Econet clock?
Econet clock?
Post by DutchAcorn » Mon Nov 19, 2018 7:10 pm
Got this with some other bits:
Can this be an Econet clock? There is nothing on the PCB...
Re: Econet clock?
Post by sweh » Mon Nov 19, 2018 7:47 pm
Looks like it; the MC14411 is a bitrate generator, and the 75159 is common in Econet circuits.
Hmm, the "Level 1 clock" documented at http://www.beebmaster.co.uk/Econet/ClockT1-6.html has the same 2 chips.
Not sure how you'd change the speed on your one, though!
Re: Econet clock?
Post by DutchAcorn » Mon Nov 19, 2018 8:04 pm
Thanks! Yes, that looks similar. It is probably fixed to one speed then... I had no idea that clock speed was a factor to consider in Econet network.
There is no plug on the unit. Looks like a normal 220V cable, but it also has a home made feel to it so I don't really trust it.
Re: Econet clock?
Post by flaxcottage » Mon Nov 19, 2018 9:18 pm
Looking at the circuit board there appear to be some unpopulated holes. Could these be for terminators or clock speed changing?
Re: Econet clock?
Post by DutchAcorn » Mon Nov 19, 2018 10:23 pm
Looking at the other side of the pcb it seems there are even more similarities.
AndyF
Re: Econet clock?
Post by AndyF » Tue Nov 20, 2018 10:25 am
Possibly dual function in that it could of just been populated with the termination components instead of clock components.
If memory serves some early terminator boxes were powered ( ? ) although as to why I'm not sure.
Andy
johnkenyon
Re: Econet clock?
Post by johnkenyon » Tue Nov 20, 2018 11:28 am
Looks like someone's brewed copied the original clock PCB, added a track to permanently select one speed and left the link holes undrilled.
I love the way the tracks from the transformer secondary pass oh so close to the incoming mains connection.
If I was going to use this for real I'd replace the 7805 with two terminal pins and connect a hacked USB cable to provide +5v directly - firstly because of the dodgy mains PCB tracks, and secondly because low voltage transformer power supplies with linear regulators are so 20th century.
Re: Econet clock?
Post by flaxcottage » Tue Nov 20, 2018 5:04 pm
... because low voltage transformer power supplies with linear regulators are so 20th century.
:lol: :lol: :lol: =D> =D> =D>
Re: Econet clock?
Post by DutchAcorn » Sat Nov 24, 2018 9:05 pm
The PSU only supplied 1V, which was not quite sufficient. So the USB cable seemed like a good solution :D
Re: Econet clock testing...
Post by DutchAcorn » Thu Nov 29, 2018 7:57 pm
Today I got some econet cables so, unhindered by more than superficial knowledge of Econet networking, I connected an Econet fitted BBC on each of the connectors.
Using *notify I tried to send a message across, but no luck. :?
Should this work or is a socket box needed for this setup?
Re: Econet clock?
Post by Rod C » Thu Nov 29, 2018 8:54 pm
Maybe two socket boxes with termination?
myelin
Re: Econet clock?
Post by myelin » Thu Nov 29, 2018 9:02 pm
You'll need a terminator somewhere in the circuit. Technically you should have one at each end, but for a short cable run (a few metres) it won't matter. The Econet terminator also biases the circuit, so it sits in the reset (data=1) state. Without one, I believe you'll end up with a 'line jammed' error.
Post by jgharston » Fri Nov 30, 2018 1:18 am
Have you got NOTIFY on disk or in ROM?
If not, this short type-in is a simple notify-esque test:
   10 REM Program to test Econet
   20 REM  RL 01jul1985
   30
   40 INPUT "Station to test: "stn%
   50 DIM X% 20:Y%=X% DIV 256
   60 X%?0=1    :REM send string
   70 X%!1=stn% :REM dest station
   80 $(X%+3)="*| Are you there?"
   90 A%=&14:CALL &FFF1
  100 PRINT "OK"
Post by DutchAcorn » Fri Nov 30, 2018 10:49 am
It seems I may have the basics wrong. I (probably wrongly) assumed that *notify was an NFS command contained in the NFS rom. *help is very unhelpful for NFS. Thanks for the code, I'll try that tonight!
Post by DutchAcorn » Fri Nov 30, 2018 8:00 pm
It works! \:D/
Thanks!
johnkenyon
Post by johnkenyon » Sat Dec 01, 2018 12:36 am
NFS3.60 only handles two * commands - *NET and *ROFF.
Everything else gets handed off to the file server.
