Master IO Controller IC15 - Databus pins?
simoni
Post by simoni » Sat Apr 13, 2019 11:41 am
The IO Controller IC15 in the Master (CF30050) has two data pins D4 and D5 connected to the CPU databus CD4 and CD5.
Does anyone know why? :)
(Even better if someone can point me in the direction of some reverse engineering for this chip)
Re: Master IO Controller IC15 - Databus pins?
Post by MartinB » Sat Apr 13, 2019 12:24 pm
This doesn't really answer your question but perhaps offers a clue in that checking the integrity of those two pin connections is called up in the Master Service Manual in the context of fault-finding both the 1MHz Bus and the Tube.... :-k
dp11
Post by dp11 » Sat Apr 13, 2019 12:28 pm
There are used to select between internal and external tube and 1MHz bus. ( fe34)
dp11
Post by dp11 » Sat Apr 13, 2019 12:39 pm
If you haven't see this thread , it might be worth a read . viewtopic.php?f=3&t=13964&p=184473&hilit=IC15#p184473
simoni
Post by simoni » Sat Apr 13, 2019 12:46 pm
Thanks! Makes a lot of sense :) &FE34 is the ACCCON register though... the documentation (Acorn engineering news 1) says that ACCCON is contained in the Memory Controller though (IC20):
https://github.com/simoninns/Acorn-Mast ... gNews1.pdf
Which is why I was a bit confused... I guess the Acorn engineering note is wrong then?
Ah, just seen your link (popped up as I was typing this); I will have a read through.
