Master ROM - what does it do?
Aaron76
Post by Aaron76 » Mon Apr 22, 2019 4:28 pm
Hi there,
I wonder if anybody can shed any light on a ROM I've found in one of my old machines. It's labelled as the 'Master ROM', with a blue background and white text. Does anybody know what special options it provides over the standard Acorn stuff?
I have no working Master machines at the minute due to PSU capacitors blowing up, so curious what it is! Any information most welcome!
Aaron
AndyF
Re: Master ROM - what does it do?
Post by AndyF » Mon Apr 22, 2019 8:35 pm
I could be wrong but I have a vague recollection of seeing a W.E advert for a 'Master Rom' , it was if (again not sure!) a controller ROM to allow you to enable/disable other roms on a 'B , a bit like an *UNPLUG effect I suppose amongst some other features.
I'm not 100% sure if it was this one I was thinking of or not though > http://classicacorn.computinghistory.or ... board.html
EDIT... Correct link would be helpful!
Then again I keep thinking Morley but it may of been Watford, but I think Morley was more likely. :-k
Andy
KenLowe
Post by KenLowe » Mon Apr 22, 2019 8:57 pm
The Master ROM that I have is a PALPROM device that sits in a carrier board, and was published by Beebbugsoft. I've not really used it, but having just plugged it in I can see that there are a lot of utility commands, which I guess attempts to emulate some of the additional functions that are standard on the Master.
Edit: http://www.8bs.com/othrdnld/manuals/app ... M_View.zip
Post by lurkio » Mon Apr 22, 2019 9:01 pm
Found this review of the Beebug Master ROM:
Post by DutchAcorn » Tue Apr 23, 2019 10:16 am
I made a quick scan of the user guide. You can download it from my dropbox using this link.
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 24, 2019 5:33 pm
I have one I found on an old floppy called the Master Emulation Rom (MER) not sure who its by, i'll have a look when i get home. It's as you mention, provides commands (like srload) that were only available on the Master.
James
BBC Model A Issue 3 (Upgraded to Model B, had it since I was a kid), Opus Dual 40/80 FDD, Watford Mouse, Voltmace delta 14/B, Gotek, IFEL ROMRAM-B4, Pi-Zero CoPro
Master 128, VideoNuLA, Gotek
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 24, 2019 5:36 pm
I found another one the other day called MAX (the beebug master rom reminded me of it) it provides a control panel (think of the control panel program on the Master Welcome disk) but it's AMX styled and uses the mouse.
Pretty cool, at least it would be if the tracking wasn't so slow!!, and that's one of the things you can't change!!
James
Aaron76
Post by Aaron76 » Mon Apr 29, 2019 9:37 pm
Thanks everyone! Great support, many thanks :) I'll go investigate it further!
