Tape - MMSD CARD/ABR reprogramming
Re: Tape - MMSD CARD
Post by danielj » Fri Aug 30, 2019 9:13 pm
Reload it all from the backup?
BeebMan2018
Post by BeebMan2018 » Fri Aug 30, 2019 9:14 pm
CMcDougall wrote:
Fri Aug 30, 2019 8:10 pm
your plus1 is fried.... somewhere :(
there must of been a loose connection, or you moved the elk /plus1 when it was doing something :|
my old rubbish Plus3 did that also, I had to rename files <3 chars, then it worked :lol:
Blowen Caps or ... ?
I've looked inside both the +1 and the Elk and could see no visable damage. No obvious burst caps or blowen / burnt resistors. Not obvious anyway but i did get a burnt smell but it was inside the elk itself ! :/
BeebMan2018
Post by BeebMan2018 » Fri Aug 30, 2019 9:15 pm
I have not made a backup of the MMFS but the guy that gave it to me might have.
ALSO, have replaced the Electron with another Electron and i get the same error with it as well. So unless they are both shot with the same fault its either the ADF Card or the, supposedly bombproof, +1. Hopefully either or can be repaired :/ So now i'm needing a maintenance guide to trouble shoot the +1 ???
Post by danielj » Sat Aug 31, 2019 5:16 am
It's more likely to be the card than the plus one. Easy things first. Get that reinstalled and go from there. I'm afraid I can't help with that bit, as I don't have one up and running - user guide here: viewtopic.php?f=3&t=5672#p66117
Post by Elminster » Sat Aug 31, 2019 7:11 am
I assume this is the card the Sydney did in thread viewtopic.php?f=3&t=17187&p=238402
Post by danielj » Sat Aug 31, 2019 7:25 am
Specifically:
viewtopic.php?f=3&t=17187&p=238402#p238158
If you didn't do as suggested then a way needs to be found of making the relevant tape...
BeebMan2018
Post by BeebMan2018 » Sat Aug 31, 2019 8:33 am
I can confirm that this is correct. It is sydneys card :(( I hope ive not broke it. I dont understand though it was fine and the elk etc was on the desk all safe n sound. :((
rharper
Post by rharper » Sat Aug 31, 2019 9:15 am
That beeb.mmb is an old one of mine which was under development - I did not realise it was out in the wild.
The Elite error is because that ssd is corrupt - I don't think it is accessed by the games menu which is probably on disc image 0 or 100.
The beeb.mmb to use is here viewtopic.php?f=3&t=12794, beeb.7z halfway down page 1. There is an updated elk-games.ssd (a bit quicker screen display) top of page 2 which can replace the original using mmbimager.
Ray
Raycomp
Post by CMcDougall » Sat Aug 31, 2019 9:19 am
so after being reminded about what happened with all my Plus1s & elks 2.5yr ago, it's the ABR!
you need another rom cartridge, then will be fine :D
BeebMan2018
Post by BeebMan2018 » Sat Aug 31, 2019 9:49 am
Cant I Repair the one i have ?
BeebMan2018
Post by BeebMan2018 » Sat Aug 31, 2019 9:54 am
Ray
Hi Ray, im quite new to the Electron 'scene' so im not very proficiant with command structure or terminology etc yet. Can you guide me through what i need to do to restore the ABR ? If its a physical fault can it not be repaired ? How do i test it to find out if its software or hardware fault ? The beeb.mmb was working fine for me. it might have been beta release but it worked and i didnt care about anything elese. Somehow this is no longer the casse and i would like to find out what happpened, how to fix it and how to ensure it wont happen again !
Post by danielj » Sat Aug 31, 2019 1:05 pm
The ROM image is probably corrupted, the fix is to reinstall. If that doesn't work its time to try other things. That's the one and only thing you need to try to do at this point.
(and to prevent it in the future, make sure you've backed up what's on the ABR as originally suggested :))
BeebMan2018
Post by BeebMan2018 » Sat Aug 31, 2019 3:15 pm
Hi daniel, I had a nagging recollection and on checking I DID do the backup think for the ABR Utilities so i have a cassette with the stuff on it. Now how do i get it back to the ABR ??? :/
Post by danielj » Sat Aug 31, 2019 3:27 pm
Excellent. What does it say in the manual? I can't read it on my phone.
