b+ and Gotek problems
shakesc
Post by shakesc » Fri May 01, 2020 6:52 pm
Hello
have a B+ and a gotek. The gotek has been working but havent had it that long (lockdown project).
Updated with rotary controller and OLED
It now seems to have stopped working. Do a break and *. and it just hangs (using usb that previously worked)
DFS 2.22
Flashfloppy 2.14
Smart SPI
Tried usual unplug, reflashing the gotek, different usb and same result
Checked voltage at gotek - all good
Any thoughts on what else I could check (only have a multi meter , no scope)?
Chris
BBC B+ 128K
Re: b+ and Gotek problems
Post by danielj » Fri May 01, 2020 7:40 pm
Remove SmartSPI for starters. What happens then? And what's the OLED displaying?
mark71
Post by mark71 » Fri May 01, 2020 8:04 pm
May seem a daft question, did you push the knob in after selecting a disk?, as it needs to mount the drive. I had the the same issue, works if you push in the button....
Post by tricky » Fri May 01, 2020 8:22 pm
Unlikely, but is your FF.CFG correct?
shakesc
Post by shakesc » Fri May 01, 2020 9:21 pm
So I popped the Smart SPI rom out and card reader - it was working with them before
The display shows the correct ssd file and the track indicator (or ejected)
I hadnt been using a ff.cfg
I found this on this viewtopic.php?f=3&t=15411&start=30
interface= ibmpc
host=acorn
index-suppression=no
I will try in a bit
BBC B+ 128K
shakesc
Post by shakesc » Fri May 01, 2020 10:00 pm
Well did that no luck
I did notice that the green LED is not lit at anytime
Wonder if the gotek could be doggy...
BBC B+ 128K
Post by danielj » Fri May 01, 2020 10:06 pm
Check that the cable is OK first. Then you really need another drive to check it against. Check you've not knocked off the drive number jumper? Assuming you're using a straight through cable it should be set to 0?
shakesc
Post by shakesc » Fri May 01, 2020 10:09 pm
Checked I'm on zero, thats ok and its a straight through cable
I've ordered another cable as I dont have another drive to check against
If only there was an SPI interface that does r/w
BBC B+ 128K
