The question that most comes up when people ask me about the ElkSD64 is "does it work with a plus 1?". To which the answer is, of course, no. But it got me thinking about doing something that would fit a Plus 1, especially when I obtained one thanks to the excellent Mr Dave Hitchins, of this parish.
After some false starts and much head scratching over Acorn's often less than precise documentation, I've now got something that works. It's basically a cut-down ElkSD64, with only 16K of flash and SW RAM as opposed to 32K of each on the ElkSD64. Just enough to run the sideways version of MMFS.
Pictures are of the prototype, which is fully functional. Final boards will have gold plated contacts, the prototype is just HASL as I'm cheap and didn't want to spend any more than necessary on PCBs that may not have worked at all.
The hardware is mostly now fixed except for minor tweaks but there's still some room to add to the CPLD programming. I'm thinking of a register to switch out the default SW MMFS and boot with the standard version, which would free up the 16K of SW RAM for other use while retaining SD capability. I'm hoping to have a very limited number of finished boards available by the end of the month or early next month.
