MMFS SD Card on the BBC B Printer Port?
Wheel_nut
Re: MMFS SD Card on the BBC B Printer Port?
Post by Wheel_nut »
My parts finally arrived on the slow boat from China this week and I have built my MicroSD Card version of Dave's design.
This sits directly on the Printer Port under the Beeb and is completely unobtrusive in use. The natural spring in the cable holds the adapter up against the base of the Beeb and the Connector clips hold it securely in place. The MicroSD Card is accessable without removing the adapter.
I used a pre-made 26Pin IDC cable which has the Polarised locating "Bump" and yields two adapters at a price of about a Pound from a Chinese seller on eBay. The SD Card adapter is a standard (3 for £1.56) eBay Arduino card with the Pin Header removed. I used a small piece of Double sided sticky foam tape to attach the cable to the back of the card and provide strain relief.
Post by flaxcottage »
Very nice. It is amazing what can be done these days. Think how good that would have been in 1984!! :shock:
DaveLecky
Post by DaveLecky »
Here is my effort, just the same as Wheel-nut, but I encapsulated the pcb with shrink sleeving.
Now on to my master 128......
Electron Plus 1 Pres AP3/4
StrongA RPC, A3020
Atom
Wheel_nut
Post by Wheel_nut »
Neat job DaveLecky. I have successfully installed these on three Issue 7 Beebs and two Issue 3 Beebs and use them with P/ZMMFS 1.44.
I don't have a Master but I am sure that the Printer Port modification will be the same though you will be using P/MAMMFS 1.44 which, if I understand the Master correctly, runs in reserved memory anyway.
JasonStonier
Post by JasonStonier »
Wheel_nut wrote:
Thu Oct 03, 2019 3:20 pm
Is there a schematic of this anywhere - I've searched in the Github and on the forum but I'm clearly missing something. I can derive it from your two photos easily enough, just wondered if there was a proper document. Thanks.
Post by hoglet »
JasonStonier wrote:
Thu Sep 24, 2020 9:18 am
Take a look earlier in this thread:
viewtopic.php?p=246995#p246995
Wheel_nut
Post by Wheel_nut »
As Dave has said, the schematic and wiring instructions are all in the first page of this thread but if you need further help, PM me and I will do my best to assist.
Robin
JasonStonier
hoglet wrote:
Thu Sep 24, 2020 1:04 pm
How the hell did I miss that! Thanks, and sorry for not doing my research properly...genuinely embarrassed.
JasonStonier
Well, I made the interface, added the mod wiring to the beeb, and then burned entirely the wrong binary to my last remaining blank eprom. =D>
Now waiting for my UV steriliser to arrive so I can blank some eproms and try again. :oops:
JasonStonier
With the right P/ZMMFS ROM installed and some SWRAM from BooBip - all works brilliantly!
Thanks to all the clever folk who have worked this scheme out: I'm in awe of your talents.
[edit to add]
I've got enough bits in to build up another, if anyone would like one.
JasonStonier
Happily using mine now, and I've built a couple for other people at cost. Really neat implementation, so thanks to everyone who worked it out and to Hoglet for the ROM.
I had a question from someone I sent one to: to get this working on the Master, what wiring mod is needed?
If I had a master I could trace it out, but I don't.
Post by danielj »
I don't think there's any wiring mod, is there? The Master printer port is the same as the Beeb one?
JasonStonier
This is the mod wiring needed on the B - if the Master is the same layout, then happy days!
Post by hoglet »
DaveLecky wrote:
Sun Mar 01, 2020 6:22 pm
Did you have any success in getting this to work on the Master?
DaveLecky
Post by DaveLecky »
Hi Folks,
Sorry I missed this reply here, I’ve been following the other thread on this subject though...
I didn’t get round to investigating this as another project popped up....as they do.
StrongA RPC, A3020
Atom
Wheel_nut
Post by Wheel_nut »
I am duplicating the pictures of the multi-headed MMFS adapter that KenLowe designed for me. The assembled board can connect to EITHER the User Port or the Printer Port (with Hoglet's modification).
KenLowe has also tested the adapter in his Master but note that there is insufficient space in the Master to have both Headers fitted so it needs to be customised to one or other application for the Master.
This is the de-constructed Adapter components:
... and Fitted to the Beeb Printer Port:
... and fitted to the Beeb User Port:
Well Done KenLowe =D> =D> :)
Robin
DaveLecky
Post by DaveLecky »
Hi Folks
Well done everyone involved.
=D> =D> =D> =D>
Another journey completed Robin.....
Stay safe
StrongA RPC, A3020
Atom
JasonStonier
DaveLecky wrote:
Sat Nov 14, 2020 4:41 pm
Hi Dave,
Have you managed to look at getting this design working on a Master?
My version of Robin's design has flying leads for the motherboard 'modification' and I'd love to know if they would work on a Master as they do on the B. Happy to send you a board to play with if you're willing to check.
DaveLecky
Post by DaveLecky »
Hi Jason,
I’ve not tried any of these on a master, I didn’t get round to it at the time as something else came up.
As you don’t have a master, I’m happy to test it out under your instructions as required...but I’m no expert.
StrongA RPC, A3020
Atom
