BBC Master with Gotek disc light comes on and doesn't list
mark71
Post by mark71 » Fri Apr 24, 2020 10:18 am
Hi All
Just bought a Gotek drive for the BBC Master, and plugged it in and switched on no problem, the issue is when i try to list the contents of the drive the light just comes on and stays on and just hangs there waiting for something?, any ideas?.
DFS 2.24 and ADFS at 1.5, stock BBC Master, re-capped.
Re: BBC Master with Gotek disc light comes on and doesn't list
Post by danielj » Fri Apr 24, 2020 10:24 am
What firmware are you using on the Gotek? Where did you get it from? What disk image have you put on the USB stick?
dv8
Post by dv8 » Fri Apr 24, 2020 2:31 pm
The Gotek may be configured as drive 1. Try entering the command *.1 to get a catalogue of drive 1.
If that worked you can change it to drive 0 by moving the jumper near the floppy cable connector on the Gotek from position S1 to position S0.
Disc image files ending with .ssd or .dsd need to be accessed through DFS. Files ending with .adl or .adf need to be accessed through ADFS.
Assuming you're using the FlashFloppy firmware, if you want to use .adf files on the beeb you will also need to put the line 'host=acorn' in the configuration file (FF.CFG) on the USB stick. Otherwise FlashFloppy will think they are Amiga format discs.
Post by tricky » Fri Apr 24, 2020 6:56 pm
You probably want something like:
interface = shugart
host = acorn
index-suppression = no
head-settle-ms = 4
nav-mode = default
extend-image = no
I'm not 100% about nav-mode as I use
nav-mode = indexed
on my GOTEKs because I use my menu on them.
The thing with FF.CFG is the gotek remembers the settings each time is sees a new FF.CFG, so I would suggest putting all the settings in an FF.CFG on each stick you use with them.
PS Also make sure you are using DFS with .SSDs. I'm not sure what happens if you don't.
mark71
Post by mark71 » Sat Apr 25, 2020 9:48 pm
Hi All
Thanks for all the advice, figured out why it didn't work in the end, operator error, didn't read the manual properly, once a disk is selected, one needs to press it in to mount it, then one can list it's content, doh.
What i did do was to test it first on a electron with a slogger 400 dfs disc interface which i knew worked as the floppy drive for it worked, once i figured out where i went wrong, plain sailing.
Only snag now was the electron died, no beep on start up, tomorrows job see what went wrong.
thanks all.
rmbrowngr
Post by rmbrowngr » Sat Apr 25, 2020 10:38 pm
Post what the symptoms and what issue The Electron is. You’ll have to Open the Electron up to understand what issue it is.
Richard B
