Watford Electronics PALPROM Redesign
Post by hoglet » Wed Oct 24, 2018 6:48 pm
(Continued from RGBtoHDMI Thread)
Today, for a but of fun, I've been building my own Watford Electronics PALPROM carrier so I can play with IanB's wonderful Quest Paint program.
There now is a github repository for this project containing:
- KiCad 5 Schematic and PCB
- GAL16V8 design for Quest Paint
- Original ROM images
- Original disk images
- Documentation
The Quest Paint PAL re-design uses the same pinout at the original, but was re-created from scratch so it might have subtle differences.
Here's some photos...
The PCB layout printed out on drafting film:
The PCB etched and drilled with 0.7mm holes:
(only a couple of slightly wayward holes!)
All soldered up:
(the flux will get cleaned off soon!)
GAL16V8 PAL installed and programmed:
(the jedec file is in gitub)
It's ended up a very similar form factor to Ian's original:
If you didn't want to socket the PAL, you could reduce the height a bit:
Installed in my Master as ROM 8:
And amazingly it worked first time:
Ian, is there a manual online anywhere for Quest Paint?
Re: Watford Electronics PALPROM Redesign
Post by BigEd » Wed Oct 24, 2018 6:59 pm
Amazing, and splendid!
IanB
Post by IanB » Wed Oct 24, 2018 10:18 pm
I don't think anyone's scanned it but I have a copy and also a copy of the Wapping Editor manual as well so I'll scan them when I have time.
Meanwhile, here is the draft manual in View format:
Quest Paint Manual (View format).dsd
(400 KiB) Downloaded 31 times
You can view this as text in DFS explorer and it's more or less readable.
BTW Wapping Editor is essentially a Mode 0 version of Quest Paint with a text editor, font editor and typesetter.
Post by hoglet » Wed Oct 24, 2018 10:29 pm
Again, many thanks.
How different is the carrier board for Wapping Editor?
It will need A15 on the 27C512 driving from the PAL. I wonder if that's the only difference.
IanB
Post by IanB » Thu Oct 25, 2018 12:59 am
I'll trace the tracks when I have the time.
BTW the original boards had the PAL mounted upside down on the bottom of the pcb
I wonder if it would be possible to come up with a universal board and PLD that could cope with 32K and 64K and and switch between them with a link.
Post by hoglet » Thu Oct 25, 2018 7:45 am
Thanks.
I think it will be different. I would expect pin 6 would have been brought into use, freeing one output macrocell for the additional logic. I think 7 macrocells are needed for the 64K design, rather than the 6 used by the 32K design. I was going to write the PAL for that this morning to check.
Interesting and slightly surprising, as the pinout seems to have been optimised for top-mounting.
Could you take a couple of photos of the top and bottom of the Quest Paint board without the ROM and PAL fitted?
Yes it would, but I think you would need to move to a CPLD. This has the advantage of being lower profile, as well as being programmable insitu.
I do still like the idea of two-socket cartridge port version.
I wonder if anyone has a KiCad design for a ROM cartridge?
Post by daveejhitchins » Thu Oct 25, 2018 9:04 am
Thanks.
Dave, I can send you DXFs of a large and small cartridge PCB, when I get home this weekend, if they would help?
Any chance this would work on the Electron ??
Post by hoglet » Thu Oct 25, 2018 9:18 am
Yes please for the DFX files.
If by this you mean the Quest Paint program, I think not as it uses MODE 7 for some things.
Post by hoglet » Thu Oct 25, 2018 12:52 pm
I've added a PLD file for Wapping Editor, currently untested:
https://github.com/hoglet67/palprom/tre ... ing_editor
It will need to be updated once Ian confirms the original PAL pinout.
Post by daveejhitchins » Sun Oct 28, 2018 11:31 am
Here's what I've been using for my Cartridge PCBs. Attached is the Large PCB. If anyone would like me to adjust for the small PCB, just shout.
Cartridge Case and Board.dxf.zip
(3.83 KiB) Downloaded 28 times
Post by danielj » Sun Oct 28, 2018 12:07 pm
I did scan the wapping editor manual and uploaded it to archive.org :)
https://archive.org/details/wedit_201511
aotta
Post by aotta » Sat Jul 18, 2020 6:19 pm
was the jed file tested? i used your files for Quest paint and it worked fine, but the wapping editor version stop my Master from booting.
I don't know if i missed something or the Wapping Editor version is still in progress...
IanB
Post by IanB » Mon Jul 20, 2020 6:03 pm
It hasn't been tested so it will need to be looked at when I have the time.
aotta
Post by aotta » Mon Jul 20, 2020 6:17 pm
Thank Ian for the answer, so i know it's not my fault in assembling it.
