I'm trying to work out which are the correct versions of Acorn DFS & ADFS for the B+ to have PAGE at E00. I'm looking at this page http://mdfs.net/System/ROMs/Filing/Disk/Acorn/. I believe the correct version for ADFS is 1.31 (ADFS131E00). For DFS I know the last version is 2.26 (which I have) and includes SWRAM utils.
I see that some people have both DFS and ADFS installed on their machines. Do both of them sit happily together and what happens to PAGE?
For ADFS131EOO, how do you set this up to work correctly? Does it only work loaded into SWRAM, or can you put it in an EPROM and it will use SWRAM for its work space?
Finally, I believe that ADFS131E00 supports SCSI hard disks, so I guess I can add a BeebSCSI.
Richard B
They both need to be installed in SWRAM as they use the space above their rom code as workspace. PAGE then remains at &E00 but you get DFS and ADFS in the machine. I use a DS1230Y 32KB NVRAM to hold them both so that they're available on power-up - that way, they're semi-permanently in SWRAM.
It does work with BeebSCSI but there is a downside. A bunch of commands are missing like *DESTROY and there is no help. So I end up using ADFS 1.30 a lot of the time anyway.
Coming back to this afternoon some time. I suppose you can combine rom and ram with some address decoding on a single board to get page at E00 and not load ADFS or DFS in SW RAM each time you boot?
Also B+ sockets being configurable as 32k you could have both ADFS and DFS on a single plugin board I guess?
Richard B
