FDD head shield
pelago
FDD head shield
Post by pelago » Tue Dec 18, 2018 10:38 pm
I opened up an old 5.25 floppy disc drive and noticed the part pictured had fallen off. It's a sort of metal shield to the read/write head. Looks like the black foam pad holding it on has perished a bit.
I can stick it back on, but is the pad supposed to be electrically or heat conductive?
Below is it lightly put in place so you can see where it came from.
SimonSideburns
Re: FDD head shield
Post by SimonSideburns » Tue Dec 18, 2018 11:35 pm
I guess they had some usefulness otherwise why would they have been there, but when I opened a set of twin drives that had these to find them in a similar way to yours I was able to remove them and the drives have been fine ever since.
Hope that helps.
pelago
Re: FDD head shield
Post by pelago » Wed Dec 19, 2018 10:22 am
Using a DMM, it certainly doesn't seem to be electrically conductive. I can't imagine it will be heat conductive either - looks too holey. I'll see if I can scrape the old stuff off and use a generic double-sided sticky pad to put it back on.
geraldholdsworth
Re: FDD head shield
Post by geraldholdsworth » Wed Dec 19, 2018 10:34 am
Take a peek at my thread:
viewtopic.php?f=3&t=16036&p=220469#p220469
plus there are a few others, in a similar vein, going back a few years asking the same question.
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
pelago
Re: FDD head shield
Post by pelago » Wed Dec 19, 2018 10:46 am
Thanks. Looks like some people say it works fine without it, whereas others say it adds weight to the head and works better with it. I'll stick it back on.
pelago
Re: FDD head shield
Post by pelago » Wed Dec 19, 2018 2:10 pm
Presumably it's not just to add weight, but to shield RF too.
