KenLowe wrote: ↑Fri Dec 04, 2020 6:05 pm
Edit: Soldered in the RAM and re-enabled the Supervisor IC (using nRDS instead of A13 for the watchdog), and everything is
almost working. The RTC is still working, all 16 sideways RAM banks seem to be working, the Shadow and Private RAM seems to be working. However, when I try and play Lancelot or Time & Magik, I get odd corruption in the game. I suspect the Supervisor IC is getting in the way of the RAM CE again. I'll try bypassing that and see if it starts working again.
It's been another frustrating day, but I think I'm there now...
I bypassed the Supervisor IC altogether, by wiring the RAM CE signal directly from the CPLD, but the RAM still misbehaved. Lancelot and Time & Magik (both of which use shadow and sideways RAM) wouldn't run reliably; it was particularly noticeable if DFS was also running from a RAM bank. The annoying thing was that if I tried to load a ROM into any RAM bank, it would load and verify ok but it appeared that, when a program needed to switch between these RAM banks, things would start going wrong. Write protect (where appropriate) didn't make any difference. If I modified the CPLD to select 4 x external 32K RAM ICs (one for shadow and the other three for 6 banks of sideways RAM) instead of the internal RAM IC everything would work properly.
After much head scratching, and even though everything seemed to bell out ok, I decided to run the soldering iron over the RAM pins again and that seems to have cured it. Lancelot and Time & Magik are both now loading and running as I would expect. The RTC is also working
. That's me now got 16 individually write protectable RAM banks (12 of which can be individually switched to external ROM sockets, 8 on the IntegraB board and 4 on the beeb motherboard), Shadow RAM & RTC all working.
I'm now going to connect the Supervisor IC back in again to see if I can get that to work reliably.
For anyone who's interested, here's the latest code. This code still uses a temporary input for the Phi2 clock. This will be corrected in the final board layout.
Edit: Code updated to temporarily use Phi1 clock instead of Phi2 (see post below). It surprisingly works in this configuration, and allows me to remove that Phi2 patch wire. I will revert back to using Phi2 on a global clock input in the next board revision.
`timescale 1ns / 1ps
IntegraBV2.v
IntegraB V2 - A fully expanded ROM / RAM Board for BBC Micro
Revision 01 - December 2020
Copyright (C) 2020 Ken Lowe
IntegraBV2 is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Email: ken@skidog.co.uk
module IntegraBV2(
input from_CPU_RnW,
input from_CPU_Phi1,
// input from_CPU_Phi2, //Temporary input (borrowed output nROMBankSel[14] - Pin 27, GCLK 3)
input from_CPU_dPhi2,
input bbc_nRST,
input [7:0] bbc_DATA,
input [15:0] bbc_ADDRESS,
input [15:0] RamWriteProt,
input [15:8] IntegraRomSel,
input [3:0] BeebRomSel,
output to_bbc_Phi1,
output to_bbc_RnW,
output to_bbc_rD0,
output to_bbc_rD1,
output nDBuf_CE,
output nDBuf_Dir,
output nWDS,
output nRDS,
output nRomBankSel0_3,
output [15:8] nRomBankSel,
output RTC_AS,
output RTC_DS,
output nRAM_CE,
output [18:14] Ram_ADDRESS
// Repeat RnW & Phi1 from Input to Output
wire Phi1;
wire Phi2;
wire ShAct;
wire RnW;
assign Phi1 = from_CPU_Phi1;
assign Phi2 = !from_CPU_Phi1;
// assign Phi2 = from_CPU_Phi2;
assign RnW = from_CPU_RnW;
assign to_bbc_Phi1 = !(!Phi1 & !ShAct);
assign to_bbc_RnW = !(!RnW & !ShAct);
assign nDBuf_Dir = RnW;
// Address decoding. Note that the lowest 2 bits A0 and A1 are not used.
wire FE3x = (bbc_ADDRESS[15:4] == 12'hFE3);
wire FE30_3 = FE3x && (bbc_ADDRESS[3:2] == 2'b00);
wire FE34_7 = FE3x && (bbc_ADDRESS[3:2] == 2'b01);
wire FE38_B = FE3x && (bbc_ADDRESS[3:2] == 2'b10);
wire FE3C_F = FE3x && (bbc_ADDRESS[3:2] == 2'b11);
// nWDS is normally just !( RnW & !Phi1) but we check for Write protect and hold nWDS high is Write Protect is active.