Post by daveejhitchins » Sat Aug 31, 2019 3:39 pm
When you saved the contents of the ABR did you save them from the program that ran after typing *ABR ?
If you did then read the section describing *LOADROM.
you’ll need your tape/tapes of both the saved ABR utilities and the ROM image you need to re-load.
ABR utils tape first: /*run LOSDROM <file name> (this maybe wrong! Could someone verify or correct me, please? I’m not in a position to access a user guide!)
Change the tape and run it. I’ll have to give it a try when I get some free time!
Can’t say I’ve ever done this, so I maybe giving you wrong information, sorry!!
BeebMan2018
Post by BeebMan2018 » Sat Aug 31, 2019 10:28 pm
I had a look at the manual and tryed to load but got errors Bad Program and another try gave No RAM so im eiter doing it wrong , which is most likely, or something is stuffed or maybe both ! I will wait for instruction as i have no clue what im doing currently regarding the ABR.
Post by sydney » Sun Sep 01, 2019 5:52 am
What commands did you try?
You say you 'did the backup thing for the ABR Utilities' but did you also backup the ABR ROM and the EMMFS ROM? What files are on the tape?
Post by danielj » Sun Sep 01, 2019 6:04 am
This. We can't tell you what you did wrong if you don't tell us what you did!
Post by daveejhitchins » Sun Sep 01, 2019 6:14 am
When using LOADROM the load sequence is: (1) find <file> (2) unlock ABR (3)load <file> (4) lock ABR
You could try unlocking your ABR first by typing:
?&FCDC=0 then ?&FCDE=0 - this will unlock the ABR regardless of which cartridge slot it’s in.
Then you can try LOADROM from tape again. The correct syntax is:
*/LOADROM <file name>
If that fails then we’ve 2 options: (1) I can make you a tape with the ABR test program on it (this would also load the utilities back onto the ABR) or (2) you could send me your ABR to check-out/repair?
BeebMan2018
Post by BeebMan2018 » Sun Sep 01, 2019 6:10 pm
:/ Alright i dont know what im doing concerning the ABR. Ive checked the tape and it has :-
!Boot
Lock
Unlock
SaveROM
LoadROM
PrintBuf
MakeROM
Zero
and
VldROM
If memory serves all i tryed to do is Load"LoadROM" and got the Bad Program error. I cant remember what command game me No RAM error. While i played with the Elk in my youth it was always about the games. Later in life i discovered the Amiga and then the PC off course. I attended college in my 20's and did some computer studies and programming courses but they were short and fast and a long time ago. I have very little knowledge concerning the Acorn Electron apart from what i'm learning from the User Guide and INPUT magazines :/ Sorry i cant be of more help :/ I'm more 'familiar' with PC architecture these days, even my commodore knowledge is getting faint :/
BeebMan2018
Post by BeebMan2018 » Sun Sep 01, 2019 7:27 pm
Hi Dave, The test tape ! What are the options for a digital download and then to record to cassette ? What equipment would i need to record to tape from pc ? Reason im asking is i am already wanting back on my electron and don't want to wait on snail mail. ! :) Also i wont learn anything if i let you do it for me :) Although i guess i will need guidance ! Let me know your thoughts.
Post by daveejhitchins » Sun Sep 01, 2019 8:33 pm
The longest time will be me preparing the tape, after that the one day postage will seem insignificant!!! I’m a bit tied up with a list of things to do, sorry.
I maybe able to get it done by Friday, otherwise at the weekend.
Post by sydney » Sun Sep 01, 2019 10:13 pm
There are no ROMS on that tape.
In the past I've managed to get a ROM onto tape from a PC but it's a bit long winded and it was 6 years ago so I don't remember actually doing it. Here's a link to the thread where I describe how to do it.
viewtopic.php?f=3&t=5214&p=59173&hilit=Upurs#p59173
You'll need both the ABR and EMMFS ROMS on the tape just in case they become corrupted in the future.
You might be better off waiting for Dave to do it for you.
