the left and right sides of each of the two "ROM" areas in the bottom right, they're oriented the same way. So if the big ROM area has decoder circuitry on the left retrieving data from the right side, then it would appear that the smaller ROM on the right works the same way.
With ten bits to decode in the smaller ROM, and the tracks of the "outputs" on the right going all the way up into the circuitry in the upper side of the board, I was wondering if they'd match up with the eight bits plus two address lines used to program the various registers. I'd theorised that the two address lines would be on the right, as most of the Don't Cares are on the left. Working under that assumption, we get all four combinations of A1 and A0, despite the datasheet only listing 00, 01, and 10 as valid (for writing to the command, parameter, and reset registers respectively).
However, if the address lines are on the far right, we've got all four combinations decoded...?
The combination 01 has four Don't Cares for every entry. If that's for the reset register, that would make sense, as the datasheet only specifiies but D0 being set as part of the reset sequence, but scarybeasts has found that setting bits D1 or D2 does funky stuff to the FDC. (If this analysis is right, D3 is also decoded and may have interesting effects, but D4-7 are Don't Cares.)
RiscPC 600 under repair
guesser
Post by guesser » Sun Aug 23, 2020 6:47 pm
assuming I've not misplaced a bit anywhere, the rows of the small decoder come out as:
$34
$2D
$24
$25
$26
$27
$22
$23
$28
$2A
$20
$21
$2B
$2E
$2F
$10
$11
$12
$13
$14
$15
$16
$17
$18
$19
$1A
$1B
$118 - $11F
$110 - $117
$128
$123
$125
$12A
$12B
$130 / $138
$131 / $139
$132 / $13A
$133 / $13B
$134 / $13C
$135 / $13D
$200 - $20F
$210 - $21F
$220 - $22F
$230 - $23F
$240 - $24F
$250 - $25F
$260 - $26F
$270 - $27F
$280 - $28F
$290 - $29F
$2A0 - $2AF
$2B0 - $2BF
$2C0 - $2CF
$2D0 - $2DF
$2E0 - $2EF
$2F0 - $2FF
$320 - $32F
$330 - $33F
$380 - $38F
$3D0 - $3DF
$390 / $392 / $398 / $39A
$391 / $393 / $399 / $39B
$394 / $395 / $396 / $397 / $39C / $39D / $39E / $39F
$340
$341
$342
$343
$344
$345
$348
$350
$351
$355
$35A / $35B
$370
$371
$373
$375
$376
$378
$3B0 - $3BF
$3C0 - $3CF
I've put them in a grid which maps the address for want of a better term to the row number
decoder-grid.ods
(12.83 KiB) Downloaded 13 times
guesser
Post by guesser » Sun Aug 23, 2020 6:56 pm
I suspect you're correct Kazzie. I also suspect I might have all my bits inverted. There was a 50% chance of it! #-o
Edit: Or not, I still can't make much of anything there line up with the datasheet either way.
/me gives up for now and goes to make his dinner.
Post by Pernod » Sun Aug 23, 2020 9:44 pm
Another update from Sean:
I cleaned both dies in hot sulfuric acid and it did help somewhat. I uploaded the new pics. I’ll try to clean the dies up more next weekend.
sbadger
Post by sbadger » Mon Aug 24, 2020 9:36 am
Nice progress here everybody and very interesting to follow (though pretty much over my head tbh)
Are you guys aware of the Degate tooling? I understand it's designed to help with this sort of stuff, and can help decode ROMS etc
https://degate.org/
and the video where I first saw it in action https://youtu.be/7Q82FkthDx8?t=4169
guesser
Post by guesser » Tue Aug 25, 2020 6:31 pm
I've transcribed out all the bits from the ROM in the bottom left and double checked them. In the spreadsheet I've re-grouped them into bytes (rather than interleaved bits) and converted to hexadecimal.
This assumes that the column select bits are the low three address bits with the left column being the lowest address. Likewise it assumes the left group of 8 columns is B7, through to B0 on the right in order. Hopefully Diminished can trace the data bus to the bond pads which hopefully mirror the pinout :)
I can easily adjust my spreadsheet to shuffle the decoding around anyway.
