Page 1 of 1
ARM1 versions / batches
Posted: Tue Dec 18, 2018 4:26 pm
by firthmj
Does anyone have any information on how many ARM1 chips were produced, or in how many batches?
Most of pictures I have been able to find have been of the same batch of chips, dated week "8625", and labelled "AUTUMN" (is that a code name or a season?)
This includes the ARM evaluation picture on Wikipedia:
https://en.wikipedia.org/wiki/ARM_archi ... System.jpg
And all but one of the ARM chips in the various boards that Ed posted pictures of here:
viewtopic.php?f=32&t=13379&p=174900#p174900
Interestingly, if I am reading it right, what should be the oldest board (the 1MB one with mod wires at the top of the group) has a younger ARM1 CPU than the rest (date code 8634)
My next question is about the A500 computer (not to be confused with the A500 second processor). I originally had the impression that this would have had an ARM1, but the older instance described at Chris's Acorns has an ARM2:
http://chrisacorns.computinghistory.org ... /A500.html
Were all of them at least ARM2, or were there early ones that had ARM1s fitted?
And finally, after some rambling, the point of my post!
There seems to be two instances of "engineering sample" versions of the ARM1 that have been seen, which presumably are the original 1985 ones, rather than the later "production" run.
The first is in Dave M's pre-production ARM evaluation unit, which has been on loan to various people, and currently is residing with me. The ARM in this looks like this:
ES ARM1
Other images of the same unit are on Beebmaster's site here:
http://www.beebmaster.co.uk/Shows/ARMSecond.html
I thought this was the only instance of this flavour of the CPU that had been mentioned online, but today I found a reference to another chip, "in a box at the Centre for Computing History":
viewtopic.php?f=3&t=13223&p=173205#p173205
So my question is whether anyone knows of any other instances of the "engineering sample" silicon, and whether any of them are running in any boards / systems?
Re: ARM1 versions / batches
Posted: Tue Dec 18, 2018 6:59 pm
by SarahWalker
Codename.
I believe most if not all A500s were fitted with ARM1s initially. Most would have been upgraded to ARM2 so they could still be used as development machines, with some having prototype ARM3s.
Neither of the chips pictured in that thread are ARM1s I'm afraid. So there's probably just a small sample run in 1985, then a small production run in mid 1986.
Posted: Wed Dec 19, 2018 3:14 am
by IanB
Mine is also "8625" and "Autumn"
The serial nunber of the unit is 25-ANC13-1000032 if that's any help
BTW The PSU in the ARM evaluation unit has RIFA caps like the BBC/Master PSUs so make sure they are changed before trying to power one up.
Posted: Wed Dec 19, 2018 7:10 pm
by Boydie
Both mine are 8625 and Autumn as well.
Neither has a proper serial number, but one has a “51” label on the board, the other “56”. I’m guessing this was Acorn’s internal serial system. If so, it gives a minimum to the number if Arm1’s made.
Posted: Thu Dec 20, 2018 11:30 pm
by flynnjs
No, the wafers were clearly not ARMs but in the same box there was a
packaged device which I thinks was. At the time I hadn't seen the ES in
the 2/4MB copro but now I've seen that I'm going to go back and check
what's in the box and compare.
Posted: Fri Dec 21, 2018 8:45 pm
by firthmj
Does this mean that the ARM1 and ARM2 were pin compatible and interchangeable?
The two A500s on the Chris’s Acorns page seem to have different types of sockets for two of the main chips - sadly the picture of the (older) one that hadn’t been upgraded with an ARM3 daughter board isn’t clear enough to read the two chips to see exactly what they are.
Posted: Sat Dec 22, 2018 8:49 am
by Boydie
They’re VIDC1 (production Arcs used VIDC1a) in the rear-right corner and early MEMC near the ARM.
Not sure if ARM1 and 2 are pin-compatible, but my A500 (ARM2) is an Issue B board. Could be that Issue A was socketed for LCC chips (ARM1) and Issue B for PLCC (ARM2)...
edit: Just checked the ARM Family Datasheets - if the ARM1 pinout on wikipedia is correct, the pinouts are near-identical, certainly close enough for a minor bodge.
Posted: Sun Dec 23, 2018 11:09 am
by SarahWalker
Even if they aren't compatible, it's entirely possible that the boards could have been reworked. They'd need some rework anyway, to allow for the MEMC1 w/ARM2 workarounds.
Posted: Mon Sep 23, 2019 4:11 pm
by anightin
Just sharing the above with a colleague at work who was involved in the original development, having myself just come across Dave's VC2588 at ABUG this weekend with Michael and co. who was tapping skillfully away, compiling and running code.
Said colleague offered the following just in case it helps to identify other old ARM processors:
Early prototypes:
VC2588 - ARM1 (Autumn)
VC2304 - MEMC (Anna)
VC2303 - VIDC (Arabella)
VC2311 - IOC (Albion)
VL2333 - ARM2
Volume production:
VL86C010 - ARM2
VL86C020 - ARM3
VL86C110 - MEMC
VL86C210 - Unallocated
VL86C310 - VIDC
VL86C410 - IOC
VY86C610 - ARM610
VY86C710 - ARM710
I did ask, and no information from this source, although the number of ARM2's was publicised in a 1990 press release:
More than 130,000 chip sets of the full 4 chip family
(ARM2 processor, MEMC1 memory controller, VIDC video
controller, IOC IO controller) have been shipped to
date, placing it among the leading RISC processors.
https://groups.google.com/forum/#!topic ... 6Icb__amCw
Best wishes
Andy
Posted: Tue Sep 24, 2019 11:29 am
by RobC
Anna, Albion and Arabella were definitely used in production Arcs as I've got them in two of my A440s. Not sure how many got out before they changed to the A4../1 machines though.
Posted: Tue Sep 24, 2019 8:22 pm
by myelin
My A310 has some overlap with that list:
ARM: VL2333-QC / ARM / ACORN / KOREA A
MEMC: VL2304-QC / ANNA / ACORN / KOREA A
VIDC: VL2303A QC / ARABELLA / ACORN / KOREA A
IOC: VL2311PS-QC / ALBION / ACORN / KOREA A
Posted: Tue Sep 24, 2019 8:41 pm
by firthmj
Early prototypes:
VL2333 - ARM2
Volume production:
VL86C010 - ARM2
VL86C020 - ARM3
VL86C110 - MEMC
VL86C310 - VIDC
VL86C410 - IOC
VY86C610 - ARM610
VY86C710 - ARM710
Best wishes
Andy
Interesting stuff! Glad the outing for the unit at the weekend has generated some interest in early ARMs!
One other update from then - Mark (Groot) and I had a chat with Jason Fitzpatrick about the Eng Sample ARM1, and he pointed us to another one that they have, which is actually on display as the example of an integrated circuit in the museum. I’m pretty sure Mark took some pictures of that one, but it looked identical to the one in the prototype ARM eval.
Posted: Sun Sep 29, 2019 9:04 pm
by flynnjs
I've not been back and looked in the box of Wafers and ICs we checked over
(which I commented to Jason F at the time I suspected to be an ARM Eng Samp)
so I guess he took that on board and it's now on display.
Would be nice to reunit one of the Eng Samps with the prototype PCB.