// nWDS needs to consider all 16 RAM banks AND the Shadow Bank
wire ShadowSel;
wire nRamBankSel[15:0];
wire GenBankSel[15:0];
assign nRDS = !( RnW & Phi2);
assign nWDS = !((!RnW & Phi2 & !nRamBankSel[0] & !RamWriteProt[0] & !BeebRomSel[0])
| (!RnW & Phi2 & !nRamBankSel[1] & !RamWriteProt[1] & !BeebRomSel[1])
| (!RnW & Phi2 & !nRamBankSel[2] & !RamWriteProt[2] & !BeebRomSel[2])
| (!RnW & Phi2 & !nRamBankSel[3] & !RamWriteProt[3] & !BeebRomSel[3])
| (!RnW & Phi2 & !nRamBankSel[4] & !RamWriteProt[4])
| (!RnW & Phi2 & !nRamBankSel[5] & !RamWriteProt[5])
| (!RnW & Phi2 & !nRamBankSel[6] & !RamWriteProt[6])
| (!RnW & Phi2 & !nRamBankSel[7] & !RamWriteProt[7])
| (!RnW & Phi2 & !nRamBankSel[8] & !RamWriteProt[8] & !IntegraRomSel[8])
| (!RnW & Phi2 & !nRamBankSel[9] & !RamWriteProt[9] & !IntegraRomSel[9])
| (!RnW & Phi2 & !nRamBankSel[10] & !RamWriteProt[10] & !IntegraRomSel[10])
| (!RnW & Phi2 & !nRamBankSel[11] & !RamWriteProt[11] & !IntegraRomSel[11])
| (!RnW & Phi2 & !nRamBankSel[12] & !RamWriteProt[12] & !IntegraRomSel[12])
| (!RnW & Phi2 & !nRamBankSel[13] & !RamWriteProt[13] & !IntegraRomSel[13])
| (!RnW & Phi2 & !nRamBankSel[14] & !RamWriteProt[14] & !IntegraRomSel[14])
| (!RnW & Phi2 & !nRamBankSel[15] & !RamWriteProt[15] & !IntegraRomSel[15])
| (!RnW & Phi2 & ShadowSel));
// This logic sets PrvAct to logic state '1' if the addresses in the Private memory range &8000..&AFFF and if one of the Private Memory flags is active.
reg PrvEn;
reg PrvS8;
reg PrvS4;
reg PrvS1;
assign PrvAct = ((bbc_ADDRESS[15:12] == 4'h8) & (bbc_ADDRESS[11:10] == 2'b00) & PrvS1 & PrvEn //address decodes to &8000..&83FF. Maps to &0000..&03FF in Shadow RAM
| (bbc_ADDRESS[15:12] == 4'h8) & PrvS4 & PrvEn //address decodes to &8000..&8FFF. Maps to &0000..&0FFF in Shadow RAM
| (bbc_ADDRESS[15:12] == 4'h9) & PrvS8 & PrvEn //address decodes to &9000..&9FFF. Maps to &1000..&1FFF in Shadow RAM
| (bbc_ADDRESS[15:12] == 4'hA) & PrvS8 & PrvEn); //address decodes to &A000..&AFFF. Maps to &2000..&2FFF in Shadow RAM
// This logic sets ShAct to logic state '1' if the addresses in the screen range &3000..&7FFF and if Shadow Memory is active.
reg ShEn;
reg MemSel;
wire ScreenMem = ((bbc_ADDRESS[15:12] == 4'h3) //address decodes to &3000..&3FFF
| (bbc_ADDRESS[15:14] == 2'b01)); //address decodes to &4000..&7FFF
assign ShAct = ScreenMem & ShEn & !MemSel;
// ShadowSel is logic '1' when either Shadow or Private RAM is being accessed.
// Note that Shadow and Private memory is mapped to a 32k Block of RAM as follows:
// Function | BBC Memory | 32K RAM
// Screen memory | 3000..7FFF | 3000..7FFF
// Private Prv1 | 8000..83FF | 0000..03FF
// Private Prv4 | 8000..8FFF | 0000..0FFF
// Private Prv8 | 9000..AFFF | 1000..2FFF
assign ShadowSel = !(!ShAct & !PrvAct);
// The following logic is used to demux the ROM banks.
// Banks 0..3 are located on the Beeb mainboard. These banks can be switched out for SWRAM on the IntegraB board instead
// Banks 4..7 are SWRAM banks located on the IntegraB board
// Banks 8..15 are ROM slots on the IntegraB board. These banks can be switched out for SWRAM on the IntegraB board instead
// All SWRAM can be write protected in 16k banks.
reg rD0;
reg rD1;
reg rD2;
reg rD3;
wire ROMDec;
assign to_bbc_rD0 = rD0;
assign to_bbc_rD1 = rD1;
// If address is in range &8000..&BFFF then SWRAddr = 1, otherwise 0
wire SWRAddr = (bbc_ADDRESS[15:14] == 2'b10);
// Check if address is in the range &8000..&BFFF and it's not Private RAM that's being accessed.