03 F9 FD 08 FF 00 46 FB
45 FF 44 FF 43 FF 41 FF
FB 0F F7 02 FD 09 FF 30
40 FF 0A FE 0B FE FC 67
FA 90 E7 D8 D0 63 FC FF
CE 75 C2 0F F8 43 FE 00
FC D1 03 EC 00 FC D1 FF
17 5F 5E 74 CB 03 A2 43
FF FC D0 30 C3 63 3F FB
CB 1C 63 3F 75 AC 67 DF
3C 2B CC FD D0 16 16 13
0F F9 46 FB 00 FB DD FC
CA 24 44 3C C4 02 FF D8
CF 0E FC EB FC D1 FF 17
FF 7F 5E 75 73 00 FE 0C
FF EA FE D4 7C 13 FF D8
CF D9 17 FD 30 80 00 03
A2 C9 DA C4 F1 11 FF 89
00 2C 03 21 41 FA 00 FF
47 FE 8B 7F 5B 47 FD 8B
BF 5B 47 FF FC D2 65 03
36 45 F4 ED D9 FE 17 5F
87 F8 FA FB 0F F9 FD 30
30 46 FE EF AE 0B 2C FD
A0 E7 3A 20 CF 45 FE EC
11 03 21 F4 03 37 FC 0B
FC C1 FD FE 0F F3 46 F7
FB 8F F7 0F FB 00 FF DE
14 78 FE 0F EF FB 9C 7F
13 FE 27 F7 FE C4 C3 07
FE 94 00 06 15 6B 6C D4
C3 7F 87 FE 10 67 2A 14
7B FB 34 10 76 F7 24 EF
FE 67 00 94 00 F0 07 FE
14 6B 75 A6 76 E0 C4 5C
D4 FB 18 24 FB 01 DD FB
34 04 FE C5 D3 17 FD 98
FD D3 CD C5 FB 9D FD CA
FE 93 00 A9 FB 24 FD FE
D2 63 00 FB 74 B9 9D FE
C1 8D FE BE 01 B5 34 02
03 96 FE D1 5D 74 D3 83
00 A9 67 EB FC 13 FB 34
02 FB 8C F7 9A 24 F7 FE
D0 06 06 63 C0 03 96 F6
11 FE C7 97 00 88 0E 05
5E 86 00 8F 5F 74 91 02
16 16 16 16 02 FF 59 FE
0C FB 9B 00 6F 5C DB 03
20 03 24 0B 28 0A 03 EA
FF DC 03 20 03 27 0A 01
0B 38 0F FE EA 0A 00 0F
FF FD 0C F5 03 1C 03 24
0A 04 01 67 0A 1A 0B 00
03 2E 67 1A 03 10 F2 11
FD 5A 74 11 12 0F F7 FD
DA 03 10 03 27 FF DD FB
0B 38 CA 0F FE 03 2E 5C
EC FF DF FD CB 0C 7F 02
FD 20 CF FB 0A FF EE FD
CC 0B FF 67 00 03 10 0A
FF FD 0A FF 0C FA 00 FB
0B 00 CA 37 0C 24 FE 44
F7 FD CA E7 FB 0F F7 1F
FA EA 03 A7 12 0F FF 0A
00 FF 5A 9A E0 EB FE 0C
FB D9 FB 11 0A FE 41 FB
FB 0A 00 E9 FE DA 03 A6
16 FD 0C 7F CB 9B 00 D0
1B 06 62 FE 5B 74 D6 CB
FF CF 02 0F FB 67 F3 AE
0C 85 FC B0 E7 10 FE D8
1B 75 B1 FF 7E 67 E7 BE
FC 85 FA 0F F7 11 D9 1D
74 A9 FD 0A F4 02 FF 11
F9 11 03 A7 67 E9 84 DF
85 67 EF FB 8C 7F 93 FC
94 FB 85 02 FC 94 BF 85
02 BE 0F A9 67 F7 01 85
67 F5 FB 34 07 01 7C 03
40 67 FF FD 29 C9 20 F7
FD 30 B0 03 A6 FE D0 90
0F 5F 03 A6 FC C3 B3 F0
64 41 FE 00 FC 5B 74 55
FB 34 C8 EF FC 5B 67 E7
75 85 00 67 07 01 4E 67
04 FF CD FA 03 3F FD 0B
FF 0C FA 45 F5 01 38 F8
11 03 40 03 E3 41 FC FC
67 ED 84 F7 85 EC DE 00
9E FB 8B 9E FE 23 FD 09
DF 90 FB 18 FD B0 E3 18
20 CF 80 C7 18 F3 11 EA
67 F1 AE 0C 85 37 02 03
A5 FB 34 01 FD 03 A6 FF
5A 9A E0 7E DB 63 C0 79
C9 FC 80 C7 F9 F0 11 FD
DA FB CA 00 0B 00 00 0F
FD 0A 00 EA FD 30 30 00
0B 00 FD 5C 74 DC 5B 77
DA 0C 7F FE 12 0B FF 30
30 12 FD 30 08 00 FF D8
CF 07 FD C9 F1 11 64 FF
DC FD CA 01 C1 64 5A 74
BA 73 AE CA 65 5C 74 C2
0C 7F 5B 76 C2 30 30 F5
11 67 FD 47 FF 73 A6 67
FB F7 11 FF FF FF FF FF
Post by Coeus » Tue Aug 25, 2020 7:28 pm
So if this is an 8-bit wide ROM do we think this is normal machine code for a microcontroller rather than microcode? Perhaps I should qualfiy that by saying my understanding of microcode is that it generally has very wide words because each bit is activating various bits of the chip as it goes through the micro-steps in each larger instruction.
If so then can we run it (the 8 bit ROM code) through a disassembler for some of the microcontrollers around at the time and see if it makes sense?
guesser
Post by guesser » Tue Aug 25, 2020 7:48 pm
I've been looking at intel instruction sets but nothing makes sense. I think we need to work out where the outputs of that 10 bit rom go next.
