My New BBC Master
SpaceFlightOrange
My New BBC Master
Post by SpaceFlightOrange » Wed Apr 10, 2019 8:44 am
I shared this in the "Today I received..." Thread, but I had to share it again!!
I'm so chuffed with this, and a little bit confused.
The case belies what is inside. I bought it from a computer disposal company, I was able to collect as they are only down the road from work.
I have no idea where it came from, but my guess is a lab of some sort, rather than a school, given the obvious lack of abuse it's had.
Its a bog standard Master, but inside it looks brand new!
The pins on the chips are still shiny
I've made up a replacement battery pack, utilising the diode/resistor combo from the original pack, and everything seems to work perfectly. the X2's in the PSU are of the non-exploding variety, so I've left them in for the time being and the startup is quick and clean, so I think C9 is ok.
Stunt Car Racer is amazing!!
I really want to put my VideoNuLa in this but i don't think I'm ready to desolder the ULA just yet.
I have a couple of questions.
Is this unusual, to find a 30 year-old beeb in this kind of condition internally?
Any tips for getting rid of the pen on the case and other cleaning up of the scratches (below the pen, it looks like someone has attempted to scratch out a number or something)?
Any tips for desoldering the ULA?
Also, I'm thinking of getting a RetroClinic MultiOS. does this contain everything that's on the MegaRom (View, ViewSheet, Edit, etc)?
James
BBC Model A Issue 3 (Upgraded to Model B, had it since I was a kid), Opus Dual 40/80 FDD, Watford Mouse, Voltmace delta 14/B, Gotek, IFEL ROMRAM-B4, Pi-Zero CoPro
Master 128, VideoNuLA, Gotek
VectorEyes
Re: My New BBC Master
Post by VectorEyes » Wed Apr 10, 2019 8:53 am
It's pretty normal to find Masters in that sort of condition. I've seen several and about half looked untouched inside, apart from the battery pack which always leaks, and the casing around the UHF modulator which is prone to rust.
Post by danielj » Wed Apr 10, 2019 8:58 am
Desoldering the ula... If you're not adept with sucker and don't have a vacuum desoldering station, it's snip the legs close to the IC and remove one at a time... However, I really can't condone destroying a working chip that's out of production and could be used to save other machines :(
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 10, 2019 9:05 am
Im ok with desoldering, generally, I think, but because I've only just got this, I don't want to risk ruining it.
I totally agree, I certainly wouldn't be prepared to ruin the ULA. which brings me onto a another question. Would the ULA in the Master work in my Issue 3 Model A (upgraded to B)? I have the VideoNuLa in there right now, but if I take that out i don't really want to put the Ferranti ULA back in.
Last edited by SpaceFlightOrange on Wed Apr 10, 2019 9:05 am, edited 1 time in total.
James
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 10, 2019 9:08 am
The modulator is the only thing that's showing signs of tarnishing. In fact it had a load of fine metal particles attached to the sides! I thought the sides were anodised at first given how it sparkled. I've cleaned them off.
James
kieranhj
Post by kieranhj » Wed Apr 10, 2019 10:28 am
Glad you're enjoying the game! :)
For the pen, I was introduced to 'magic sponge' by sbadger. It sounds too good to be true but is scarily effective. A permanent marker may take a good few passes but certainly worth a try in my experience.
ChadsArcade
Post by ChadsArcade » Wed Apr 10, 2019 11:48 am
Hairspray is also good for removing some types of permanent marker. I had some graffiti on a space invaders tabletop, tried all sorts and nothing would shift it. Tried spraying on some hairspray after reading about it on the internet and it wiped right off.
Edit: Also, if that's sticker residue on the top corner then WD-40 should shift it nicely.
Post by flaxcottage » Wed Apr 10, 2019 12:04 pm
Yes, as far as I can tell. I don't use the View ROMs or Edit - always have them unplugged. :roll:
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 10, 2019 12:52 pm
It's brilliant! Was one of my favourite games on the Amiga. you did an amazing job! Does it support Rob's VideoNula?
Thanks for the tip, I have a feeling we have some of that in the cleaning cupboard. I'll give it a go.
James
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 10, 2019 12:54 pm
Thanks, I'll give that a go.
Thanks for all the tips, folks!
James
Post by RobC » Wed Apr 10, 2019 2:27 pm
Nice machine - well done!
I've removed a good number of Video ULAs from Masters and have managed to remove the ULA intact from each one.
I use a desoldering pump with a flexible nozzle. I use lots of flux and apply new solder to any joint that doesn't clean up on the first pass.
Once all the joints on the underside have had the solder removed, I use the tip of my iron (making sure it's free from solder) to free the pins so that they sit in the middle of the holes. I then turn the board over and use the pump or desoldering braid to remove as much solder as possible from the top of the pins. Again, flux helps with the solder removal. As you might expect, I usually find that the pins connected to the power rails are the most stubborn.
When I'm satisfied that I've removed as much solder as I can and that all the pins are free, I try to gently prise the ULA away from the board. If it doesn't move easily, I check the pins again and remove any solder that's holding it in place.
Once the ULA is out, I refill the holes with new solder and clean them out again before fitting the socket.
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 10, 2019 10:41 pm
Thanks for the detailed description, Rob. Really appreciated. If I haven’t plucked up the courage by the end of the month, i’ll Bring it to the Wakefield show for you to do :lol:
Last edited by SpaceFlightOrange on Wed Apr 10, 2019 10:42 pm, edited 1 time in total.
James
Post by danielj » Wed Apr 10, 2019 10:43 pm
I'll bring the desoldering station to Wakefield... It'll make short work of any wayward DIPs ...
KenLowe
Post by KenLowe » Thu Apr 11, 2019 12:54 am
I use a desoldering pump to remove the worst of the solder, then give the underside of the PCB a blast with a hot air gun whilst at the same time using a small flat blade screwdriver gently lever the chip on the other side of the PCB. Once the solder is sufficiently melted, and the chip starts to work free, I then use a long nose pliers to lift the chip out. The key is to have a sufficiently large nozzle on the heat gun to ensure the heat is spread evenly across all pins.
Once out, I then clean up the holes in the same way as Rob.
SpaceFlightOrange
Post by SpaceFlightOrange » Thu Apr 11, 2019 10:09 am
Cool.
If i haven't plucked up the courage by then, would it be ok to bring it along?
James
SpaceFlightOrange
Post by SpaceFlightOrange » Thu Apr 11, 2019 10:18 am
Cleaned up. Looking much better now. The Magic eraser was a brilliant suggestion, @Kieranhj, Thanks. Unfortunately it didn't get rid of the pen but took everything else off, no bother. I haven't tried the hairspray trick yet, will do that next.
The magic eraser even got the original plug looking like new!
All Keycaps removed and cleaned too.
might redrobright it at some point, but really happy with it how it turned out
James
Post by RobC » Thu Apr 11, 2019 7:39 pm
By all means do - I'm sure that between us, Daniel and I can get it sorted.
SpaceFlightOrange
Post by SpaceFlightOrange » Thu Apr 11, 2019 7:57 pm
Cool! I was kidding, but that would be great, thanks
James
