A Little Help Please !
BeebMan2018
Post by BeebMan2018 » Sat Jun 08, 2019 12:18 am
Hey guys its me again,
OK So to update you that don't recognize me. I'm new and have just plugged in an MMFS into my +1. I also have an SD Card plugged into my printer port !
OK so when i first boot i generally do the following.
*DISC
*DCAT3 (4 DISCS FOUND)
*DIN2 (I THINK THIS IS THE SD CARD BUT ITS UNNAMMED AND I DON'T YET KNOW HOW TO RENAME IT)
*CAT (LISTS THE FILES IN DIN2)
OK So from here i can type in my basic and save them to DIN2 and thats all fine. Im struggling a little finding my way about the DFS and using it but that will come with time. My main issue right now is before i got the MMFS and SD Card i saved some listings to tape. I would like to load them from tape and now save them to the SD Card but i dot know how :/ Am i overthinking this ?
Re: A Little Help Please !
Post by Elminster » Sat Jun 08, 2019 12:22 am
I don’t have one, but would it not be something like.
*TAPE
LOAD “”
LIST
*DISC
SAVE “Somename”
duikkie
Post by duikkie » Sat Jun 08, 2019 6:43 am
maybe you can read the manual ?
to save from tape to sd card:
*tape
load or *load program
i think by mmfs
*card or commando for mmfs rom
*din xxx (xxx=0 to 512)
save or *save your program
repeat the proces
*DISC
rharper
Post by rharper » Sat Jun 08, 2019 3:14 pm
*DIN 0 2 will load disk image 2 into Drive 0
*TITLE Disk2name will set the title of the disk which the system uses for the names of the disk images.
Then *DIN 0 Disk2name will do the same as *DIN 0 2
You can of course load to any of the 4 (n=0-3) Drives. *DRIVE n will take you there.
Ray
Raycomp
