MMFS SD Card on the BBC B Printer Port?
Re: MMFS SD Card on the BBC B Printer Port?
My parts finally arrived on the slow boat from China this week and I have built my MicroSD Card version of Dave's design.
I used a pre-made 26Pin IDC cable which has the Polarised locating "Bump" and yields two adapters at a price of about a Pound from a Chinese seller on eBay. The SD Card adapter is a standard (3 for £1.56) eBay Arduino card with the Pin Header removed. I used a small piece of Double sided sticky foam tape to attach the cable to the back of the card and provide strain relief.
This sits directly on the Printer Port under the Beeb and is completely unobtrusive in use. The natural spring in the cable holds the adapter up against the base of the Beeb and the Connector clips hold it securely in place. The MicroSD Card is accessable without removing the adapter. I used a pre-made 26Pin IDC cable which has the Polarised locating "Bump" and yields two adapters at a price of about a Pound from a Chinese seller on eBay. The SD Card adapter is a standard (3 for £1.56) eBay Arduino card with the Pin Header removed. I used a small piece of Double sided sticky foam tape to attach the cable to the back of the card and provide strain relief.
- flaxcottage
Very nice. It is amazing what can be done these days. Think how good that would have been in 1984!!
Here is my effort, just the same as Wheel-nut, but I encapsulated the pcb with shrink sleeving.
Now on to my master 128......
Electron Plus 1 Pres AP3/4
StrongA RPC, A3020
Atom
StrongA RPC, A3020
Atom
Neat job DaveLecky. I have successfully installed these on three Issue 7 Beebs and two Issue 3 Beebs and use them with P/ZMMFS 1.44.
I don't have a Master but I am sure that the Printer Port modification will be the same though you will be using P/MAMMFS 1.44 which, if I understand the Master correctly, runs in reserved memory anyway.
- JasonStonier
Is there a schematic of this anywhere - I've searched in the Github and on the forum but I'm clearly missing something. I can derive it from your two photos easily enough, just wondered if there was a proper document. Thanks.Wheel_nut wrote: ↑Thu Oct 03, 2019 3:20 pmI used a pre-made 26Pin IDC cable which has the Polarised locating "Bump" and yields two adapters at a price of about a Pound from a Chinese seller on eBay. The SD Card adapter is a standard (3 for £1.56) eBay Arduino card with the Pin Header removed. I used a small piece of Double sided sticky foam tape to attach the cable to the back of the card and provide strain relief.
Take a look earlier in this thread:JasonStonier wrote: ↑Thu Sep 24, 2020 9:18 amIs there a schematic of this anywhere - I've searched in the Github and on the forum but I'm clearly missing something. I can derive it from your two photos easily enough, just wondered if there was a proper document. Thanks.
viewtopic.php?p=246995#p246995
As Dave has said, the schematic and wiring instructions are all in the first page of this thread but if you need further help, PM me and I will do my best to assist.JasonStonier wrote: ↑Thu Sep 24, 2020 9:18 amIs there a schematic of this anywhere - I've searched in the Github and on the forum but I'm clearly missing something. I can derive it from your two photos easily enough, just wondered if there was a proper document. Thanks.
Robin
- JasonStonier
How the hell did I miss that! Thanks, and sorry for not doing my research properly...genuinely embarrassed.hoglet wrote: ↑Thu Sep 24, 2020 1:04 pm
- JasonStonier
Well, I made the interface, added the mod wiring to the beeb, and then burned entirely the wrong binary to my last remaining blank eprom.
Now waiting for my UV steriliser to arrive so I can blank some eproms and try again.
- JasonStonier
With the right P/ZMMFS ROM installed and some SWRAM from BooBip - all works brilliantly!
Thanks to all the clever folk who have worked this scheme out: I'm in awe of your talents.
[edit to add]
I've got enough bits in to build up another, if anyone would like one.
[edit to add]
- JasonStonier
Happily using mine now, and I've built a couple for other people at cost. Really neat implementation, so thanks to everyone who worked it out and to Hoglet for the ROM.
I had a question from someone I sent one to: to get this working on the Master, what wiring mod is needed?
If I had a master I could trace it out, but I don't.
I don't think there's any wiring mod, is there? The Master printer port is the same as the Beeb one?
- JasonStonier
This is the mod wiring needed on the B - if the Master is the same layout, then happy days!
Hi Folks,
Sorry I missed this reply here, I’ve been following the other thread on this subject though...
I didn’t get round to investigating this as another project popped up....as they do.
StrongA RPC, A3020
Atom
StrongA RPC, A3020
Atom
I am duplicating the pictures of the multi-headed MMFS adapter that KenLowe designed for me. The assembled board can connect to EITHER the User Port or the Printer Port (with Hoglet's modification).
KenLowe has also tested the adapter in his Master but note that there is insufficient space in the Master to have both Headers fitted so it needs to be customised to one or other application for the Master.
This is the de-constructed Adapter components: ... and Fitted to the Beeb Printer Port:
... and fitted to the Beeb User Port:
Well Done KenLowe
Robin
Well Done KenLowe
Robin
Hi Folks
Well done everyone involved.
Another journey completed Robin.....
Stay safe
Stay safe
StrongA RPC, A3020
Atom
StrongA RPC, A3020
Atom
- JasonStonier
Hi Dave,
Have you managed to look at getting this design working on a Master?
My version of Robin's design has flying leads for the motherboard 'modification' and I'd love to know if they would work on a Master as they do on the B. Happy to send you a board to play with if you're willing to check.
Hi Jason,
I’ve not tried any of these on a master, I didn’t get round to it at the time as something else came up.
As you don’t have a master, I’m happy to test it out under your instructions as required...but I’m no expert.
StrongA RPC, A3020
Atom
StrongA RPC, A3020
Atom