assign ROMDec = (SWRAddr & !PrvAct & Phi2
| SWRAddr & !PrvAct & !nRomBankSel0_3);
// GenBankSel[x] is logic '1' when bank is selected
// wire GenBankSel[15:0];
assign GenBankSel[0] = !rD3 & !rD2 & !rD1 & !rD0 & ROMDec;
assign GenBankSel[1] = !rD3 & !rD2 & !rD1 & rD0 & ROMDec;
assign GenBankSel[2] = !rD3 & !rD2 & rD1 & !rD0 & ROMDec;
assign GenBankSel[3] = !rD3 & !rD2 & rD1 & rD0 & ROMDec;
assign GenBankSel[4] = !rD3 & rD2 & !rD1 & !rD0 & ROMDec;
assign GenBankSel[5] = !rD3 & rD2 & !rD1 & rD0 & ROMDec;
assign GenBankSel[6] = !rD3 & rD2 & rD1 & !rD0 & ROMDec;
assign GenBankSel[7] = !rD3 & rD2 & rD1 & rD0 & ROMDec;
assign GenBankSel[8] = rD3 & !rD2 & !rD1 & !rD0 & ROMDec;
assign GenBankSel[9] = rD3 & !rD2 & !rD1 & rD0 & ROMDec;
assign GenBankSel[10] = rD3 & !rD2 & rD1 & !rD0 & ROMDec;
assign GenBankSel[11] = rD3 & !rD2 & rD1 & rD0 & ROMDec;
assign GenBankSel[12] = rD3 & rD2 & !rD1 & !rD0 & ROMDec;
assign GenBankSel[13] = rD3 & rD2 & !rD1 & rD0 & ROMDec;
assign GenBankSel[14] = rD3 & rD2 & rD1 & !rD0 & ROMDec;
assign GenBankSel[15] = rD3 & rD2 & rD1 & rD0 & ROMDec;
// Logic to select Motherboard ROM Banks 0..3
// Check if bank is mapped to ROM on beeb motherboard, or to RAM on IntegraB board
// GenBankSel[x] is the output of the 4..16 line decoder. Logic '1' if output is decoded
// BeebRomSel[x] is based on jumper selection via pull up resistor. Logic '1' selects motherboard ROM. Logic '0' selects onboard RAM
// nRomBankSelB[x] is logic '0' when bank is selected otherwire logic '1'
wire nRomBankSelB[3:0];
assign nRomBankSelB[0] = !(GenBankSel[0] & BeebRomSel[0]);
assign nRomBankSelB[1] = !(GenBankSel[1] & BeebRomSel[1]);
assign nRomBankSelB[2] = !(GenBankSel[2] & BeebRomSel[2]);
assign nRomBankSelB[3] = !(GenBankSel[3] & BeebRomSel[3]);
assign nRomBankSel0_3 = nRomBankSelB[0] & nRomBankSelB[1] & nRomBankSelB[2] & nRomBankSelB[3];
// Logic to select IntegraB ROM Banks 8..15
// Check if bank is mapped to ROM on IntegraB board, or to RAM on IntegraB board
// IntegraRomSel[x] is based on jumper selection via pull up resistor. Logic '1' selects IntegraB ROM socket. Logic '0' selects onboard RAM
// nRomBankSel[x] is logic '0' when bank is selected otherwire open collector
assign nRomBankSel[8] = (GenBankSel[8] & IntegraRomSel[8]) ? 1'b0 : 1'bz;
assign nRomBankSel[9] = (GenBankSel[9] & IntegraRomSel[9]) ? 1'b0 : 1'bz;
assign nRomBankSel[10] = (GenBankSel[10] & IntegraRomSel[10]) ? 1'b0 : 1'bz;
assign nRomBankSel[11] = (GenBankSel[11] & IntegraRomSel[11]) ? 1'b0 : 1'bz;
assign nRomBankSel[12] = (GenBankSel[12] & IntegraRomSel[12]) ? 1'b0 : 1'bz;
assign nRomBankSel[13] = (GenBankSel[13] & IntegraRomSel[13]) ? 1'b0 : 1'bz;
assign nRomBankSel[14] = (GenBankSel[14] & IntegraRomSel[14]) ? 1'b0 : 1'bz;
assign nRomBankSel[15] = (GenBankSel[15] & IntegraRomSel[15]) ? 1'b0 : 1'bz;
// Logic to select IntegraB RAM Banks 0..15
// Check if bank is mapped to ROM on either beeb motherboard / IntegraB board, or to RAM on IntegraB board
// IntegraRomSel[x] is based on jumper selection via pull up resistor. Logic '1' selects motherboard ROM. Logic '0' selects onboard RAM
// nRamBankSel[x] is logic '0' when bank is selected otherwire logic '1'
assign nRamBankSel[0] = !(GenBankSel[0] & !BeebRomSel[0]);