Diminished
Post by Diminished » Tue Aug 25, 2020 8:45 pm
A quick PHP hack on the bytes collected shows how many times each of them occurs. These are listed the "wrong way round", with the frequency first and the byte second (so I could sort them in order of commonness).
I left in the ones that never occur at the bottom (the zeroes). Most possible bytes do get an outing, though.
Not particularly insightful but Fx and 0x look quite common.
46 : FF
38 : FE
37 : FB
36 : FD
36 : 00
34 : 03
22 : FC
22 : 67
18 : 0F
15 : F7
15 : 11
14 : 0A
13 : 30
13 : 0C
13 : 0B
12 : 02
11 : 74
10 : 01
9 : 85
9 : 7F
8 : FA
8 : CA
8 : 24
7 : CF
7 : 5B
7 : 34
7 : 16
6 : EA
6 : E7
6 : D0
6 : A6
6 : 75
6 : 63
6 : 20
6 : 10
5 : F9
5 : EF
5 : DA
5 : D8
5 : CB
5 : 5C
5 : 41
5 : 17
5 : 07
4 : F5
4 : EC
4 : DF
4 : D9
4 : D1
4 : C9
4 : C4
4 : C3
4 : AE
4 : A9
4 : 94
4 : 5F
4 : 5A
4 : 47
4 : 46
4 : 45
4 : 18
4 : 13
4 : 12
4 : 06
3 : F8
3 : F4
3 : F3
3 : F1
3 : F0
3 : EB
3 : E0
3 : DD
3 : DC
3 : D4
3 : D3
3 : C7
3 : C2
3 : C1
3 : BE
3 : B0
3 : 9A
3 : 90
3 : 8B
3 : 80
3 : 76
3 : 73
3 : 64
3 : 5E
3 : 44
3 : 43
3 : 40
3 : 3F
3 : 38
3 : 37
3 : 27
3 : 14
3 : 04
2 : ED
2 : E9
2 : E3
2 : DE
2 : DB
2 : D2
2 : CD
2 : CC
2 : C5
2 : C0
2 : BF
2 : A7
2 : A2
2 : 9E
2 : 9D
2 : 9B
2 : 96
2 : 93
2 : 8F
2 : 8C
2 : 87
2 : 84
2 : 7E
2 : 7C
2 : 6B
2 : 65
2 : 3C
2 : 2E
2 : 2C
2 : 21
2 : 1C
2 : 1B
2 : 1A
2 : 0E
2 : 09
2 : 08
1 : F6
1 : F2
1 : EE
1 : D6
1 : CE
1 : C8
1 : BA
1 : B9
1 : B5
1 : B3
1 : B1
1 : AC
1 : A5
1 : A0
1 : 9C
1 : 98
1 : 97
1 : 91
1 : 8D
1 : 89
1 : 88
1 : 86
1 : 83
1 : 7B
1 : 79
1 : 78
1 : 77
1 : 6F
1 : 6C
1 : 62
1 : 5D
1 : 59
1 : 55
1 : 4E
1 : 3A
1 : 36
1 : 2B
1 : 2A
1 : 29
1 : 28
1 : 23
1 : 1F
1 : 1D
1 : 15
1 : 05
0 : E8
0 : E6
0 : E5
0 : E4
0 : E2
0 : E1
0 : D7
0 : D5
0 : C6
0 : BD
0 : BC
0 : BB
0 : B8
0 : B7
0 : B6
0 : B4
0 : B2
0 : AF
0 : AD
0 : AB
0 : AA
0 : A8
0 : A4
0 : A3
0 : A1
0 : 9F
0 : 99
0 : 95
0 : 92
0 : 8E
0 : 8A
0 : 82
0 : 81
0 : 7D
0 : 7A
0 : 72
0 : 71
0 : 70
0 : 6E
0 : 6D
0 : 6A
0 : 69
0 : 68
0 : 66
0 : 61
0 : 60
0 : 58
0 : 57
0 : 56
0 : 54
0 : 53
0 : 52
0 : 51
0 : 50
0 : 4F
0 : 4D
0 : 4C
0 : 4B
0 : 4A
0 : 49
0 : 48
0 : 42
0 : 3E
0 : 3D
0 : 3B
0 : 39
0 : 35
0 : 33
0 : 32
0 : 31
0 : 2F
0 : 2D
0 : 26
0 : 25
0 : 22
0 : 1E
0 : 19
0 : 0D
guesser
Post by guesser » Tue Aug 25, 2020 8:50 pm
Also bear in mind that as well as bit order being unsure, the bits might also all be inverted.
Diminished
Post by Diminished » Tue Aug 25, 2020 9:00 pm
I think there is at least one clue that the bit ordering is right, which is the 2/8 split in the structure that feeds the ROM's address lines. I could be wrong but I feel like that does reflect the A[1:0]/D[7:0] nature of the internal register block mentioned in the data sheet.
I was hoping we could get a cleaner image of the polysilicon layer.
