2Mhz clock from 4Mhz crystal
simonm
Post by simonm » Sun Jun 02, 2019 1:41 pm
Hi folks, I've got an electronics question that Google hasn't been able to help me with, and I know wizards live here.
Are there any clever tricks to get a 2Mhz clock signal out of a 4Mhz crystal?
I have a project where I want to drive two chips - one at 4Mhz and one at 2Mhz but I only have 4Mhz crystals.
I'm getting the idea I need a counter chip probably (4060 maybe) but perhaps theres other options?
TIA!
Re: 2Mhz clock from 4Mhz crystal
Post by hoglet » Sun Jun 02, 2019 1:46 pm
All you need is a single D-type FF:
(https://www.electronics-tutorials.ws/co ... unt_1.html)
simonm
Post by simonm » Sun Jun 02, 2019 2:15 pm
Fantastic thanks! This looks perfect. Will an SN74LS74AN do the trick?
Post by oss003 » Sun Jun 02, 2019 2:20 pm
Just look at the Atom schematic, the CPU clock has a 4mHz crystal and an 393 to generate 1 mHz. Another output of the 393 is 2 mHz.
Post by 1024MAK » Sun Jun 02, 2019 4:23 pm
Yes, half a 74LS74, 74HC74 or 74HCT74 will do the job.
bprosman
Post by bprosman » Sun Jun 02, 2019 10:30 pm
The MPF-1B is one of the designs that uses this.
Clock in on pin 3, Clock/2 out on pin 6.