assign nRamBankSel[1] = !(GenBankSel[1] & !BeebRomSel[1]);
assign nRamBankSel[2] = !(GenBankSel[2] & !BeebRomSel[2]);
assign nRamBankSel[3] = !(GenBankSel[3] & !BeebRomSel[3]);
assign nRamBankSel[4] = !(GenBankSel[4]);
assign nRamBankSel[5] = !(GenBankSel[5]);
assign nRamBankSel[6] = !(GenBankSel[6]);
assign nRamBankSel[7] = !(GenBankSel[7]);
assign nRamBankSel[8] = !(GenBankSel[8] & !IntegraRomSel[8]);
assign nRamBankSel[9] = !(GenBankSel[9] & !IntegraRomSel[9]);
assign nRamBankSel[10] = !(GenBankSel[10] & !IntegraRomSel[10]);
assign nRamBankSel[11] = !(GenBankSel[11] & !IntegraRomSel[11]);
assign nRamBankSel[12] = !(GenBankSel[12] & !IntegraRomSel[12]);
assign nRamBankSel[13] = !(GenBankSel[13] & !IntegraRomSel[13]);
assign nRamBankSel[14] = !(GenBankSel[14] & !IntegraRomSel[14]);
assign nRamBankSel[15] = !(GenBankSel[15] & !IntegraRomSel[15]);
// Logic to Enable RAM IC
// If any RAM bank or shadow / private RAM is being accessed, then nRAM_CE is logic '0' otherwise logic '1'
assign nRAM_CE = nRamBankSel[0] & nRamBankSel[1] & nRamBankSel[2] & nRamBankSel[3]
& nRamBankSel[4] & nRamBankSel[5] & nRamBankSel[6] & nRamBankSel[7]
& nRamBankSel[8] & nRamBankSel[9] & nRamBankSel[10] & nRamBankSel[11]
& nRamBankSel[12] & nRamBankSel[13] & nRamBankSel[14] & nRamBankSel[15] & !ShadowSel;
// RAM addresses A0..A13 and data lines D0..D7 are wired to the CPU (via buffers on the IntegraB board)
// RAM addresses A14..A18 are switched by the CPLD based on which RAM bank has been selected
// ShadowSel is a 32k block based on Shadow RAM and Private RAM. A14 switches between the upper and lower bank.
assign Ram_ADDRESS[14] = rD0 & !ShadowSel
| bbc_ADDRESS[14] & ShadowSel;
assign Ram_ADDRESS[15] = rD1 & !ShadowSel;
assign Ram_ADDRESS[16] = rD2 & !ShadowSel;
assign Ram_ADDRESS[17] = rD3 & !ShadowSel;
assign Ram_ADDRESS[18] = ShadowSel;
// Logic to control RTC address and data strobe lines
assign RTC_AS = FE38_B && Phi2 && !RnW; // &FE38..B -> Address Strobe
assign RTC_DS = FE3C_F && Phi2; // &FE3C..F -> Data Strobe
// Logic to enable the data buffer.
// Buffer needs to be enabled (logic low) when accessing onboard SWRAM, SWROM, Shadow RAM, Private RAM, or when writing data to registers &FE30..&FE3F
assign nDBuf_CE = !SWRAddr & !ShadowSel & !FE3x
| !nRomBankSel0_3 & !ShadowSel & !FE3x; // this line ensures the IntegraB data buffer not active when accessing off board SWROM
//This data is latched when address is in the range FE30..FE33
//rD0..rD3 are used to decode the selected SWROM bank
always @(negedge Phi2 or negedge bbc_nRST) begin
if (!bbc_nRST) begin
rD0 <= 1'b0;
end else if (!RnW && FE30_3) begin
rD0 <= bbc_DATA[0];
end
end
rD1 <= 1'b0;
rD1 <= bbc_DATA[1];
end
end
rD2 <= 1'b0;
rD2 <= bbc_DATA[2];
end
end
rD3 <= 1'b0;
rD3 <= bbc_DATA[3];
end
end
//PrvEn is used in conjunction with addresses in the range &8000..&AFFF to select Private RAM
PrvEn <= 1'b0;
PrvEn <= bbc_DATA[6];
end
end
MemSel <= 1'b0;
MemSel <= bbc_DATA[7];
end
end
//This data is latched when address is in the range FE34..FE37
PrvS8 <= 1'b0;
end else if (!RnW && FE34_7) begin
PrvS8 <= bbc_DATA[4];
end
end
PrvS4 <= 1'b0;
PrvS4 <= bbc_DATA[5];
end
end
PrvS1 <= 1'b0;
PrvS1 <= bbc_DATA[6];
end
end
ShEn <= 1'b0;
ShEn <= bbc_DATA[7];
end
end
endmodule