BeebMan2018
Post by BeebMan2018 » Mon Sep 02, 2019 2:54 pm
Hi Dave, After looking at Sydneys guide I think I will wait for you to make a tape :/ I don't understand why this happened though :/ Its not as if i pulled the ABR out when the power was on so how come ? I didn't lift the ELk either. :/
Post by daveejhitchins » Mon Sep 02, 2019 4:35 pm
I’ll sort something out for you ASAP.
BeebMan2018
Post by BeebMan2018 » Tue Sep 03, 2019 8:37 pm
Good man Dave ! :) Ive got a bit of reading to catch up on in the meantime anyway :)
Post by CMcDougall » Mon Sep 09, 2019 9:23 pm
found a ABR disc, & had file U: unlock/lock/romload , so used BeebEm414 to make a .UEF 'tape'
don't use FreeUEF as that only works with 30% of .UEF files, so use :
http://www.8bitkick.cc/playuef.html
and have laptop volume at 20-30%
worth a go..... :?
EDIT : http://playuef.8bitkick.cc/?LOCAL=true : use browse.... button to pick the file from your local HD drive
PPS, not tried BeebEm.uef maker on this, so can't confirm if 100%
ABR unlock lock romload.uef
uef from BeebEm414
(1.57 KiB) Downloaded 5 times
Post by daveejhitchins » Tue Sep 10, 2019 6:43 am
Paul ( BeebMan2018) should have a tape, with all he needs, today along with a Plus 1 Support ROM.
BeebMan2018
MMFS RESET / FORMAT / RESTORE / REPROGRAM ?
Post by BeebMan2018 » Wed Sep 11, 2019 12:00 am
OK Guys, Some of you will be aware i've a sick Elk System. So far we think the Elk itself is OK and the +1 Rom has been replaced. Thanks Dave. Ive also got a new 32Gb Micro SD Card. Need to try that next after format FAT 32 and fresh Beeb.mmb is copied onto it. I feel however that wont solve the issue and I'm going to be faced with flashing or reprogramming the ABR and putting a new MMFS on it. Am i even explaining this correctly ? Im not up to speed on the Acorn jargon yet :/ Sorry guys. So i've looked at the MMFS Wiki on git hub and partially scanned the BBC Disc Filing System User Guide but it confuses me to be honest as its a tad long winded and yea. Sooo maybe tomorrow i might want to tackle doing the mmfs on the abr. I have the tape with the utils and a version of mmfs and i've some instructions on loading it but i'm still unsure. I'm over thinking this. I always do this. but do i need to pull the battery first to reset it or do i need to erase the software on the ABR first some way.. ??? its late and i shouldn't post when its as late as this as i'm likely not thinking clearly but want to get it up to you guys before the morning so maybe i can get some advice by tomorrow evening so i might get a chance to tackle it. Been missing the ELK :)
Re: MMFS RESET / FORMAT / RESTORE / REPROGRAM ?
Post by daveejhitchins » Wed Sep 11, 2019 12:46 pm
From the User Guide:
9 - PCB Jumpers
ABR: J3 – Remove to clear RAM. J4 – Remove to inhibit RAM.
ATI: J5 – Remove to clear RAM J6 – Remove to inhibit RAM.
J4 – 1 & 2 linked = RAM 1/3 mapped to sideways bank 13
J4 – 2 & 3 linked = Normal
So, one of two way to clear the ABR memory is to open-up the ABR and remove J3 - count to 10 - refit J3 and refit into the case.
A second way is just to issue the command (now you have the Plus 1 Support ROM): *ZERO <bank number*) UL - Clear both banks - If in doubt clear all 4!
* Back slot = 0/1 Front slot = 2/3
Once you've done that just try : *UROMS - This should list the ROMs you have in your machine. But more importantly it should reveal the ABR as containing RAM. Make a Note of which banks show-up as RAM - you'll need this for the loading, below.
If all works as described above then you can connect up your tape deck - and, from side B of the tape I sent you (you'll need to fit side B upmost and ensure you rewind it) issue the command: *LOADROM EMMFS <one of the bank numbers from above> UL - You should then be prompted to start your tape and press RETURN.
Once done: Ctrl/Brk followed by *ROMS - this should show EMMFS in the bank you specified.
Good luck - Dave H :D
