2nd Batch of the New AP6 and probably the last batch!
Post by daveejhitchins » Sun May 03, 2020 3:58 pm
Getting ready to order a few prototypes of the 2nd batch of the New AP6 PCB 1V3.
What's changed from 1V2?
1) Fixed an error on 1V2 relating to J6 - You'll now be able to disable ROMs 5 & 6
2) I've fitted a link so that when changed over you'll be able to program, in situ, IC1 - the AP6 ROM
3) I've managed to squeeze-in a battery (as fitted to the ABR/ATI) and a MCP79410 RTC!
4) Tentative: A way of accessing the upper half of the 2nd bank of the AP6 ROM (a 28C256). Currently taken up by TreeCopy. However, if I can find a way to do this then there'll be room for the RTC code. E.g. The first 16K will be the AP6 ROM - the first 8K of the second 16K will be identical to the bottom 8K of the first 16K with the second 8k of the second 16K being the RTC code. If not possible then it will require a second ROM :(
As in the subject - this will probably be the last batch of AP6s that I'll be making. I'll put all the design files in GitHub. So if anyone wants to make themselves one, in the future, it should be easy enough.
Comments . . .
Retro Hardware New AP6 07-05-20.zip
(204.59 KiB) Downloaded 10 times
Edit (07-05-20): Added Schematic and list of functions available.
Jumpers:
1) Disable ROM 13 - For when a fitted cartridge also uses ROM13.
2) Disable ROM 4 - For when the Acorn Plus 3 is fitted.
3) Disable ROMs 4, 5, 6 & 7 - For when Prime's Acorn Plus 3 ROM/RAM board is fitted.
4) Disable ROMs 13 & 15 - Enables reprogramming of corrupt device in situ.
5) Enable ROM 5/6 for 32K
6) Disable ROMs 5 & 5/6 - Enables reprogramming of corrupt device in situ.
Up to 7 16K images in EPROM/EEPROM/SRAM
Software write protection for sockets 5, 5/6 and 13/15 (for EEPROM/RAM)
Support for 24K in IC1 (16K base + 8K in upper 16K of the supplied 28C256)
Support for Reprogramming IC1 in place
Support for MCP79410-RTC (Battery backed)
Last edited by daveejhitchins on Thu May 07, 2020 3:18 pm, edited 2 times in total.
KenLowe
Re: 2nd Batch of the New AP6 and probably the last batch!
Post by KenLowe » Sun May 03, 2020 4:05 pm
Yes, please :D .
rmbrowngr
Post by rmbrowngr » Sun May 03, 2020 7:28 pm
Possibly interested in one if I can source a reasonable priced Plus 1 for my second Electron. All the Plus 1’s on eBay are way over priced.
Richard B
egel
Post by egel » Mon May 04, 2020 3:30 pm
Yes, please :D .
0xC0DE
Post by 0xC0DE » Mon May 04, 2020 5:17 pm
Yes please!! =D>
0xC0DE
Post by jgharston » Mon May 04, 2020 5:22 pm
Use the existing *SRPAGE method? Write a sequence of bytes to &AFFF.
Post by daveejhitchins » Mon May 04, 2020 8:01 pm
That's just for the AP5, Jonathan - There isn't the addressing available in the AP6. But (see the latest eMail) I have a method that should work within the Prestel Hardware address range that is available.
Post by daveejhitchins » Thu May 07, 2020 3:11 pm
mr-macrisc
Post by mr-macrisc » Thu May 07, 2020 3:43 pm
Add me to list :)
Post by richardtoohey » Thu May 07, 2020 10:34 pm
Me too, please. :D
walkerworks
Post by walkerworks » Thu May 07, 2020 10:46 pm
And me too, please. :D
bygonebytes.co.uk
rharper
Post by rharper » Fri May 08, 2020 11:24 am
One for me please.
Ray
Raycomp
